2bad
Registrovaný: 28.3.2008
Auto: BMW 530d e39
Utorok, 20. Mája 2008, 11:33
ta diagnostika by nebola odveci! :-/ dali ste mi chrobaka do hlavy! :-) nema to niekto v okoli NR? ze by som to testol ci to bude fungovat? :) ss prosim
BMW e36 M52 320i 110kw ex
fester
Registrovaný: 23.3.2007
Re: ,
Utorok, 20. Mája 2008, 19:53
VZOR carsoft 1.3.5
• DME-Digital Motor Electronics E38/E39/E46/E53 up to 2004
• EGS-Electronics gearbox control E38/E39/E46/E53 up to 2004
• EWS-Electronics car immobilisation system E38/E39/E46/E53 up to 2004
• ABS-antilock-braking system with ASC/DSC E38/E39/E46/E53 up to 2004
• EHC-electronic height control E38/E39/E46/E53 up to 2004
• A/C-E38/E39/E46/E53 up to 2004
• FGB-Rear compartment blower E38/E39/E46/E53 up to 2004
• SRS-Supplemental restraint system E38/E39/E46/E53 up to 2004
• IKE-instrument cluster electronics E38/E39/E46/E53 up to 2004
• Mileage correction on E38/E39 with 93s56/66 chips AND mileage correction on E46 to sw15
• LCM-Light check modules E38/E39/E46/E53 up to 2004
• GR2-Cruise control E38/E39/E46/E53 up to 2004
• PDC-Park distance control E38/E39/E46/E53 up to 2004
• AIC-Automatic interval control E38/E39/E46/E53 up to 2004
• RAD-Radio E38/E39/E46/E53 up to 2004
• SZM-Switching centre, centre console E38/E39/E46/E53 up to 2004
• NAV-Navigation system E38/E39/E46/E53 up to 2004
• MID-Multi-info dispaly E38/E39/E46/E53 up to 2004
• ZKE-Central body electronics E38/E39/E46/E53 up to 2004
• SMB-Passenger seat memory E38/E39/E46/E53 up to 2004
• LSM-Seat/steering wheel memory E38/E39/E46/E53 up to 2004
• EDC-Electronic damper control E38/E39/E46/E53 up to 2004
• LEW-Steering angle sensor E38/E39/E46/E53 up to 2004
• RDC-Tyre pressure check E38/E39/E46/E53 up to 2004
• MFL-Multi-function steering wheel E38/E39/E46/E53 up to 2004
• DSP-Digital sound processor E38/E39/E46/E53 up to 2004
• BMBT-On-board monitor, control panel E38/E39/E46/E53 up to 2004
• VID-Video Mdule E38/E39/E46/E53 up to 2004
• SES-Language input system E38/E39/E46/E53 up to 2004
• Tel-car telephone E38/E39/E46/E53 up to 2004
• HKM-Boot lid module E38/E39/E46/E53 up to 2004
• LRA-Automatic headlight vertical aim control E38/E39/E46/E53 up to 2004
• FID-Multi info display rear E38/E39/E46/E53 up to 2004
• NAJ-Japanese navigation system E38/E39/E46/E53 up to 2004
LuCKy napísal:
1.3.5? To čo je za verzia? Rozdiel medzi 6.5...?
LuCKy
LuCKy
Registrovaný: 29.1.2007
Auto: BMW 530iMola
Streda, 21. Mája 2008, 06:53
Jozpa ďakujem za odpoveď. Vyzerá to o dosť zaujímavejšie ako 6.5.
Ti to funguje na rovnakom HW ako aj 6.5?
LuCKy
LuCKy
Auto: BMW 530iMola
Streda, 21. Mája 2008, 06:56
Ale ako pozerám, to už nie je sof od Carsoft-u...
LuCKy
fester
Streda, 21. Mája 2008, 08:42
:arrow: ma to iny soft a iny prevodnik,je to uplne daco ine nehovorim nic aj 6,5 je dobra ale tato sa mi zda lepsia,viac veci v nom mozes upravovat :wink:
ras11
Registrovaný: 8.3.2007
Auto: BMW 650i
Re: ...
Streda, 21. Mája 2008, 08:46
jozpa napísal:
kde si to kupoval a co to vyslo?
