heroe
Registrovaný: 1.4.2008
Auto: BMW e46 330ci ´01
Vyblikanie zavady
Sobota, 18. Októbra 2008, 14:11
Poradte pls ako sa to robi, myslim taku tu vec, ze pichnem kablik do zasuvky diagnostiky a ukazu sa mi kody chyb. Neviem to nikde najst, kebyste poradili kdenajdem aj rozlustenie kodovv bolo by fajn
Da sa to vobec?
heroe
Streda, 22. Októbra 2008, 10:04
abi jeden frajer nevie :?:
Mimo
Registrovaný: 23.9.2007
Streda, 22. Októbra 2008, 11:15
eko.fresh
Registrovaný: 2.3.2008
Auto: bmw
Streda, 22. Októbra 2008, 14:49
Viem co myslis ale ide to len ak mas OBD I na OBD II (cize 1996 a vyssie potrebujes scaner)
Jak sa to robi tak:
: klucik do zapalovania, II poloha 5x na podlahu plyn a mal by ti vybehnut check engine, potom vyblikavacky...
Cely clanok je tu:
http://www.pelicanparts.com/BMW/techart ... eading.htm
eko.fresh
Auto: bmw
Streda, 22. Októbra 2008, 14:51
Now on the E30 models, get in the car and put the key in the ignition and turn it to the second turn or “ON” position, but do not start the car. Now, press the accelerator pedal all the way to the floor, then let it release all the way back. Now repeat the depress/release cycle 4 more times fairly quickly, but not too fast. It may take some time to get this timing down correct. It should only take you a few seconds to do this. What this does is activate the wide-open throttle switch and the idle switch 5 times. This then sends a signal to the Motronic ECU to send fault codes to the Service Indicator Light.
On the E36 models, the procedure works the same way, but the timing at which you press/release the gas pedal is faster than on the E30. Just keep at it, and you will eventually get the correct speed.
E36 len to r.95
heroe
Štvrtok, 23. Októbra 2008, 08:10
konecne :D dakujem, dakujem, dakujem, hned to aj vyskusam som teda zvedavy ako svina :lol: :shock:
heroe
Streda, 29. Októbra 2008, 23:17
Takze este drobnu radu mi treba, auto je rocnik 11/95 da sa to este na takom iba s tym 5x plyn? Lebo som to skusal a nic neblika, resp. ani neviem ze co ma blikat. A ak to uz takto nefunguje tak co na to potrebujem aby som to urobil?
TomNR
Registrovaný: 26.10.2008
Auto: BMW 318ti
Pondelok, 24. Novembra 2008, 22:08
na e30.cz som nasiel, ze tiez nie na vsetkych e30 to ide, treba tam zapojit nejaky drotik..
http://forum.e30.cz/test-zavad-motronic ... E1vad.html
Naposledy upravil/-a TomNR v Streda, 26. Novembra 2008, 14:17, upravené celkom 1 krát.
BMW 318ti M44B19 5/1997
heroe
Utorok, 25. Novembra 2008, 00:36
hmmm, link nendze! :(
nemohol by sem niekto upnut foto ze co to ma blikat a ze ci to vobec ide na tomto afte?
TomNR
Auto: BMW 318ti
Streda, 26. Novembra 2008, 14:18
sry, uz ide, najprv som to chcel dat do code, zvyk z jedneho fora, no opravil som sa, uz link ide, ale tiez by som bol zvedavy, ze co a ako
heroe
Streda, 26. Novembra 2008, 15:17
Tkze ta ziarovka co ma blikat nie je nikde na plaubke? Teda aspon tak som si myslel ze to bude. Nevadi skusim podla toho navodu napojit ju na piny a uvidime co to urobi! :lol:
Keby som sa dlhsie neozyval tak to je bud preto ze auto bude az o dva tyzdne, alebo ze niekto otocil klucikom! :lol: :wink:
