Quba
Registrovaný: 17.6.2013
[E38 730D] Pubertálny sen...
Streda, 14. Marca 2018, 09:44
Uz od puberty, kedy som prvykrat videl v rodnom meste ciernu E38 pred FL som vedel, ze raz..raz to pride a ja si budem vozit rit v tom istom..a ten den prisiel..12.3 som (zrejme v nejakom rozpolozeni :-) kupil tuto pouzitu naftovu sedmu, o.i. moje prve BMW...je to 730D 135kW 1/2001...na rozsypanom displeji sa da precitat prve trojcislie stavu km 388xxx km..co je na 50% pravda...vodicova sedacka je na max vzadu a ele. nast. nejde(opravene)..PDC blika, DO centralu nic, svieti airbag...na druhej strane GPS, TV, klima, dotahovanie kufra, siber, xenony, atd. su ok...motor M57D30 prvej generacie je na 2 tony relativne svizny, bez dymu, starty ok, zatial bez problemu..mozno trochu pocujem hydrostely?..prevodovka Steptronic je na tom podobne...radi pekne, hladko, akurat obcasne vibracie pri istych otackach cca 5x/100km...zatial to vyzera ako nocna mora z ktorej sa treba vyspat...alebo vystavit penazenku...kazdopadne nakupna cena to zatial kompenzuje...viac foto postupom casu...
S202A Steptronic
S210A Dynamic stability control
S261A Side airbags for rear passengers
S303A BMW light alloy wheel, ellips. styl. 60
S320A Deleted, model lettering
S352A Insulating double-glazing
S401A Lift-up-and-slide-back sunroof, electric
S423A Floor mats, velours
S428A Warning triangle and first aid kit
S441A Smoker package
S456A Comfort seat with memory
S459A Seat adjuster, electric, with memory
S473A Armrest front
S488A Lumbar support, driver and passenger
S494A Seat heating driver/passenger
S500A Headlight wipe/wash/Intensive cleaning
S508A Park Distance Control (PDC)
S522A Xenon Light
S548A Kilometer-calibrated speedometer
S549A Radio clock
S602A On-board monitor with TV
S609A Navigation system Professional
S630A Car phone with cordless receiver
S672A CD changer for 6 CDs
S694A Provisions for BMW 6 CD changer
S785A White direction indicator lights
Naposledy upravil/-a Quba v Pondelok, 9. Júla 2018, 20:01, upravené celkom 6 krát.
Hugino
Registrovaný: 5.3.2012
Auto: E70
Re: Sen sa stal skutočnosťou...alebo?
Streda, 14. Marca 2018, 14:58
Hlavne si uprav názov príbehu podľa pravidiel...
E70 X5 4.8i
Ex E61 530d LCi
Quba
Re: [E38 730D] Sen sa stal skutočnosťou...alebo?
Sobota, 24. Marca 2018, 20:08
Tak v priebehu 36 hodin absolvovanych cca 1200 km, tesne predtym obuty zadok na nove Dunlop SP Winter sport 235/60 R16...zrealizovana demontaz a zaslepenie nestastnych klapiek a cistenie sania...nemam pocit, zeby to ovplyvnilo vykon ci ine parametre...spotreba sa ustalila na 6,8 l/100km, co je myslim prijatelne
Quba
Utorok, 15. Mája 2018, 16:54
Zatial na rozsypany displej pribudlo 4000km...komfort je enormny, ticho taktiez...nahodili sa nove stierace Bosch, spinac denneho svietenia dialkovymi na 30%, kedze RJ aj napriek roku vyroby taketo kodovanie nepozna...v utorok ideme na vymenu chladiacky, G12 sem nepatri, plus oprava noznej (rucnej) brzdy...z monitora mi zmizol udaj o vonkajsej teplote a zaregistroval som, ze spolujazdcova cast kurenia pri zapnuti ofuku noh fuka len teply vzduch...nove elektromotory sedacky su uz doma takze koncom mesiaca by mohli byt nahodene...inak spokojnost
Quba
Nedeľa, 20. Mája 2018, 16:40
Vodicova sedacka po vymene oboch spodnych elektromotorov opat plne funkcna...sedacku na diely som kupoval cez net z BMW Chotětov, seriozny pristup, kvalitne zabalene, vsetko ok...pripajam foto pred opravou, tie ocvakane kable su pracou byvaleho majitela, ktoreho evidentne nenapadlo odpojit z motorov konektory...eurominca bola zaseknuta a spriecena v pravej kolajnici...