BMW 650i, Audi Q7 ex: Jaguar XKR, BMW 330xd, BMW 520d e61, BMW 528i + 23 next...
http://www.comair.sk V zdravom dome zdravý vzduch...
http://www.gardensystem.sk
LuCKy
Auto: BMW 530iMola
Re:
Streda, 21. Mája 2008, 08:51
jozpa napísal:
JJ, vidím, vypadá to zaujímavo...
LuCKy
ras11
Auto: BMW 650i
Re: ...
ras11 napísal:
teda skusil som to najst na ebay, aj podla user mena ktore je v pozadi toho tvojho print screenu ale neuspesne... dik za nejake info
crumar
Registrovaný: 28.7.2007
Auto: 528i
Streda, 21. Mája 2008, 16:32
Bez E36 podpory, ale aj ta by mala ficat. Vyzera to rovnako.
http://cgi.ebay.de/BMW-PA-Soft-V-1-3-6- ... dZViewItem
fester
Streda, 21. Mája 2008, 19:35
aj 1,3,6 mam :wink:
Streda, 18. Júna 2008, 10:35
Toto samozrejme nie je CARSOFT, ale PA Soft, co je myslim americka firma. Vazne pochybujem zeby to bolo lepsie ako CARSOFT. Americka firma ALPHA-BID ponuka na predaj komplet sadu aj CARSOFT aj PA SOFT a ked som sa ich spytal co z toho je lepsie, tak mi oznamili ze CARSOFT. PA SOFT sa jedneho casu dal bezproblemov stiahnut z ich ebay stranky, neviem ako je to teraz, poznam vsak jedneho dedka v DE co to ma, lebo mi s tym scanoval auto. Najvacsia sranda vsak bola, ze dal mi kody zavad ktore som doteraz nerozlustil, co znamenaju. Ak ma niekto nejaky zoznam, tak by som ho radi videl.....
Streda, 18. Júna 2008, 10:47
Este som zabudol, najnovsia verzia CARSOFT pre BMW sa vola CARSOFT BMW Ultimate Pro 1.0, zatial sa mi to nepodarilo nikde najst a ani dopatrat ceny, a to som emailoval priamo do CARSOFTU. Ten zvladne aj najnovsie BMW.
bedo
Registrovaný: 16.1.2008
Piatok, 20. Júna 2008, 08:42
Caute vsetci,
v prvom rade dakujem za super forum, nasavam tu informacie ako spongia;) Ok, k teme...uz aj u mna dozrel cas na kupu bmw, volba padla na 530d e39 r.v 2001+ lokalita nemecko, cena do cca 12.000E. Prave finisujem aukciu na ebayi na OBD2 kabel a chcem sa opytat, len pre istotu - je toto lokacia portu?
http://autocenter.weber.edu/OBD-CH/docu ... s/2000.jpg
http://autocenter.weber.edu/OBD-CH/docu ... 2000_2.jpg
..predpokladam, ze sa ten uzaver len chyti a potiahne smerom nadol (ziande sofistikovane zatlacit, pootocit, posunut a neviemco), je to tak?
Kedze nie som mechanik, chcel by som si zobrat NB a spravit diagnostiku, nez auto kupim, snad to vie odhalit nejake skryte chyby.
Vdaka za akekolvek rady;) a tipy - aj ohladom kupy, na co si dat pozor - samo, ze rady pred kupou v technickom okienku mam precitane:)
Bodka
Registrovaný: 28.4.2007
Auto: EX: E36 325TD
Štvrtok, 3. Júla 2008, 21:38
Neviem ci to tu uz niekde je, ale dnes som narazil na nejake softiky na nete : http://www.eobd2.da.ru/
jergy_zm
Registrovaný: 8.10.2007
Auto: Trabant
Štvrtok, 7. Augusta 2008, 14:43
skusal z vas niekto kabel s carsoft 6,5 na bmw e36 s motorom M43?
Suzuki Burgman 400
Volvo S70 LPG
Trabant 1.1 limo
ex:
BMW E36 ///M3 3.2i US limo
Lada Niva Tajga 1.6 4x4
Citroën Berlingo 1.9D
ARO 10.4
Škoda Felicia Combi VanPlus 1.9D
BMW E36 318i limo
Trabant 1.1 limo
Gilera Dakota 350 Enduro
Škoda M 120 L LPG
Trabant 601 limo
Simson S51 Enduro
Babetta 210
