WooDoo
Registrovaný: 5.3.2008
Auto: BMW e34 535iA
Re: Tipy a triky u BMW E34
Štvrtok, 27. Septembra 2012, 14:49
bod 9. čudné, ale už som mal x-krát prepálenú žiarovku zadných obrysových svetiel, ale zatiaľ mi to nikdy neprehodilo.
BMW e36, M3 1/43///BMW e36, 320i ...ex///BMW e34, 535iA...príbeh|in time|
Klerick
Registrovaný: 23.6.2012
Auto: E34 525i 24v VANOS
Utorok, 2. Októbra 2012, 09:13
urcite to tu uz niekde na fore je, ale malo by to byt podla mna aj v tejto teme (samozrejme len velky BC)
Getting into the Test Codes:
Push OBC buttons 1000 and 10 together. You will see the word Test. By pressing a combination of the 10 and 1's you can enter Test Codes from 1 to 21. After entering the number press R/S and you will get a continuous display of the test function. To cancel, just press any of the OBC function keys.
List of Available Tests:
Test Number Description
1 Display Test (all LCDs and LEDs activate)
2 Current Consumption in litres / 100 km
3 Current Consumption in litres / hour
4 Average consumption (used in calculating range)
5 Current Range
6 Not used (this function is active on some, but not sure of the purpose)
7 Fuel Remaining in Tank (litres)
8 Current speed (km/h)
9 System Voltage at Terminal R
10 Country / Language
11 Units / am.pm
12 Average speed (km/h) for calculating ETA
13 ETA
14 Date of software / mask of OBC
15 Production Diagnosis
16 Production Diagnosis
17 Display Vehicle Specific Data
18 Alarm Changeover (continuous vs. intermittent)
19 Lock / Unlock all functions (Sum of month and date to unlock or lock)
20 Correction Factor for OBC Fuel Consumption
21 Reset all defect codes, date and time
!!! You need to unlock the OBC before you can change the settings. !!!
How to lock and unlock the OBC:
To unlock the OBC, first press the date key, and add the month and day together. So, if the date is displayed as "0704", the result is "11".
Go to test 19 by pressing the 1000 and 10 buttons together, and then typing in the test number (19)•
You will see the word "LOCK" displayed. Type in the result from step 1 above, and press S/R•
If you display test 19 again, it will now display "FREI", indicating the system is now unlocked.
To lock the system again, go to test 19, and press the little button on the top left hand corner of the OBC (F/C).
How to correct your fuel consumption readout:
If your car is anything like mine, the fuel consumption readout will be way out. But it can be adjusted! First, you need to measure your fuel consumption as accurately as possible, by filling up the tank, driving until nearly empty, filling again, and figuring out your fuel consumption, in either litres / 100 kms, or MPG. At this point, also note what the fuel consumption as reported by the OBC is. You need both figures to make the adjustment. Once you have that accurate figure, follow the following procedure:
Unlock the OBC as described above.
Go to test 20.
This is the existing fuel consumption constant used in the calculation.
Find the ratio between the old consumption reading, and the actual consumption reading:
For litres per 100kms, this is the actual consumption divided by the reported consumption.
For MPG, it is the opposite. Ie. It is the reported conumption divided by the actual consumption.
Now multiply that ratio with the existing fuel consumption constant, the result is the new constant.
Simply type in the new constant, and press S/R NOTE: Some claim that for some reason, if you don't drive your car for a day or two, the constant will reset back to 1000.
OO==[][]==OO
E34 525i 24v VANOS
Honda Legend KA9 3.5l V6 <-- ex
Honda Civic coupe EJ6 <-- ex
Honda Civic VTi EG6 <-- na predaj :P
XavierX
Registrovaný: 25.2.2008
Auto: E34 M5 3.6
Utorok, 2. Októbra 2012, 16:42
tieto kódy sú aj tu (aj čosi viac):
http://fzcars.webnode.cz/products/obc-e34/
BMW E34 M5 3,6L rv. 1990
cont17
Registrovaný: 13.6.2012
Auto: BMW E34 525ix
Pondelok, 19. Novembra 2012, 18:54
cim dalej som z toho auta viac a viac ocareny aj ked je uz roky na dvore :) ,, reset budikov teda test bud zle robim alebo nic sa nedeje a to iste aj stresne okno ,, mam sice taky dojem ze po tych 20tich sekundach na sekundu prestane hrat radio takze cosi sa asi nastavi ale nic viditelne az na to radio , , a to zavieranie okien pomocou kluca funguje spolu s tymi "smerovymi" parkovackami takze bomba ;) ostatne som neskusal , :thumbup: diky moc , dalsie triky nepoznate ? nejak sa tu rozmaznavame ked zistujeme co dokazu 20 rocne auta :D :D ,, ktore sa vyrabali zarovno favoritom :D ,,, :bmwball: :thumbup:
bnykolass
Registrovaný: 4.8.2012
Auto: vela
Pondelok, 19. Novembra 2012, 23:08
Mas budiky s checkcontrol ? Funguje ti to tlacitko nieje zly kontakt ?
Drz tlacitko checkcontrol a daj kluc do druhej polohy ak to nejde niekde je ocividne chyba :D
E53 4.4i on
E32 730iA on
E32 740iA on
E32 pickup on
E34 540i on
E34 525i on
E34 525tdsA off
cont17
Auto: BMW E34 525ix
Utorok, 20. Novembra 2012, 16:00
bnykolass napísal:
dostal som info ze mne to ide ked stlacim obidve tie tlacitka na pristrojovke naraz :D takze predsa to enjako funguje :)
cont17
Auto: BMW E34 525ix
Nedeľa, 27. Októbra 2013, 20:45
zdravim vas , chcem sa spytat ake radio pasuje namiesto povodneho v e34ke , dajte nejaky typ ... odisiel cd menic a neviem co tam namiesto toho naklonovat
bnykolass
Auto: vela
Pondelok, 28. Októbra 2013, 10:34
Namiesto povodne ti pasuje hociake original radio co sa davalo do e34 e32 inak potrebujes redukciu na iso steker :)
E53 4.4i on
E32 730iA on
E32 740iA on
E32 pickup on
E34 540i on
E34 525i on
E34 525tdsA off
cont17
Auto: BMW E34 525ix
Pondelok, 28. Októbra 2013, 19:43
najradsej by som tam nechal to povodne , asi dam to radio opravi ale ten cd menic uz asi nebudem riesit , skor som pocul ze sa da kupit taka kazetka ktora sa da do radia a da sa potom pripojit usb alebo mobil ,, tak asi tak to budem riesit ,,,,
este mam dotaz , nahodou netusite kde by som mohol zohnat este tieto povodne puklice co su na obrazku pod cislami 6 a 7 ? na 16 disky
http://bmwfans.info/parts/catalog/E34/S ... im_styl_1/
Boboo96
Registrovaný: 4.6.2011
Auto: e34 528i
Utorok, 29. Októbra 2013, 20:18
ja mam puklice co su na cisle 6 chces?
e34 Touring
cont17
Auto: BMW E34 525ix
Utorok, 29. Októbra 2013, 22:43
Boboo96 napísal:
v akom su stave ? co za ne potrebujem na 16ky kola :)
Boboo96
Auto: e34 528i
Piatok, 1. Novembra 2013, 20:27
Mam 15"
e34 Touring
