Johnny_R6
Registrovaný: 1.12.2010
Auto: E38 728iA, X5 E53 V8
Adaptive brake lights - BMW E39
Nedeľa, 14. Apríla 2013, 15:26
Ahojte,
Všimol som si že na novších modeloch pri núdzovom berdení brzdové svetlá blikajú, dá sa také niečo nastaviť na E39 Tour ? Rok 6/2000 čiže predlift
Za každú radu budem vdačný
Pokial nemáš pre BMW srdce , je to pre teba len obyčajné auto ;-)
_________________
E38 728iA "Derrick"
E53 X5 4.4i "Američanka"
EX E53 X5 30d "Mahagoni"
EX E53 X5
EX E39 525dT "VermontGreen"
EX E46 320dTA 2001
Re: Adaptive brake lights - BMW E39
Nedeľa, 14. Apríla 2013, 16:20
Nie.
Johnny_R6
Nedeľa, 14. Apríla 2013, 17:10
A nevieš či by sa to dalo dorobiť ? Mám na mysli nejaky kit alebo niečo podobné.
_________________
E38 728iA "Derrick"
EX E53 X5
EX E46 320dTA 2001
fafa111
Registrovaný: 2.5.2011
Auto: E36 320i coupe
Nedeľa, 14. Apríla 2013, 19:34
Da sa to kupit v eshopoch. Pohladaj, pogoogli a budeš blikat.
matomendoza
Registrovaný: 12.4.2008
Auto: e39,e38
Utorok, 25. Júna 2013, 10:16
hej bolo to v eshopoch
mam to aj doma ale dako to nepasovalo na e39/1997 a ani na e38/2001 ](*,)
len to prerobit
ale ohladom toho kodovania by to bolo ciste riesenie :thumbup:
tu je daco co som nasiel
Here are some options that can be coded on an e39:
- Auto lock after 2 minutes if no doors opened
- Autolock if you drive over X km/h, a few values for X
- Selective unlocking (only unlocks driver's door on first unlock)
- Alarm chirps once on lock, twice on unlock, individually programable
- Indicators flash once on lock, twice on lock, individually programmable
- Seat belt chime remove
- Key in ignition chime remove
- Seat belt warning remove
- Autofold mirrors by pressing & holding remote lock (only with electrically folding mirrors)
- Brake Force Display (where 3rd brake light flashes in an emergency braking situation)
- Auto dip passenger mirror (only with memory seats)
- Memory key for heating settings (car remembers heating settings for different keys)
- Memory key for radio settings (car remembers radio settings for different keys)
- Auto lights light intensity adjustment
- Daylight running lights enable
- US Sidemarkers enable
- Electric window working/not working when door opens
- Disable/Enable comfort closing/opening of windows with remote key
ale osobne som to neskusal(dako bojim,bojim)
su tu kodovaci-machri ti by skor povedali
a tu cely
http://forum.bmw5.co.uk/topic/75415-coding-options/
alebo
http://e46.bmwklub.cz/viewtopic.php?f=17&t=20401
ale len e46(od 03/2003)
b m w e 38 735 i A individual
geboren in Dilgolfing am 24.04.2001
Gewicht:1925 kg/Länge:4984 mm
b m w e 39 525 t d s
geboren in Dingolfing am 6.11.1997
Gewicht:1655 kg/Länge:4805 mm
vw passat 2.8 v6 synchro excrash
matomendoza
Auto: e39,e38
Utorok, 25. Júna 2013, 12:41
dalsia zaujimavost
ak treba prelozit poslite ss(pm)
apropo sa mi zda ze to iste robi aj tt-simik s TT
na tom videu je to zle vidiet ale zda sa ze tie brzdy blikaju(e39) :shock: (oci bolá)
len popise to nieje napisané
http://cds-fink.de/coding.htm
matomendoza
Auto: e39,e38
Utorok, 25. Júna 2013, 14:44
teoreticky by toto pomohlo
http://www.youtube.com/watch?v=c5qSB28s ... r_embedded
lebo sa to da programovat ako potrebujes
je viacej verzi podla toho co clovek chce a kolko dotoho vrazi
ovlada to vsetky ziarovky(led) na aute jednotlivo a najvyssi model
ma funkcie:
eLight ultimate Modul
- denne svietenie cez hmlovky
- denne svietenie cez parkovacky,alebo cez AE ak su namontovane
- trojblik smerovky
- senzorom ovladane Coming-Home-osvetlenie (Wayfinder) ktore pri tme zapne svetlá(aby ste nepadli na hubu v noci :mrgreen: ).
