buboja
Registrovaný: 9.6.2013
Auto: E53 3d.
PANORAMATICKA STRECHA
Nedeľa, 23. Marca 2014, 18:51
AHOJTE NA ZACIATOK BY SOM LEN DODAL ZE PANORAMATICKA STRECHA U BMW BY MALA BYT KAZDA ROVNAKA A PROBLEMY SA UKAZUJU TAKTIEZ VSETKY STEJNE NA KOLKO SA ZDA ZJAVNE ZE PROBLEM JE VZDY TEN ISTÝ.
AKO UZ ASI KAZDY VIETE ZE PANORAMATICKA MA DVE ZAKLADNE FUNKCIE :
1: VETRANIE -KDE SA POOTVORIA OBE KRIDLA PRVE VELKE A HNED ZAROVEN AJ DRUHE MALE KRYDLO NA VETRACKU A TO VTEDY KED STLACITE TLACITKO SMEROM DNU ,VTEDY DOCHADZA K NADMERNEMU OPOTREBENIU PLASTOVEJ SUCIASTKE KTORA SA CASOM OSLABÍ A PRASKNE KDE UŽ OKNO SA POTOM NEDA SPET SKLOPIT. ABY SME PREDISLI DALSIM PROBLEMOM JE POTREBNE ODKLOPIT PREDNY KRIT AKO SU ZVICAJNE MALICKE MRIEZKY NA MIKROFON V TOM PANELI AKO JE TO TLACITKO NA STRESNE OKNO A POD TY KRYTOM JE DIERKA V PRIEMERE ASI 10mm DO KTOREJ VLOZITE 4 INBUSOVY KLUC A RUCNE ZATVORITE ZTRESNE OKNO . POTOM TREBA ODSTRANIT PERO S PEROVEJ OCELE (DROTIK ) A VYTIEHNUT ZARAZKU ABY STRESNE PRI OTVARANI VETRACKY NEOTVARALO ZADNU CAST STRESNEHO OKNA A VSETKO BUDE FUNGOVAT AKO PREDTYM . VYDEO PRILOZENE .
1.1 TU AK POTIAHNETE VYPINAC SMEROM DOPREDU TAK SA TA TAPACIRUM SAMO ZATVORY A NECHA MEDZERU V POLOVICKE NAKOLKO VETRACKA JE DALEJ OTVORENA A V TAPACIRU JE TAKTIEZ OTVORENY TEN STRED . 1.2
PO DOTLACENY VYPINACA DO PREDU SA ZASE VETRACKA ZATVORI A TAPACIRUM SA DOVRIE .TAK JE PANORAMA CELA ZATVORENA
2: PANORAMATICKE OKNO SA ODSUVA SMEROM DOZADU A ODSUVA SA LEN TA VECSIA CAST OKNA NA DVAKRAT PRVIKRAT.
1 .POTIAHNUTIE PREPINACA SMEROM DOZADU SA ODSUNIE TAPACIR CELY SA ODKRIJE .
2. POTIAHNUTIE ZNOVU DO ZADU PREPINAC PO ODTIAHNUTI TAPACIRA SA ZACNE ODTAHOVAT STRESNE OKNO NA PRVU VLNU CCA 35cm.
3. AK SA OKNO DOTIAHNE ZNOVU ZATIAHNEME VYPINAC A OKNO SA ODSUNIE POD TU KRATKU CAST CELE TO JE VSETKO .
https://www.youtube.com/watch?v=MLg3yR8Z2PE" onclick="window.open(this.href);return false;
https://www.youtube.com/watch?v=wXpDcy8C56Y" onclick="window.open(this.href);return false;
taktiez je tam kativacia panorami aby sa aktivovala ak sa sama deaktivovala to jest v kratkosti rucne dovriet cele stresne okno pomocov toho inbusoveho kluca 4 a potom treba zatvorit vsetky dvere zapnut zapalovanie a stlacit a dlho drzat vypinac okno sa zacne samo otvarat a zatvarat zacina vetrackov konci zatiahnutim tapacira trva to asi cca 2minutky cely cas to treba drzat vkuse a cely proces skoncisam tak ze uz sa nic nebude diat . ak by sa nahodov stresne okno neda niako zatvorit elektricky a zacne sa samo pri stlaceni otvarat a hned zatvarat alebo opeacne tak mu pomozte pri zatvarani pritlaceni rukov ono to funguje ak ma vecsiu zataz alebo teda nejaku prekazku tak sa sam vrati do povodnej polohy blisie info poskitnem na telefon .ak ma niekto zaujem taktiez
panoramaticke okno ma dva motorceky jeden je na odtah okna a druhy je na odtah tapacira a zaroven aj sietky proti hmyzu .co vyskakuje ak sa okno otvara do druhej polohy .
