Moderátori: alfi666, fox1k
Ederon
Registrovaný: 6.9.2008
BMW TIS 12/2007
Štvrtok, 4. Decembra 2008, 11:51
BMW TIS verzia z 12/2007 na stiahnutie. Diely, navody, servisne instrukcie atd. pre vsetky modely BMW do toho datumu.
http://rapidlibrary.com/index.php?q=bmw+tis&filetype=0
Rudkoo
Registrovaný: 2.2.2007
Štvrtok, 4. Decembra 2008, 12:02
nem funguje, :twisted:
Ederon
Štvrtok, 4. Decembra 2008, 12:37
Musi byt momentalny vypadok, ked som to tu postoval to este islo. Asi nejaky server maintenance. Treba skusit neskor.
EDIT: Uz to fici
ice.blade
Registrovaný: 14.7.2008
Štvrtok, 4. Decembra 2008, 19:02
ja len doplnim linky priamo na rapid
http://rapidshare.com/files/107371195/BMW_TIS_12_2007_English.part01.rar
http://rapidshare.com/files/107372089/BMW_TIS_12_2007_English.part02.rar
http://rapidshare.com/files/107373010/BMW_TIS_12_2007_English.part03.rar
http://rapidshare.com/files/107373994/BMW_TIS_12_2007_English.part04.rar
http://rapidshare.com/files/107374980/BMW_TIS_12_2007_English.part05.rar
http://rapidshare.com/files/107376106/BMW_TIS_12_2007_English.part06.rar
http://rapidshare.com/files/107377233/BMW_TIS_12_2007_English.part07.rar
http://rapidshare.com/files/107378356/BMW_TIS_12_2007_English.part08.rar
http://rapidshare.com/files/107379366/BMW_TIS_12_2007_English.part09.rar
http://rapidshare.com/files/107380406/BMW_TIS_12_2007_English.part10.rar
http://rapidshare.com/files/107381397/BMW_TIS_12_2007_English.part11.rar
http://rapidshare.com/files/107382460/BMW_TIS_12_2007_English.part12.rar
http://rapidshare.com/files/107383523/BMW_TIS_12_2007_English.part13.rar
http://rapidshare.com/files/107383836/BMW_TIS_12_2007_English.part14.rar
R0nnIe
Registrovaný: 11.9.2008
Auto: 325i e36 coupe
Štvrtok, 8. Januára 2009, 13:43
ice.blade napísal:
Ako sa pouziva ten rapidshare? nemam s tym skusenosti.
Ederon
Štvrtok, 8. Januára 2009, 14:48
neni co riesti, pozri linku, daj free user (ak nechces platit) a potom stahuj
je to sice dost annoying, lebo vzdy mozes stahovat len jeden subor a medzi stahovanim si to vyzaduje nejaku pauzu, ale da sa to...
docertabum
Registrovaný: 3.9.2008
Štvrtok, 15. Januára 2009, 14:57
ludkovia, tak som si stiahol ten image... len teraz nie som si isty, ci to musim aj vypalit, alebo staci to len rozbalit na disk a tak nainstalit, lebo pri tej druhej moznosti sa to chova nejako debilne... inak nemozem si pomoct ale cely ten soft vyzera tak "šupacky". teda ziaden autostart alebo ina samozrejmost. Len este dodam, ze skusil by som to aj napalit aj namontovat, ale momentalne nemam nato podmienky. som v praci :)
a este jedna otazka. Je toto CDcko ekvivalentom napr. tejto knihy?
http://www.amazon.com/gp/reader/0837612772/ref=sib_dp_pt#reader-link
BMW e46 323i
LuCKy
Registrovaný: 29.1.2007
Auto: BMW 530iMola
Štvrtok, 15. Januára 2009, 16:20
R0nnIe napísal:
Stiahni si USDownloader a nemusíš čakať ako blb, kedy Ti rapid dovolí ťahať. Skopíruj si všetky tie linky, daj pridať do zoznamu, potvrď, spusti ťahanie, daj na pozadie a nech si ťahá. :wink:
Ešte si nastav miesto kam to má ukladať.
LuCKy
LuCKy
Auto: BMW 530iMola
Štvrtok, 15. Januára 2009, 16:22
docertabum napísal:
Keď to máš stiahnuté, tak to rozbaľ. Bude tam jeden súbor s obrazom dvd, ten si buď napáľ alebo si ho otvor vo virtuálnej mechanike a pracuješ s ním ďalej ako s napáleným.
A keďže je to TIS, tak to budeš inštalovať. WDS inštalovať netreba, stačí vložiť dvd alebo otvoriť obraz vo virtuálnej mechanike.
LuCKy
