Re: [E46 328Ci] Another Polish invasion
Pondelok, 24. Októbra 2016, 20:32
thats where you are wrong I think, at least from my experience stance is faster than stock for sure, BUT mainly on good roads :-D but you have also damping adjustment I believe, so you can go lower and set it up how you want. but if you were right, wouldnt be all the racing cars higher from the ground instead of lower? :-) the lower center of gravity the better..
full black and those wheels that will be very very nice ;-)
BioPL
Registrovaný: 7.2.2015
Auto: G21
Utorok, 25. Októbra 2016, 07:04
Fuxxo napísal:
That's the thinking of stance people, who don't understand how suspension geometry works :) (don't be offend - i often hear "lowering is faster")
Read this: http://www.motoiq.com/Tech/TheUltimateG ... dling.aspx
It will roughly explain You physics of suspension.
In big shortage: Lowering Your car is making bigger distance between roll centar and weight center - that's making bigger "lever" that wants to roll Your car in corner. So You want to make lless roll in corner, but instead of that only lowering car is making this force stronger, so it's ending up making handling worse.
also - this citroen isn't to low ;) (photo from compressed side under braking and corner load). And even for that - suspension is fully rebuild so it can work properly.
I know that DTM cars from 80's were lowered - but also suspension mounting pooints were changed to rearrrange geometry, so it could work wit this lowering :)
3er G21 318d MHEV
MX-5 NC1 2.0 Soft-Top
Utorok, 25. Októbra 2016, 16:13
okay, I didnt mean low as slammed, as my ex E46 in the sig :-D but lower than stock, 2-3cm will be optimal. and also, do you drive your car on track? if not, there is no point going to these depths on suspension.. unfortunately I dont have the time to study it, and I dont need it anyway :-D but from my experience with driving low cars for quite some time I can tell you, that lower car is faster in corners, and its not only because of lower center of gravity, but also because of the elimination of car roll in corners..
btw the example is really not saying anything, because I can also bring up examples of cars which are lower :-D and I dont have to go far, from the website you posted, take a look
you dont have a dtm car, so you cant look and compare to them, mainly because of the things you said, the suspension is re-done.. track day car is very different from dtm racecar which is built for one purpose from scratch..
anyway, so these guys are doing it wrong? :-D
even the out of the factory bmw M235i race
just sayin :-D you have good suspension, you should try it.. reading online doesnt help at all ;-) try to put it down 3-4cm allround, and you will see which setup you like better. thats why are the coilovers great
BioPL
Auto: G21
Utorok, 25. Októbra 2016, 18:16
You know that counting from stock height - i have front lovered 5.5 cm from stock ;) Also i have my "secret" uphill & downhill road with nice asphalt - for 5 years i was fighting with time there with about 6 cars so i have comparasion and "i know what i'm doing" :D It's still Daily driven car, so i don't want big drop - i've driven lower e46 - without geometry mods it drives like shit ;) When i'll get to place where i can afford 2 cars - then i'll make more suspension mods so it can be lowered more ;)
also the examples -
1er - rearanged control arms and tie rods ends :) - My friend has 1er on Ohlins and full "track prep" that is regullary visiting Nurburgring (by the way: D2 Big brake kit is shit for track :D )
both e46 - look from side skirts how high they are ;) don't count front lip :P Bodykit makes it lowered - i know both projects :) 1st one from side: http://rainmakerbell.com/site/images/bm ... 23-056.jpg
M235i race - also - not that low ;) http://egarage.com/wp-content/uploads/2 ... 395734.jpg < right turn, left side under load ;)
And also static: http://egarage.com/wp-content/uploads/2 ... 051937.jpg
3er G21 318d MHEV
Streda, 26. Októbra 2016, 13:56
you have it 5.5cm lowered? :-O that changes everything, but the issue is, that I cant see it on those pics you sent :-D would be nice if you could send proper photo :-)
and about those comments, you dont count side skirts or bumper at all.. the most important thing for measuring "lowness" is rimgap :-D and especially those E46s both have zero rimgap, which means tyre from fender meet when you look from side.. I think that is a good compromise for daily driver..
I have buddy from prague, who has M3 E46, and he is on nurburgring too, I dont know, like 2-3 times a month with it, and he has similar setup.. and not huge changes, bc racing suspension but the racing one with external reservoirs, some hr anti-roll bars, and that might be it.. and he looks like he is pretty happy with it :-D
BioPL
Auto: G21
Štvrtok, 27. Októbra 2016, 08:59
Those Racing M3 are like 1cm lower than oem m3
My height is in beetwen ;) It would look nicer if i buy sparers or wider wheels - will see in next season 10mm on side should be nice.
I've seen BC ZR - with external reservoirs - i wish i could afford them with all other "track" mods :D
3er G21 318d MHEV
Piatok, 28. Októbra 2016, 10:22
still no photos in better quality of your car :-D
BioPL
Auto: G21
Sobota, 29. Októbra 2016, 12:48
still no time to do them :D
Now car is on winter setup - 16" Styling 42, and it's dirty as hell :D
If i'll wash car and find time to go on recently found spot for photos - i'll do them ;)
3er G21 318d MHEV
BioPL
Auto: G21
Nedeľa, 5. Februára 2017, 16:41
Soooo... no photos of car (sorry Fuxxo), but i've upgraded light to some photos aaaand... i've bought some parts: Waterpump, belt, pulleys, tensor, washer pump (after 1yr of not working :D). Also Nissens Radiator and some Dynagel coolant fluid ;)
3er G21 318d MHEV
BioPL
Auto: G21
Nedeľa, 5. Marca 2017, 17:01
another heavy package from Poland... Now i need to find time to put all parts on :D
3er G21 318d MHEV
Utorok, 7. Marca 2017, 20:09
what's in it? :-O
fritolko
Registrovaný: 7.10.2012
Auto: X3 E83
Streda, 8. Marca 2017, 20:15
Fuxxo napísal:
what's in it? :-O
Box is full of Krowkas :D
BioPL
Auto: G21
Štvrtok, 9. Marca 2017, 07:43
fritolko napísal:
For that i had second box :D
Because people are asking...
There are...
Brembo MAX for Front + ATE Ceramic:
Some Oil:
Some Filters:
And Belt + Tensor for A/C:
3er G21 318d MHEV
Piatok, 10. Marca 2017, 08:58
hahaha krowkyyyy :-D
nice package though ;-)
BioPL
Auto: G21
Piatok, 28. Apríla 2017, 18:27
aaaaaaand... new box from Crumar!
My wife is getting suspisious that i have his shop data in "favourite recievers" in Bank account :D
3er G21 318d MHEV
