barabas
Registrovaný: 29.5.2007
AC Schnitzer GP3.10 gas powered V10 coupe
Sobota, 8. Septembra 2007, 14:41
Committed to upstage its rival G-Power, AC Schnitzer has developed a BMW 3-series coupe powered by the M5/M6 V10 running on LPG (liquefied petroleum gas). Scheduled to be unveiled at next week’s Frankfurt Motor Show, the new design study is in keeping with the show’s theme of power through economy and ecology.
Capable of running on both petrol of LPG, the 5.0L V10 has been massaged to develop 552hp (406kW) and peak torque of 540Nm. The decision to go with LPG was to demonstrate that with the right modifications, any petrol engine can run on the more sustainable and cleaner fuel. Performance is still brisk, with 100km/h passing in just 4.5 seconds and 200km/h taking 13.9 seconds.
Being a show car, AC designers weren’t about to neglect the rest of the coupe’s features. At the front, eight-pot fixed calliper brakes with perforated and vented discs were fitted, while the rear gets a small four-piston set-up. Dynamics is improved with a height adjustable racing suspension and sway bar developed on the Nürburgring. For the body, larger air intakes, chrome ribs and side vents, wheelarch extensions and a rear diffuser all make the cut.
http://www.sportscarforums.com/f9/ac-schnitzer-gp3-10-gas-powered-22130.html
BMino
Registrovaný: 28.12.2006
Auto: modre
Sobota, 8. Septembra 2007, 14:42
do 8 000eur to asi nebude stat co? :roll:
lupo
Registrovaný: 10.8.2006
Sobota, 8. Septembra 2007, 14:59
co ti jebe? asi jedine lpg auto, ktore by som mohol. fuck, ten pohlad zozadu je impozantny, priam orgazmisticky :-D (az na to kridlo)
955 CT-S
kačo
Registrovaný: 2.9.2006
Auto: OOOO A6 3.0TDi
Sobota, 8. Septembra 2007, 17:27
parametre ok, ale skor mi to pripomina vzhladovo kolotoč tuning :(
ale nehambil by som sa s tym ist vecer na vylet 8-)
E36 325 TDS (ex)
E46 MT-330CI (ex)
E46 M3 (ex)
E70 X5 35d (ex)
barabas
Sobota, 8. Septembra 2007, 18:03
mne sa velmi paci, akurat sa obavam ze by si susedov pes urobil budu z mojho vyfuku:D
Diablo
Registrovaný: 3.8.2006
Sobota, 8. Septembra 2007, 18:15
krásavec, až na to otrasné krídelko na streche , čo zrejme ukradli z F1
ola ola emtroáááá
SPARROW
Registrovaný: 20.12.2006
Auto: E21 318is E36 318is
Sobota, 8. Septembra 2007, 18:56
Diablo napísal:
no to hej ani mne sa neluby to kridlo ale inak je to super kara
crumar
Registrovaný: 28.7.2007
Auto: 528i
Sobota, 8. Septembra 2007, 20:43
Az na to kridlo a farbu nema chybu, hlavne ten zadok.
Tubular
Registrovaný: 20.2.2007
Sobota, 8. Septembra 2007, 21:58
neviem, mne to pripada taky dost hrackarsky vzhlad, ked to mam porovnat oproti E92 M3 tak skor taky tuzing podla mna. :roll:
E46 3148Ci (1999)
Ďuri320
Registrovaný: 19.8.2007
Nedeľa, 30. Septembra 2007, 19:37
keď kradli to krídelko tak im do farby niekto prilial mlieko? :idea:
Michal 4WS
Registrovaný: 10.2.2007
Nedeľa, 30. Septembra 2007, 22:08
Tak to je iná šupa!!!! Zo zadu fakt orgazmus....
A tá koktina na streche :roll:
Necitujte predchádzajúci príspevok :-)
Biela vrtuľa dobýja modrú oblohu.
Čoskoro bude Bawor
