SmartBastard
Registrovaný: 5.5.2011
Auto: '08 M Coupe, '10 X6
BMW recalling 241,000 3 Series models over faulty taillights
Piatok, 2. Septembra 2011, 12:18
http://www.autoblog.com/2011/09/01/bmw- ... il-lights/
BMW is recalling 241,000 3 Series models for potentially faulty rear lamps. According to NHTSA, certain 2002-2005 325i, 325xi, 330i and 330xi models built between September 1, 2001 and March 1 2005 may experience increased resistance at the electrical contacts. This resistance may eventually lead to the failure of tail light, brake light or turning indicator lamps over time. That failure could impede a driver's ability to warn other motorists of his or her intentions, potentially leading to an accident.
Bastard's Video Collection
www.RoyalGarage.sk
SmartBastard
Re: BMW recalling 241,000 3 Series models over faulty tailli
Piatok, 2. Septembra 2011, 12:39
A este jeden recall:
BMW recalling 2,120 diesel X5 models
BMW is recalling the 2009 X5 xDrive35d due to a problem with the vehicle's diesel fuel pre-heater, the issue being that it's not working as it should, and it could experience an electrical overload that would put it in a permanent "on" state.
http://www.autoblog.com/2011/08/31/bmw- ... x5-models/
www.RoyalGarage.sk
lovebmw
Registrovaný: 9.6.2009
Piatok, 2. Septembra 2011, 20:21
aaa ešte jeden Recall :D
120,000 vehicles BMW 1,5,7,X3,X5,X6
http://www.bmwblog.com/2011/09/02/fault ... -vehicles/
TiTAN
Administrátor
Registrovaný: 1.8.2006
Auto: BMW 530d xDrive
Piatok, 2. Septembra 2011, 20:26
jj uz sme boli s nasou e90 3er nadherne nam zlicovali po tejto vymene svetla v ZA :D dakedy pridam foto, spravili s toho nadhernu buracku :D proste pri predaji kazdy povie ze to bolo na zadok burane :D
caliopcar
Registrovaný: 10.8.2009
Auto: BMW E 46 316i
Piatok, 2. Septembra 2011, 21:08
TiTAN napísal:
A mohol by si prosím ťa napísať ako sa tá závada prejavovala?? Lebo aj ja spadám do tej škály rokov v ktorých sa to stalo aj keď nie modelom, ale zadné svetlá mi nejako blbnú. Ďakujem.
TiTAN
Administrátor
Utorok, 6. Septembra 2011, 18:46
caliopcar napísal:
nijak, nebol snimi absolutne ziadny problem, proste len zvolali vsetky vozidla kvoli vymene, malo tonejaky suvis s konektorom, ale tie svetla svietia presne tak isto ako predtym :)
Užívatelia prezerajúci toto fórum: Bing [Bot] a 39 neregistrovaných
