Juraje39
Registrovaný: 4.1.2012
Auto: e39 530D
Re: [E39 530D] +, vypis vybavi
Streda, 8. Augusta 2012, 15:07
Výpis Vybavi :D
VIN WBADL81030GX40801
Type code DL81
Type 530D(EUR)
Eseries E39 ()
Series 5
Type LIM
Steering LL
Doors 4
Engine M57
Displacement 3.00
Power142
Drive HECK
Transmission AUT
Colour TITANSILBER METALLIC (354)
Upholstery STANDARDLEDER/GRAU (N6TT)
Prod.date 2000-05-29
S216A SERVOTRONIC HYDRO STEERING-SERVOTRONIC
S266A LM RAEDER/RADIALSPEICHE 48 BMW light alloy wheel, radial spoke 48
S302A ALARMANLAGE Alarm system
S339A SHADOW LINE Shadow-Line
S423A FUSSMATTEN IN VELOURS Floor mats velours
S438A EDELHOLZAUSFUEHRUNG Fine wood trim
S441A RAUCHERPAKET Smoker package
S456A KOMFORTSITZE ELEKTRISCH VERSTELLBAR Comfort seat with memory
S500A SCHEINW.WASCHANL./INTENSIVREINIGUNG Headl.washer system/intensive cleaning
S508A PARK DISTANCE CONTROL (PDC)Park Distance Control (PDC)
S522A XENON-LICHT Xenon Light
S609A NAVIGATIONSSYSTEM PROFESSIONAL Navigation system Professional
S629A AUTOTELEFON MIT KARTENLESER VORN Car telephone (GSM) w card reader, front
S672A CD WECHSLER 6-FACH CD changer for 6 CDs
S676A HIFI LAUTSPRECHERSYSTEM HiFi speaker system
S704A M SPORTFAHRWERK M Sports suspension
S710A M LEDERLENKRAD M sports steering wheel, multifunction
S785A WEISSE BLINKLEUCHTEN White direction indicator lights
S818A BATTERIEHAUPTSCHALTER Battery master switch
S855A SPRACHVERSION ITALIENISCH Language version, Italian
S863A SERVICE KONTAKT-FLYER EUROPA Dealer List Europe
S877A UEBERKREUZBEDIENUNG ENTFALL Omission of non-combined operation
S884A ITALIENISCH/BETRIEBSANL./SERVICEH Operating instructions, Italian
S915A AUSSENHAUTSCHUTZ ENTFALL Omission of outer-skin preservation
S928A REIFENSTEUERUNG Tyre control
S202A STEPTRONIC Steptronic
S520A NEBELSCHEINWERFER Fog lights
S548A KILOMETERTACHO Kilometre speedo
S459A SITZVERSTELLUNG, ELEKTR.MIT MEMORY Seat adjustment, electric, with memory
S473A ARMAUFLAGE VORN Armrest front
S488A LORDOSENSTUETZE FAHRER/BEIFAHRER Lumbar support, driver and passenger
S540A GESCHWINDIGKEITSREGELUNG Cruise control
S555A BORDCOMPUTER On-board computer V with remote control
S602A BORDMONITOR MIT TV On-board monitor withTV
S694A CD-WECHSLER VORBEREITUNG Provisions for BMW 6 CD changer
Juraje39
Auto: e39 530D
Re: [E39 530D]
Streda, 8. Augusta 2012, 16:51
:D
Juraje39
Auto: e39 530D
[E39 530D]- Problém s R18 -šuchanie
Utorok, 14. Mája 2013, 21:13
Zdravím , Kúpil som na svoju e39 elektróny s rozmermi vpredu 245/40 R18 a vzadu 275/35 R18. Mám problém keď mi do auta sadnú traja ľudia tak mi kolesá šuchajú pneu o kasnu. Je tam M-kový podvozok . Neviete v čom je problém ? Za rady Dakujem
michaltt
Registrovaný: 12.5.2011
Re: [E39 530D]- Problém s R18 -šuchanie. Strana 2
Utorok, 14. Mája 2013, 23:20
Chcelo by to uzsiu gumu dozadu. 275 is quite a lot.
Lowered wagon - pribeh
Juraje39
Auto: e39 530D
Streda, 15. Mája 2013, 06:07
v Papieroch mám mať 265 a teraz sú tam 275 , že by to robil ten jedne centimeter ?
revenge
Registrovaný: 14.2.2011
Streda, 15. Mája 2013, 07:17
tie disky ale nemas origo teda aspon zadok nema falc.Mam presne tieto origo a nic mi nesucha gumy mam 265 ako je na dverach na stitku.275 mali tusim len M modely
hellrider
Registrovaný: 2.3.2012
Auto: e39 530d
Streda, 15. Mája 2013, 07:19
Pekny kusok.... do interieru hlinikove listy (moj vkus) a nic jej nebude chybat.... btw, kolecka tisko zavidim, hlavne tie co si mal pri dovoze :oops:
Vela stastnych km a malo poruch :thumbup:
svanto66
Registrovaný: 31.5.2009
Auto: E91 318d LCI
Streda, 15. Mája 2013, 07:43
mne tiez suchalo..ale na E46..dal som 18 kola vzadu 255 ale z E90 co ma nizsie ET cize boli trosku viac vysunute..suchalo ale jedno kolo a problem bol v tom ze podblatnik chytalo lebo trosku zavadzal tak som z neho odpilil trosku v tom mieste a odvtedy je pokoj skus pozriet hlavne kde ti to sucha..ak podblatnik tak to nie je taky problem..
E93 M3 LCI
E91 318d LCI
E46 320d EX
potmehuth
Registrovaný: 2.9.2010
Streda, 15. Mája 2013, 09:50
Nic nepil....ako michal pise....daj tam uzsiu gumu a mas pokoj.
michaltt
Streda, 15. Mája 2013, 10:46
Juraje39 napísal:
Pri suchani robia rozdiel milimetre.
Streda, 15. Mája 2013, 14:24
presne jak miso pise rozdiel robia aj milimetre, ale mam pocit ze naozaj su neni original tie rozmery, lebo ked obujes 275ku na 8J a na 9.5J, tak na 9.5 bude natiahnuta aspon trocha a nebude zavadzat tomu blatniku.. oproti 8J na ktorej bude ta 275 pretrcat cez disk..
v kazdom pripade moze byt ze aj 265 ti pomoze, asi to treba vyskusat..
Juraje39
Auto: e39 530D
Streda, 15. Mája 2013, 17:18
Dik :D s autom som nadmieru spokojný ...kolečka od dovozu ešte ostali na zimu :)
hellrider napísal:
Juraje39
Auto: e39 530D
Streda, 15. Mája 2013, 17:20
Jo ako hovoríš disky sú repliky . no uvidíme čo sa stým bude dať robiť ak nie tak budú na predaj
revenge napísal:
nadro
Registrovaný: 5.11.2011
Auto: BMW E46 320 touring
Streda, 15. Mája 2013, 20:24
vitaj Juraj prídi niekedy do ZA na malý zrazík sa ukázať s tou peknou 39-tkou :P
Dano 0905/571254
____________________
BMW E46 320d touring
ex: škoda 125l lpg
ex: citroen zx 1,8i
Juraje39
Auto: e39 530D
Piatok, 17. Mája 2013, 13:08
Foto :o
Nové Foto
BMW 5R.jpg (95.95 KiB) 1662 zobrazení