- zaistenie dveri pri rozbehu,odistenie pri vypnuti motora
- odbocovacie svetla cez hmlovky,pouzitie lava/prava strana do 60 km/h
- automaticke zavretie a otvorenie spatakov pokial su elektricke
montaz treba zapojit 3 kable(+,- a i-bus)
obsah dodavky
eLight-Modul, potrebne kable, Wayfinderkabel so senzorom, datovy kabel Serialport, Software-CD, obrazkovy navod \:D/
kedze to ovlada jednotlive svetla a moze to aj blikat,tak vychadzam stoho ze to bude pouzitelne aj na "BFD",aby brzdy blikali
ale to chce vyskusat
http://www.car-solution.de/de/component ... l?Itemid=0
a maju aj pre ine modely od bmw
Utorok, 25. Júna 2013, 15:11
:thumbup: :thumbup: :thumbup:
matomendoza napísal:
dalsia zaujimavost
matomendoza
Auto: e39,e38
Utorok, 25. Júna 2013, 15:52
to tt-simik:nemas zac
ale klamal som?
to others:
podstate sa to da nakodovat ked mas novsi LCM,ale asi toto vsetko nie?
j.matrix
Registrovaný: 31.1.2012
Auto: BMW 320d E46
Utorok, 25. Júna 2013, 16:12
vsetko nie, pre vacsinu veci z toho zoznamu profor vyrabal vlastne plosaky :mrgreen:
matomendoza
Auto: e39,e38
Utorok, 25. Júna 2013, 16:34
to hej
cital som to
profor to riesil aj montoval
ale toto je vcelku
ziadna odborna montaz(aj pre lavorukych)
obsluhujeto viacej obvodov
a netreba menit LCM aby sa dali veci kodovat
tym padom je to vhodnejsie pre tych co maju starsie modeli
ale chcel by som vidiet to nastavenie ci je to "trottelfest"
a myslim ze cenou sa dostaneme este vysie ked sa meni aj LCM a ine veci
a urcite by som si to nedal aby som mohol robit vianocny stromcek dakde na pumpe [-(
ale kvoli inym veciam
revenge
Registrovaný: 14.2.2011
Utorok, 25. Júna 2013, 19:56
Dal by som si to jedine koli dennemu svieteniu a to uz mam,neviem si predstavit niekde pustit to blikanie sak by som sa citil ako uplny keket...
matomendoza
Auto: e39,e38
Streda, 26. Júna 2013, 10:00
je to trapne ani by som to nedaval kvoli tomu
aj ja mam denne svietenie dorobena na oboch bmw
chvalabohu ze to nerobia na VW a Skoda [-o<
ale ten trojblik a zapinanie hmloviek ked odbacas
to vyzera dobre :thumbup:
ale ako bol nazov temy ze sa hlada riesenia aby blikali brzdy pri brzdeny na starsich modeloch
by trebalo vyskusat
jaj uz to len objednat
a mimo nemci si to chvalia,ze nestupla spotreba ziaroviek :mrgreen:
serwo
Registrovaný: 15.7.2009
Auto: E39 528iA
Utorok, 23. Júla 2013, 22:32
Ten eLight mam uz davno. Funkciu vystrazneho brzdenia to nevie.
EX - BMW E39 528iA
EX - BMW E66 745Li, '03
EX - BMW E30 324d, '87
