Baworo
Registrovaný: 24.11.2010
Auto: e46 320d
PLS DELETE TEMA - servisny interval - delete
Piatok, 19. Októbra 2012, 11:00
cauko all...
Caka ma vymena oleja a neviem zmazat servisny interval koli tomu ze ked som daval tacho kruzky tak sa mi podarilo cudlik trosku odlomit takze neviem ho teraz resetnut...stale som ho resetoval cez budiky a slo to pekne...teraz ten cudlik mam zlomeni tak ho neviem resetnut...vie mi niekto pomoct alebo dat navod ako to resetnut.?. lebo som v minuse asi 22 000 :oops: olej menim pravidelne este 4000km pred servisnym intervalom..
Ide o 320d e46 2003...
Alebo nema niekto na predaj taky pristoj ktory resetne SI.?.
vopred za odpovede dakujem :thumbup:
Naposledy upravil/-a Baworo v Sobota, 20. Októbra 2012, 10:37, upravené celkom 1 krát.
j.matrix
Registrovaný: 31.1.2012
Auto: BMW 320d E46
Re: servisny interval - delete
Piatok, 19. Októbra 2012, 11:22
na FL by sa to malo dat bez pristroja a spajania drotikov 8)
1. Ignition key to position 0 (off)
2. Hold trip meter button (the left button)
3. Ignition key to position 1. The display will show: "test 1"
4. Keep holding the trip meter button until the the display shows: "reset inspection" or "reset oilservice"
5. Release the button
6. Press and release the tip meter buton once. The Display will show the square clock symbol and the month the fluid change is overdue on. I can't remember if the date format was mm.yy or yy.mm
7. Press and hold the trip meter button until the display is showing a flashing "reset". Then release the button. "Reset" will keep flashing.
8. Presss and release the trip meter button once. The display will show the square clock symbol and the month for the next fluid change in 2 years time in the format mm.yy or yy.mm
9. Press and hold the trip meter until "End" is displayed
10. Let go of the button and turn ignition to 0 (off). The clock symbol will not show again until the next fluid chnage is due
11. Record the the completed service in the service book and put your own stamp on it if you are proud.
12. Renew you own fluids with your most preferred beverage. Then pat yourself on the back for a job well done knowing that the drink was for free, that for once you had a brake fluid job that you could trust, and that the dealer monkeys did not get a chance to break your car.
eko.fresh
Registrovaný: 2.3.2008
Auto: bmw
Piatok, 19. Októbra 2012, 12:37
Vsak ale pise ze to robil vzdy cez budiky. 8)
Treba najst ochotny servis kde ti to resetnu zadarmo, napr. BMW :mrgreen:
Alebo z ebayu kupit tu somarinku na OBDII reset
Baworo
Auto: e46 320d
Piatok, 19. Októbra 2012, 12:38
j.matrix:::presne podla takehoto navodu som fungoval doteraz ale ten "trip meter" tlacidlo mam zlomene a nereaguje vobec...potrebujem iny sposob alebo ten pristroj na reset intervalu... :thumbup:
eko.fresh::: nice vtip :lol: ze v bmw mi to resetnu zadara :lol: presne tu somarinku potrebujem ale eBay moc nemusim a ani ho nepouzivam :-k niekto to raz predaval ale neviem kto #-o
Mikidolar
Registrovaný: 27.6.2011
Auto: Bmw F31 318d
Piatok, 19. Októbra 2012, 13:10
Niekde tu na fore bol navod ako to resetnut drôtikom priamo na obd2 zasuvke..
(neviem to teraz najst narychlo) skus pohladat
BMW F31 Touring 318d
EX: BMW E46 Touring 330d
eko.fresh
Auto: bmw
Piatok, 19. Októbra 2012, 13:35
OBD2 drotikom neresetnes, uz nema SI pin. ako OBD1
A neviem ani kto by sa o to pokusal, kedze to resetnes cez budiky pohodlne
Mi_t_is
Registrovaný: 2.5.2010
Auto: BMW E36 325iA
Piatok, 19. Októbra 2012, 13:40
OBD1 sa da drotikom a nedá cez budiky
OBD2 sa nedá drotikom a dá cez budiky
OBD1 aj OBD2 sa dá resetnuť cez tie nastroje ktoré mám v podpise ;)
Na predaj:
Kontakt
j.matrix
Auto: BMW 320d E46
Sobota, 20. Októbra 2012, 07:08
nejako som to tam prehliadol, prepacte :lol:
Baworo
Auto: e46 320d
Re: servisny interval - PLS delete temu
ok zasuvka objednana od Mi_t_is takze problem vyrieseni :) dik chlapci :)
PLS DELETE
