tusiak2
Registrovaný: 22.3.2015
"Roletka" v ladvinkach
Pondelok, 20. Apríla 2015, 19:46
Cavte mam 318d e91 2009. Je to moje prve bmw a mam ho ca.tyzden. Chcem uspokojit svoju zvedavost. Prosim vas za ladvinkami mam takuto roletku (vid.fotky). Zatial som ju videl len zavretu, rukou mi nesla otvorit, teda manualne to asi nepojde. Otvara sa cez nejaky motorcek, alebo naporom vetra, alebo ako ? Za vysvetlenie dakujem
BMW 318d E91 09 , N47D20U0
Chip od http://www.powermotion.sk 126kW 171Ps
FOTO http://www.imagehosting.cz/?v=image652.jpg
lionlion
Registrovaný: 24.9.2009
Auto: E90 325d
Re: "Roletka" v ladvinkach
Pondelok, 20. Apríla 2015, 20:27
Kym sa motor nezohreje a teda nepotrebuje este chladit tak bude zatvorena. Na otvaranie ma vlastny pohon, naporom vetra to neotvori. Otvara pri 100°C a zatvara pri 95°C (teplota chladiacej), ma to este aj dalse mozne poziadavky kedy ich otvara.... cely popis zde:
    Radiator shutter
    The DDE control module opens or closes the radiator blind depending on the operating range.
    The radiator shutter is opened at:
    •Coolant temperature > 100 °C (closes at < 95 °C)
    •Speed > 180 kph (closes at < 140 km/h)
    •Speed request for electric fan > 1600 rpm (closes at < 1380 rpm)
    •Speed request for electric fan by air conditioning system > 1600 rpm
    (closes at < 1050 rpm)
    •Winter safety function:
    •Window wipers ON and
    •Speed between 65 kph and 125 kph and
    •Ambient temperature between -8 °C and 2 °C
    •Electric fan after-run
    •With automatic transmission: transmission temperature > 115 °C (closes at < 110 °C)
    During trailer towing, the radiator blind is permanently opened if the trailer is connected to the trailer module.
    The winter safety function prevents the radiator blind from freezing shut while the vehicle is being driven in wet or snowy conditions.
Osobne by som bol za, kebyze to mam aj ja, aspon v zime by sa skor zohrial, ale bohuzial v pripade e90 to v ramci Dieslov maju iba 4-valce. Vo vypise vybavy sa to uvadza ako "CO2 Package"
tusiak2
Pondelok, 20. Apríla 2015, 21:00
Wow, ďakujem za vysvetlenie. Dá sa to aj na diagnostike odskúšať nejako, či to funguje ?
lionlion
Auto: E90 325d
Pondelok, 20. Apríla 2015, 21:08
Verim ze ano, urcite tam bude taka moznost. Ale malo by stacit ked zapnes klimu, ked bude teplejsie. Pisu tam, ze sa otvaraju aj vtedy, ked ventilator toci viac ako 1600 rpm. Auto ma iba jeden ventilator, a po zapnuti klimy sa vzdy spusti. Len preto pisem ze ked bude teplejsie, lebo neviem ci nahodou pri klime ten ventilator nebezi na dva rozne rychlosti, podla potreby.
tusiak2
Pondelok, 20. Apríla 2015, 21:15
Budeš mať podľa mňa pravdu lebo ja som sa pozeral na to aj keď bola klíma pustena ale mriežka bola zavreta. Bolo ale 16 st. Čo je málo ešte. No odsledujem to keď bude teplo.
madxface
Registrovaný: 13.1.2014
Auto: f34, e91
Utorok, 21. Apríla 2015, 08:39
Mne sa to nikdy nechcelo otvorit, dialnice som chodil standardne 160 priemerku, uz som si myslel ze je to pokazene. Minuly rok som daval taky vyjazd na Biokovo v CHR, 1762m prevysenie a prvy krat sa to otvorilo hore az som bol pysny :D
Mal som zapnutu klimu, bolo 30 stupnov vonku a este ten narocny vyjazd urobil svoje
salat
Registrovaný: 4.11.2010
Auto: BMW 320d E91 LCI
Utorok, 21. Apríla 2015, 08:43
este doplnim, ze LCI diesle uz mriezky nemaju, pokial viem tak len 320d "efficient dynamics" verzia, ta s obmedzenim vykonu. (opravte ma ak sa mylim, ale tak mi bolo povedane ked som kupoval auto)
Ani moja E91 LCI, 320d N47 r.v. 03/2011 uz mriezky nema.
BMW 320d E91
Seat Ibiza ST, 1,2TSI DSG
EX - Seat Leon II
tusiak2
Utorok, 21. Apríla 2015, 11:30
madxface napísal:
=D> gratulujem :D , dúfam že aj ja raz budem pyšný :lol:
Tomeo
Registrovaný: 20.2.2012
Auto: F11 530xd
Streda, 22. Apríla 2015, 22:03
Ja to mam na 320d lci. Je to kravina. Mam to odpojene a trvalo otvorene aj v zime. V lete som s tym isiel do IT po dialnici 140, vonku 34 stupnov a tie blbe klapky sa vkuse otvarali a zatvarali. Teplota kvapaliny lietala od 89 - 105° dookola. To asi motoru neprospieva, tak som to nechal odpojit.
Okrem toho mi to uz raz menili, udajne boli chybne, ale co ja viem ci autorizak len nechcel zarobit ked som to dal skontrolovat
F11 530xD - Príbeh
Black-On-GraphiteGrey
tusiak2
Štvrtok, 23. Apríla 2015, 06:54
Tomeo napísal:
ako ja som prekvapeny ze sa to otvara az pritakychto podmienkach... [-( Na zimu to je super, len cez to leto.. Nwm, ako hovoris, ak sa to bude stale otvarat/zatvarat.. No uvidim aj ja, hlavne to musim este k niekomu dat na diag. aby som zistil, ci to mam funkcne. No a do skryteho menu sa neviem dostat v pal.pc..nenabehne mi tam 5miestne cislo, ktore sa musi spocitat.. navodov tu je vela, ale nejako mi to nejde. Lebo inak teplotu chladiacej nezistim... ](*,)
madxface
Auto: f34, e91
Štvrtok, 23. Apríla 2015, 07:02
tusiak2 napísal:
...No a do skryteho menu sa neviem dostat v pal.pc..nenabehne mi tam 5miestne cislo, ktore sa musi spocitat.. navodov tu je vela, ale nejako mi to nejde. Lebo inak teplotu chladiacej nezistim... ](*,)
1. drzis nulovanie km cca 10s kym ti nenaskoci obrazovka s cislicami
2. stlacas ten gombik na nulovanie az kym neprides na polozku 19
3. tam zadas sucet poslednych 5-tich cisel VIN-ka tym sa ti to menu odomkne (ja mam 9+2+7+9+0= 27)
4. zasa stlacas ten gombik na nulovanie a prides na polozku 7 - teplota motora...
tusiak2
Štvrtok, 23. Apríla 2015, 08:00
madxface napísal:
pisem ti ss, lebo to bude uz Od temy tu riesit.
peter9898
Registrovaný: 9.12.2012
Auto: BMW 530xd f10 2016
Streda, 2. Decembra 2015, 23:09
lionlion napísal:
    Radiator shutter
Funguje too tak aj pre e60-tky s mriezkou?
Mozno pomimo. Pri akej teplote chladiacej kvapaliny resp motora sa spusta ten ventilator radiatora ?
Dikes
BMW 530d xDrive F10 A/T, r. v.: 2016, LCI
ex BMW 530d (e60) A/T, r. v.: 2007, LCI