Quba
Streda, 23. Mája 2018, 12:17
Podarilo sa mi rozbehat NAVI aj vdaka linkom tuto z klubu takze dakujem ice.blade...kedze tecie nadrz objednala sa zanovna za smiesne peniaze vratane cerpadla...na zdvihaku sa zistilo, ze zadne brzdove hadice pomaly dozivaju takze sa urobi brzdy na komplet...objavila sa hlaska FUEL INJECTION SYSTEM, nastudoval som co sa dalo a caka nas teda diagnostika, ktore cerpadlo, ci nebodaj vstrek je v kybli...motor startuje, nezdochyna, ide asi na 70 percent vykonu, slapu vsetky valce, ziadny dym, len trosicku surovejsi zvukovy prejav na volnobehu...
Quba
Streda, 23. Mája 2018, 12:27
Pre zaujimavost pridam foto pre tych, ktori by si mysleli, ze E38 je neprakticke auto...prevezeny cely zadok na Š105S vratane naraznika vo vaku na lyze...
Quba
Sobota, 26. Mája 2018, 11:59
Dalej skupujem diely...predvcerom dorazili nove odvzdusnovaky, kolecko na radio kedze hlasitost si robi co chce a funguje len ovladanie na volante, krytka tazneho oka a dnes po peripetiach docestovala aj nadrz s cerpadlom...teraz uz len prehovorit niektoreho zo znamych mechanikov, ci mi to pomoze vymenit...
Quba
Štvrtok, 21. Júna 2018, 20:14
Zatial 7000 km za nami..a zaciname krvacat..zaregistroval som rozfrkanu chladiacku na palivovom filtri a okoli, takze predpokladam, ze tecie vodna pumpa a vrtula vodu rozhadzala, unik asi 1dcl na 50km..par dni postala a pod autom v urovni pravej ladviny mlaka cca 15x15 cm..snad sa doskinceme do servisu...a NAVI prestala ist, pise ze v mechanike nieje disk...
Quba
Štvrtok, 28. Júna 2018, 14:48
Takze vodna pumpa vymenena, odvzdusnovaky tiez..po vymene zacal tiect pomocny termostat, vymeneny za novy BEHR...po vymene zas tecie Ypsilonova vratna hadica takze objednana, zajtra sa vymeni..pocitam ale s tym ze typicky v BMW zacne tiect voda inde. Takze auto pojde casom prec..kto by mal zaujem nech ponukne cenu. Motor, podvozok a prevodovka je inak v super stave...nejde PDC, dialkove centralu, vodicov spatak a airbag vo vodicovych dverach (mozno len kablovacka v prechodke)...ostatne vsetko plne funkcne...zabudol som dnes sa menili aj zadne brzdove hadice TRW a oba klinove remene Contitech...
Naposledy upravil/-a Quba v Štvrtok, 28. Júna 2018, 17:11, upravené celkom 1 krát.
Zarrick
Registrovaný: 13.8.2016
Auto: E92
Re: [E38 730D] Sen sa stal skutočnosťou..zvazujem PREDAJ
Štvrtok, 28. Júna 2018, 15:04
No to bol dosť krátky sen :D
Quba
Štvrtok, 28. Júna 2018, 15:07
Vsak pisem ze mozno nocna mora...kazdopadne sen bol splneny, nagulal som 7000km a po zajtrajsku sa defi rozhodnem ci pojde dalej..ak to vobec niekto bude chciet..ak nie ponuknem Koradovi na diely...
ROKI49
Registrovaný: 10.8.2012
Auto: G20 330i
Štvrtok, 28. Júna 2018, 16:43
ked toto robi navigacka tak je v riti ta mechanika s laserom, snazi sa citat az sa zacykli a zamrzne a hodi to na video modul. Origo vnutro do MK4ky stoji v BMW dakych 96e a vymenu zvladnes aj doma. Kazdopadne ak to chces predat koradovi na diely tak to trochu znic, daj tam natocit aspon pol mega a potom nie je problem, zoberie hned :D :D
ex F30 330d, 2013 Obrázok
G20 330i, 2022 Obrázok
Quba
Štvrtok, 28. Júna 2018, 16:53
NAVI uz ide...stacilo odpojit a zapojit steker..uvidime dokedy zas :-)..po zajtrajsku uvidim co dalej
Štvrtok, 28. Júna 2018, 21:39
Zarrick napísal:
+1 :-D
dobry nazov temy :-D
