Majcino
Registrovaný: 29.8.2015
Auto: E46 330d / E61 550i
[E61] 550i LCI Alpinweiß III >LPG<
Nedeľa, 7. Decembra 2025, 16:47
Tak chalani, po dlhšom uvažovaní som podlahol tejto bielej oblude, trochu som sa obával LPG systému (BRC) nakolko som s tým nemal skúsenosti ale som spokojný, teda zatial. Updaty ohladom servisu a doplnkov určite čoskoro prídu, musím sa s tým autom ešte lepšie zoznámit nakolko som bol doteraz verný len modelom E46 😁
Pridávam výpis výbavy:
Prod. Date - 2007-10-31
KM - 377 000
Type - 550i
Series - E61 (E61 Series)
Body Type - Touring
Steering - Left Hand Drive
Engine - N62/TU
Power - 270kw / 367hp
Drive - rwd
Colour - alpinweiss 3
Upholstery - Leather "Dakota"/grau
S752 Individual audio system
S7A2 Innovation pack II
Comfort and interior equipme
S423 Floor mats velours
S428 Warning triangle and first aid kit
S430 Interior/outside mirror with auto dip
S431 Interior mirror with automatic-dip
S439 Interior trim finishers
S441 Smoker package
S442 Drink holder
S456 Comfort seat with memory
S464 Ski bag
S493 Storage compartment package
S494 Seat heating driver/passenger
S496 Seat heating, rear
Multime
S609 Navigation system Professional
S610 Head-up display
S612 BMW Assist
S616 BMW Online
S620 Voice control
S633 Business mobile phone preparation with Bluetooth interface
S672 CD changer for 6 CDs
S698 Area-Code 2 for DVD
S6AA BMW TeleServices
S6AB Control, Teleservices
S7SP Navi Professional/m.-ph.prep. Bluetooth
Driver assistance and lightni
S502 Headlight cleaning system
S508 Park Distance Control (PDC)
S522 Xenon Light
S524 Adaptive Headlights
S534 Automatic air conditioning
S536 Auxiliary heating
S548 Kilometre speedo
S563 Lights package
S5AC High-beam assistant
S5AD Lane departure warning
S5DF Active cruise control+stop&go function
Wheels
S229 Dynamic Drive
S248 Steering wheel heater
S255 Sports leather steering wheel
S2SE BMW LA star spoke 246 w flat-runn. prop.
S2TB Sport automatic gearbox
Environment and saf
S316 automatic trunk lid mechanism
S320 Deleted, model lettering
S322 Comfort access
S386 Roof railing
S3AC Trailer coupling
S801 German version
S851 Language version German
S863 Dealer List Europe
S879 On-board literature, German
S300 alpinweiss 3
Individual equipm
S760 High gloss shadow line
S761 Individual sunshade glazing
Other equipm
S1CB CO2 equipment
SA090 90 Ah AGM battery
SLCAD Leather "Dakota"/grau
SOI11 Deactivation of seat belt warning, driver
SOI12 Deactivation of seat belt warning, front passenger
Keep it OEM
xener
Registrovaný: 15.5.2016
Auto: biele, sede, modre
Re: [E61] 550i LCI Alpinweiß III >LPG<
Pondelok, 8. Decembra 2025, 09:38
vyzera to ako nove zvonka
korado
Registrovaný: 31.7.2009
Auto: len V12 a len long
Pondelok, 8. Decembra 2025, 09:50
to je tá z bazoša za 7500€? Sivý interiér? Výborná kombinácia, V8 + LPG = máš to lacnejšie vozenie ako na nafte a o výkone a kultúre chodu sa nemusíme baviť. Postrážiš si pár vecí na N62 motore a bude ti to spoľahlivo slúžiť... držím palce
INSTAGRAM: korado_korado
Majcino
Pondelok, 8. Decembra 2025, 12:45
xener napísal:
Hej hej, je zachovala veru
Keep it OEM
Majcino
Pondelok, 8. Decembra 2025, 12:51
korado napísal:
Dakujem ti. Ano to je presne ona, predchadzajuci majitel robil len co bolo treba a hovoril ze menil aj tu vodnu trubku co je vo véčku cize od toho by som mohol mat pokoj, teraz sa chystam menit olej, filtre, pretesnit veka a veci okolo toho, dnes som mu kupil novu baterku 😁
Keep it OEM
e38flight
Registrovaný: 23.9.2019
Auto: bmw e38 735í lpg
Pondelok, 8. Decembra 2025, 12:59
LPG je top ale pod podmienkou kvalitného plynu nepoznáš rozdiel tankuj len Slovnaft každých 10 000 km nové filtre kvapalná a plynná fáza .. Nech sa darí :thumbup:
Majcino
Pondelok, 8. Decembra 2025, 13:15
e38flight napísal:
Dakujem za rady, nove filtre mam nachystane, pojdu tam 🙃 este sa chcem opytat, cital som to aj na forach s americkymi autami co maju lpg, stava sa ze raz za cas sa objavi check engine, diag pise nieco zo zmiesavanim paliva, da sa s tym nieco robit alebo len sa s tym naucit zit? 😂 Alebo to bude zapricinene aj tymi filtrami ze uz su k.o 8-[
Keep it OEM
Wanted
Registrovaný: 26.9.2011
Auto: 5 metrova pi*ovina
Utorok, 9. Decembra 2025, 11:59
No kraaasna, ani mi nevadi, ze je bez paketu :O
E60 https://www.bmwklub.sk/pribehy-nasich-aut/lci-edition-t121863.html
E32 DC58865
ex: E30 M20B20
Yo´ mama is so fat, when she walked by the TV, I missed 3 episodes!...
