g1de0n
Registrovaný: 23.9.2011
Auto: E91 320D M47N2
3stage BFD - pomoc nakodovat
Utorok, 19. Januára 2016, 13:07
Ahojte,
kto mi pomoze nakodovat BFD na E91? (Brake Force Display)
Tu je moj TRC subor: http://www.upnito.sk/subor/04bc7d6ad4b4cf578fc4ca21372d6470.html
E91 preLCI. Moj modul FRM2-XE, kodovaci index C09.
Level 1: Regular day-to-day low deceleration braking
Level 2: Greater deceleration. Coded so rear fog lights illuminate.
Level 3: Emergency braking where ABS engages. Normal brake lights, rear fog lights illuminate and 3rd brake light blinking.
[youtube]Wo8t10nPMRY?t=5s[/youtube]
bizonik
Registrovaný: 16.6.2009
Auto: BMW E46 330ci
Re: 3stage BFD - pomoc nakodovat
Utorok, 19. Januára 2016, 14:11
tuto moznost som uz zacal obzerat aj ja. Nasiel som aj temu kde sa to uz rozoberalo https://www.bmwklub.sk/bmw3-e90-e91-e92 ... 97797.html , no zatial som sa k tomu nedostal. Ak to chapem spravne level1 je standard, level2 a 3 si vies dodatocne zapnut.
tu su mozne hodnoty pre BFD2, treba sa s tym pohrat a cez zimu sa to da aj lahsie otestovat :D podla tvojho vypisu mas BFD2 neaktivne, tam by som zacal :)
BFD2_AKTIV
* nicht_aktiv not active
aktiv active
BFD2_ESS_ENABLE
aktiv active
BFD2_ESS_ANZEIGE
aktiv active
BFD2_SL_BL_1
dauer_an
blinkend flashing
BFD2_SL_BL_2
dauer_an
blinkend flashing
BFD2_BFD
dauer_an
blinkend flashing
BFD2_BL_M
dauer_an
blinkend flashing
BFD2_NSL
dauer_an
blinkend flashing
BFD2_BL
dauer_an
blinkend flashing
BFD2_BLINKEN
* 3_hz
5_hz
BFD2_V_MIN
* wert_01 value 01
* wert_02 value 02
BFD2_A_MIN
* wert_01 value 01
wert_02 value 02
BFD2_A_LOE
wert_01 value 01
* wert_02 value 02
BFD2_T_ABS
* wert_01 value 01
wert_02 value 02
BMW E46 330ci
Toyota Auris Touring HSD
BMW E91 318D EX
BMW E39 530Da EX
BMW E46 320D Touring EX
Alfa Romeo 146 1.6TS EX
lionlion
Registrovaný: 24.9.2009
Auto: E90 325d
Utorok, 19. Januára 2016, 14:37
Chcelo by to presny navod.... ja som sa o to pokusal pred rokom a nepodarilo sa mi to zmenit podla mojich predstav, funguje to inak ako som chcel. A pritom som hladal kade-tade po zahranicnych forach aby som co najlepsie pochopil ktory riadok co robi. Asi najvacsi zadrhel je to ze nikto nema rovnaku verziu modulu, vzdy su tam nepatrne zmeny.
madxface
Registrovaný: 13.1.2014
Auto: f34, e91
Utorok, 19. Januára 2016, 15:53
klubak h@wky mi to nakodoval za par eur. skus sa s nim dohodnut http://www.bmwdiagnostika.wz.sk/
3 stage nemam ani ja otestovany, lebo vtedy musi zasiahnut ABS, tak cakam na sneh a dobre parkovisko :D
lionlion
Auto: E90 325d
Utorok, 19. Januára 2016, 17:26
Zopar drobnych by nebol problem, ale problem je ta dialka. Navyse je to vpodstate prkotina aby som sa s tym za niekym trepal, a pritom sam mam vsetko potrebne. Pravda je ze som sa s tym vobec nehral, skusil som to iba raz prekodovat, viac som nelaboroval. Vysledok je taky ze teraz mi to funguje iba dvostupnovo ak som to spravne odsledoval. Najpr svietia iba jedne brzdy v zadnom svetle, a pri prudsom uz svietia oboje brzdove ziarovky, inak vsetko po starom.
Ak by sa ktomu Hawky chcel vyjadrit, pripadne trosku poposunut tim spravnym smerom, nebolo by to na skodu :D
madxface
Auto: f34, e91
Utorok, 19. Januára 2016, 21:43
Tuto to dobre vidiet https://www.youtube.com/watch?v=VQ2DfNpdNPY
Pri druhom stadiu sa ti zapnu aj hmlovky. Tretie stadium dosiahnes jedine ak sa ti zapne ABS (aj na palubnej doske), co mne sa v lete nepodarilo, resp. skusal som to pri 50kmh slapnut na brzdu a nic :D S tym h@wkym som myslel, ze si to odtelefonujete/mailujete ked to uz polovice mas.
Streda, 20. Januára 2016, 08:05
Posli mi ho do mailu a upravim ti to a poslem spet.....
g1de0n napísal:
Ahojte,
g1de0n
Streda, 20. Januára 2016, 09:45
TT-SIMIK napísal:
:thumbup:
lionlion
Auto: E90 325d
Streda, 20. Januára 2016, 15:40
Nechcem sa vtierat TT-SIMIK, ale vedel by si aj mne helfnut? Mam zalohovane aj povodne nastavenie, stacilo by mi iba vediet co zmenit, resp. mozem to aj poslat.
Inac skusal som vseliako, aj jemne aj prudsie aj s ABS, vzdy som to rozbehol na 80-100 km/h, brat to s vonku sledoval.
