Lipo69
Registrovaný: 30.9.2011
Re: bmw alu replica
Štvrtok, 6. Novembra 2014, 11:08
No ja by som v replikach spasu nevidel.
Jasne ze je lepsie dat polovicu ceny za novu sadu ako za origo z druhej ruky, ale oni nie su drahsie pre srandu.
A tie runflaty sa daju vymenit za obyc ci ?
F11 530 dx
Ex E60 530 xi fl
Ex E46 320 d fl
Rottwa
Registrovaný: 19.8.2010
Re: bmw alu replica
Štvrtok, 6. Novembra 2014, 11:12
Rottwa napísal:
miso_525d: Style 228, 252 a 301 maju problem od vyroby a su nachylne na praskanie. BMW to ako uz v minulosti kauza so Style 172 samiozrejme nechce pripustit a preplacat. V SŠA su pravidelne na sude:
http://gotaclassaction.com/bmw-named-in ... oy-wheels/
Uz aj oficialne stanovisko od BMW Germany hovori za seba. Nic preplacat nebudu a pripustili iba kozmeticke vady na materiale, ktore vraj nemaju vobec nic spolocne s praskanim a bezpecnostou ](*,) :
I understand that you would like BMW to consider the situation regarding our alloy wheels as you are concerned about the safety of affected vehicles. Investigations have been undertaken by BMW Germany into this matter and there is no evidence to suggest that this is the case. We have tested our alloys on many occasions and they have been found to conform to strict European guidelines regarding safety.
I acknowledge that you have undertaken some research into this matter which has led you to believe that this is a common issue with our vehicles, however, we do not believe this to be the case. As stated in my previous email I have checked our systems, utilising parts orders and failure reports and there is no evidence to suggest that this is a common or inherent fault.
BMW UK prides itself on utilising the highest quality materials for our products and the last batch of alloy wheels were rejected for cosmetic quality reasons and not due to safety. I am unable to advise you how many we currently have on back order, however, I can assure you that we are working hard ensure the shipment and delivery of the wheels to the UK and your dealer will contact you as soon as they arrive.
I appreciate you will remain dissatisfied with my response, however, I can assure you that our alloy wheels have been rigorously tested on many occasions and they are not found to breach health a safety guidelines.
futy
Registrovaný: 1.10.2009
Auto: C180w205
Re: bmw alu replica
Nedeľa, 9. Novembra 2014, 18:42
Nazdar chlapci, včera som natrafil pri umývaní letnej RunFl sady (kúpená s BMW) na prasklinu, treba to dať asi zavariť :-k , len mne sa ešte takéto nikdy nepodarilo ani ohnúť a jazdím 20r, tak kde to dať v ZA opraviť, prípadne ak to nie je vážne tak pojazdím. Inak bubliny žiadne vzorok pekne ojazdený. Zadky 6mm predky 7mm. Ďakujem..
BMW 523i F10- som bez vrtule
Audi A4B8 TFSi- sa minulo už
VW BORA 1,6 16V- ex
upir156
Registrovaný: 25.11.2012
Re: bmw alu replica
Nedeľa, 9. Novembra 2014, 20:33
Treba to dať zavariť.
miso_525d
Registrovaný: 20.8.2009
Auto: SOBI 20
Re: bmw alu replica
Utorok, 11. Novembra 2014, 09:23
ok ale ja som mal obute 19´ styling 235 Vielspeiche. tak zrejme aj tieto su naprd.
a pozeram ze styling 228 a 301 to su individual kolesa, inak kraaaasne, aj kamos ich na na F02. tych je skoda :|
Rottwa napísal:
madxface
Registrovaný: 13.1.2014
Auto: f34, e91
Re: bmw alu replica
Utorok, 11. Novembra 2014, 14:45
futy napísal:
V ziline Miroslav Czechowicz
Lietavská Lúčka
Žilinská cesta 51/26
01311 Žilina
Telefón:
0905795757
Odporucam ti tam ist osobne a dohodnut sa, teraz maju sezonu, tak telefon ani nezvihnu :D