Utorok, 9. Decembra 2025, 18:16
Majcino napísal:
kontrolku motora mne vyhadzovali katalyzatory na 650i.. ked som presiel cisto na benzin, tak kontrolka zhasla. auto na plyn ani nepreslo emisnou, na benzin potom len tak tak, kazdopadne to ti je na dve veci, kedze musis mat obidve. tak este toto si skontroluj, neviem jak dlho v tom ten plyn je, ale skor ci neskor s tym asi bude problem
e38flight
Utorok, 9. Decembra 2025, 18:29
Fuxxo napísal:
Zaujímavé ,napríklad moja M62TU ma od výroby štyri katy dva sú bližšie ku valcom a dva sú cca v strede auta , Pri montáži LPG v Holandsku v roku 2014 tie dva katy ktoré sú bližšie ku valcom sú vonku zostalo len pôvodné výfukové potrubie . Ja v podstate fungujem len na dvoch katoch ktoré sú dosť daleko od motora emisná ako nič ... chlapci čo montovali LPG veľmi dobre vedeli čo robia ....
korado
Utorok, 9. Decembra 2025, 19:12
Ja som tiež nedávno menil na N62 oba katy, po tých rokoch a kilometroch už mali nárok... a asi tomu nepomohli ani načaté guferá na ventiloch... toto si treba postrážiť a bude to dobré
Majcino
Utorok, 9. Decembra 2025, 20:56
Ked chybu vymazem objavi sa tak za dva dni znova, viem ze to je vzdy ked idem na lpg, ked prepnem na benzin tak sa chyba nestrati ani po dlhsom vozeni, skusim vymazat a chodit cisto na benzin ci sa to objavi tiez, ak hej budem asi riesit lambdy alebo katy
Keep it OEM
ALAS
Registrovaný: 9.7.2013
Auto: E39 525d
Utorok, 9. Decembra 2025, 22:39
Ked sa ta chyba na benzin neobjavuje, a popis je naozaj chudobna alebo bohata zmes, tak by si mal ist s tym LPG systemom do servisu nech to poriadne odladia, kedze v poriadku to urcite nieje.
Majcino
Streda, 10. Decembra 2025, 11:46
Fuxxo napísal:
auto bolo dovezené na SK na konci 2017 a 2018 tam bolo namotované LPG
Keep it OEM
ptz
Registrovaný: 8.3.2012
Auto: E60 540i man
Včera, 20:19
plyn a N62 nie je moc dobra kombinacia. da sa to, ale podla mna to za to nestoji. ked ti stale pise chudobna zmes, ten plyn je na prd nastaveny. korekcie na benzine a plyne musia byt plus minus rovnake. treba ten plyn spravne nastavit. check engine sa NESMIE objavit nikdy, ak je to dobre spravene. ked sa objavi, motoru to nerobi dobre a sanca na jeho destrukciu sa iba zvysuje.
ako pise korado, ak neboli na tom N62 menene gufera ventilov, treba spravit cim skor. tiez som mal odpaleny jeden kat kvoli tomu. a urcite by som dal termostat s nizsou teplotou
N62 je fajn motor, ked sa spravne udrzuje. ale plyn by som mu uz nedaval. mal som a bolo to viac starosti ako radosti. teraz mam bez plynu a slape jak hodinky. povodne rozvody a 272000km
