Cerberro
Registrovaný: 22.5.2008
Auto: E46 325Ci
[E46 325Ci] Cerberro`s
Sobota, 24. Apríla 2010, 15:24
Takze po dlhej dobe som sa konecne dostal k tomu, aby som sem pridal aj ja svojho tatosa ;-) Je to dovoz z DE, ale kupoval som to uz na SK znackach. Pri kupe malo za sebou cca 160.000km, dnes uz nieco cez 192.000km. Kazdopadne som s autom zatial spokojny, jazdne vlastnosti su velmi dobre, obzvlast potom ako som vymenil prakticky cely podvozok. Spotreba po meste tak 10-11l, mimo mesta a na dlhsie vzdialenosti sa da dostat aj pod 8l. Ocenujem automat, najma pre jeho pohodlie. Ma to aj moznost akehosi sekvencneho resp. manualneho radenia, ale priznam sa ze to vyuzivam skutocne len minimalne. P.S.: Hamann nema s autom spolocne nic okrem nalepky na blatnikoch, boli na aute uz ked som ho kupil a kedze som si na ne celkom zvykol zrejme tam aj zostanu.
E46 325Ci
r.v. 2000, prve prihlasenie: 2001
motor: M54, 141kw (192hp)
farba: Orientblau metallic (317)
interier: Standardleder/Schwarz (N6SW)
Order options:
205 automatic transmission
225 sport suspension settings, deletion
249 multi-function for steering Wheel
279 lt/aly wheels star spoke 45
320 model designation, deletion
423 floor mats, velour
428 warning triangle
434 interior trim
459 seat adjustm., electr. w. memory
473 armrest, front
481 sport seats f driver/front passenger
488 lumbar support driver/front passenger
494 seat heating f driver/front passenger
502 headlight washer system
508 park distance control (pdc)
522 xenon light
534 automatic air conditioning
662 radio bmw business cd
801 germany version
863 europe/dealer directory
879 german/owners handbook/service booklet
Series options:
255 sports leather steering Wheel
520 foglights
548 speedometer with kilometer reading
550 on-board computer
882 battery in luggage compartment
851 language version germany
+ auto malo pri kupe na moje potreby celkom postacujucu audio vybavu:
radio ALPINE CDA-9851, zosik XETEC VECTOR V 350.6, subwoofer XETEC XIRCUIT X-8 S, repro vzadu HERTZ, vpredu som nezistoval...
Auto som kupil na jesen 2008, pricom odvtedy prebehlo par oprav(uprav):
Letne gumy FALKEN FK 452 – 225/40 ZR18 92Y (predok) a 255/35 ZR18 94Y (zadok) + podlozky vpredu aj vzadu boli uz pri kupe 8)
Vymenene naplne + filtre (motor, automat, diferencial, servo, brzdovka)
Vymenene odvetravanie klukovej skrine, senzor vyfukovej vacky, spodne koleno sania
Vymenene tesnenie po vekom + 6x sviecky NGK BKR6EQUP
Vymenene tesnenia vanosu – BEISAN SYSTEMS
Komplet GO podvozku (pruziny EIBACH PRO KIT, tlmice BILSTEIN B4, ulozenia, manzety a dorazy, tycky a gumy stabilizatorov, vsetky predne a zadne silentbloky, komplet P a Z kotuce + platnicky (MEYLE) + geometria
Vycistenie a naolejovanie KN vzduchoveho filtra (vlozka)
+ v najbližšej dobe je na pláne:
Vymena relatiek centralu
Mensia preventivna GO chladiaceho systemu (vodna pumpa, termostat, remene, kladky + napinak atd.)
Opravna sada na kozu (osuchany bok vodicovej sedacky, hlavica paky, mozno aj volant)
a este zopar foto:
Naposledy upravil/-a MT-SPEEDY v Streda, 28. Apríla 2010, 12:36, upravené celkom 1 krát.
herri13
Registrovaný: 4.2.2009
Auto: BMW E39 528i sedan
Re: Cerberro`s E46 325Ci
Sobota, 24. Apríla 2010, 16:59
=D> =D> =D> pekneeeeee, konecne si pridal pribeh, uz by si sa mohol aj ukazat na kavicke. Zajtra mame vylet do BS, nepridas sa ?
Stefo1248
Registrovaný: 8.2.2009
Auto: paraolimpiada
Sobota, 24. Apríla 2010, 17:15
=D> krasne autíčko, prid ho ukázat zajtra naživo :)
Audi TT Quattro 260ps
Ex:E39 530ia lpg
Ex:E46 328 ci lpg
Ex:Bmw R1150R
Ex:E46 320D 200ps
herri13
Nedeľa, 25. Apríla 2010, 19:42
Z dnesneho vyletiku \:D/
Cerbero 1.JPG (75.55 KiB) 2343 zobrazení
Cerbero 2.JPG (87.37 KiB) 2343 zobrazení
Cerberro
Auto: E46 325Ci
Re: [E46 325Ci] Cerberro`s
Nedeľa, 23. Mája 2010, 16:12
takze auticko preslo planovanou mensou GO chladiaceho systemu: vymenene oba spanovaky, oba remene, nastavovacia kladka, vodna pumpa + remenica, termostat + chladiaca zmes.
zabil som s tym tak pol dna, kedze som to robil prvykrat, ale o to vacsia spokojnost kedze sa mi vsetko podarilo tak ako som chcel... vodnu pumpu a termostat som sa rozhodol vymenit len preventivne - este by boli nejaky cas vydrzali, remene mozno tiez, no ale kladka a oba spanovaky boli KO, takze najvyssi cas vymenit... po vymene sa konecne po nastartovani neozyvaju spod kapoty rozne pazvuky ;-)
no a dnes som si konene nasiel cas na vymenu zamku spolujazdcovych dveri.. mal som problem s centralom, povodne som tipoval ze su to relatka, ale po ich vymene sa problem odstranil len ciastocne.. teraz po vymene zamku vsetko konecne opat odomyka a zamyka tak ako ma 8)
eko.fresh
Registrovaný: 2.3.2008
Auto: bmw
Pondelok, 24. Mája 2010, 09:51
parada, treba sa starat. Nejake fotky z vymeny sem hod ak mas 8)
Cerberro
Auto: E46 325Ci
Pondelok, 24. Mája 2010, 17:04
eko.fresh napísal:
fotky zial nemam.. povodne som aj mal v umysle spravit par obrazkov, ale pocas opravy som na to akosi pozabudol ;-) navyse zayebane ruky a fotak, to velmi nejde dokopy :lol:
Martin46
Registrovaný: 28.6.2007
Auto: BMW 130i +Quaife
Pondelok, 24. Mája 2010, 18:51
od lukasa si mozu vsetci brat priklad ako ma vyzerat starostlivost o auto... !!!
Cerberro
Auto: E46 325Ci
Štvrtok, 5. Augusta 2010, 08:10
taaaakze auticko dostalo novy olej + filter :smile:
Cerberro
Auto: E46 325Ci
Štvrtok, 5. Augusta 2010, 08:26
a prakticky v rovnakom case odisla servo pumpa :evil: takze nastal cas na vymenu.. plus samozrejme novy olej do serva... vymenu som zvladol svojpomocne, bez akychkolvek komplikacii ci problemov...no a ako uz tradicne, podakovanie patri Martinovi za rychle a bezproblemove dodanie potrebneho materialu + priaznivu cenu =D>
pre porovnanie - stara pumpa LUK LF-20
Užívatelia prezerajúci toto fórum: ALAS a 100 neregistrovaných