0915897
Naposledy upravil/-a buboja v Štvrtok, 1. Augusta 2024, 07:27, upravené celkom 5 krát.
ja a ona E53 260PS 0915897103
Darkness
Registrovaný: 25.7.2011
Auto: X5 3.0D
Re: PANORAMATICKA STRECHA
Pondelok, 24. Marca 2014, 21:55
opravuje to niekto, tak aby to fungovalo ako ma????
EX e-46 330xi
pribeh
post1064004.html#p1064004
buboja
Auto: E53 3d.
Utorok, 25. Marca 2014, 12:09
Darkness napísal:
No je s tým problém jedine BMW originál ja som si to robil sám možem sa nato pozriet no práca je dosť pracnaa zdĺhavé na zopár hodín alebo aj jednu hodinku záleží od rozsahu poruchy čo máš . Ale všetko sa dá
matis357
Registrovaný: 26.9.2012
Auto: BMW X3 2.0 xDrive
Utorok, 25. Marca 2014, 19:22
Ja som to zvladol doma na dvore,staci postupovat podla videa cislo dva,vylamat tie plasty ako ukazuje,pozor nestaci vybrat len pierko
M47/T2 - 2,00l (110kW)
WE10193
Rishox
Registrovaný: 24.8.2013
Auto: BMW X5 E53
Nedeľa, 1. Júna 2014, 17:14
poznam tipka co mi to robil.ja som menil komplet vsetky tiahla co su po stranach co vyslo 400e.robota na cely den od 8 do 20.len aby sa vedelo.
Driver67
Registrovaný: 10.5.2010
Auto: E53 2.0iS (iks5)
Utorok, 10. Júna 2014, 00:08
Toto video si mal pridať, kde ukazuje ako to opravil :D
Inak díky za príspevok, pojdem tú kurvu aj ja vytuzingovať (pôjdem opraviť moju strechu)
Chcem uz konecne auto, do ktoreho sa leje servo olej a nemat namiesto svetlometov lampy na petrolej
Darkness
Auto: X5 3.0D
Nedeľa, 6. Júla 2014, 21:54
po novom mi to nezatahuje plato vzdy sa vrati dozadu a ked okno chcem otvorit tak v 3/4 sa zasekne a zacne vracat spat ... vsimol som si ze to pokrci tu gumu co tam je na tej liste a ani mi tam poriadne nesedi :D
EX e-46 330xi
pribeh
buboja
Auto: E53 3d.
Pondelok, 7. Júla 2014, 06:29
Darkness napísal:
Gumu?
No celé okno je na princípe zatazitelnosti to zna že ak sa ti tam niečo skrizilo tak preto sa ti to vracia skús mu troskuviacej pomôcť rukou ci sa bude otvárať .ak nie treba ho vycentrovat po krajoch sú torxove skrutky 3a3 na lište dosť blbi prístup zo srubovakom a ked ti potom aj tak nebude zatahovat plátno tak treba vzadu rozobrat motorcek a nastaviť to
IwkowiczL
Registrovaný: 30.11.2010
Auto: Bmw 330i Touring M
Pondelok, 7. Júla 2014, 18:52
ahoj, ja si myslel, ze me to neceka, ale take ano. neco v tom patrne prdlo a nejde z polohy ventilace zadelat, to se mi podarilo podle videa, ale chci to opravit, co jsem se tak koukal, tak jsou nejake popraskane ty plasty na tom zeleze co je namontovane na skle. poloha uplneho otevreni funguje, ale prijde mi, jako by cast velkeho okna byla trochu volna, je to mozne? pokud tomu nekdo rozumi, tak mi prosim hodte cisla dilu diky.
buboja
Auto: E53 3d.
Pondelok, 7. Júla 2014, 19:04
Nápis číslo telefón do spraví
jakub2712
Registrovaný: 21.9.2014
Auto: bmw 335d coupe
Sobota, 9. Júla 2016, 16:37
Nazdar viete niekto poradiť ? Tiež som mal problém so strechou zavrel som ju rucne torxom na motorceku a odvtedy mi strešný tapacir nechce úplne zasunúť, vždy ostane cca 5 cm pootvorený. Jedná sa o BMW e70 Diky
buboja
Auto: E53 3d.
Sobota, 9. Júla 2016, 18:43
Treba nastavit tapacir mitorcek
jakub2712
Sobota, 9. Júla 2016, 18:47
A vieš mi prosimta povedať kde nájdem ten motorcek ?
buboja
Auto: E53 3d.
Sobota, 9. Júla 2016, 20:29
Vzadu v kufri
jakub2712
Sobota, 9. Júla 2016, 20:57
Diky, zajtra to pozrem dúfam ze ho nájdem
Užívatelia prezerajúci toto fórum: Žiadny pripojení užívatelia a 68 neregistrovaných
