amand
Registrovaný: 19.3.2012
Auto: 320d
vypnutie airbagu 320d Touring
Sobota, 2. Marca 2013, 11:42
Zdravim pani. Vy mi urcite budete vediet pomoct - potrebujem vypnut airbag spolujazdca, predny aj bocny kvoli umiestneniu autosedacky dopredu (vzadu uz jednu mam a aby mala manzelka dobry vyhlad na oboch drobcov zozadu) Ziadny klucik na boku palubovky ako pise mudra knizka som vsak nenasiel. Znamena to, ze sa mi nedaju vypnut?
Dikes
Ak sa opakujem s nejakou inou temou, sorac, nechodim tu moc casto a nic k tomuto som tu nenasiel. Kludne ma presunte na spravne miesto :)
kubog
Registrovaný: 22.8.2011
Auto: Tiguan 1.5 TSI DSG
Re: vypnutie airbagu 320d Touring
Sobota, 2. Marca 2013, 11:54
Niekto pise ze tam ten switch ma ked otvori pasazierove dvere, niekto hovori ze sedacka ma senzor, ktory nespusti ABG ked tam je menej ako 20kg, niekto pise ze to bola priplatkova option (mat switch) a dalsi pise, ze bag nebuchne, ked nie je zapnuty pas. A teraz babo rad :-k Manual?
kubog
Sobota, 2. Marca 2013, 11:57
Toto sa pise v prirucke.
Automatic deactivation of front
passenger airbags
Your BMW has a seat occupation detection
system. By evaluating the weight on the front
passenger seat, the system detects whether or
not the seat is occupied by a child in the child-
restraint system or an adult.
When a child is seated in the child-restraint
system, or with an empty seat, the front and
side airbags are automatically deactivated
on the passenger side.
When an adult is traveling in the front seat,
the front and side airbags remain active on
the passenger side.
Although not desired,
it can occur in the
case of heavier children that the front
passenger airbags remain active, or in the case
of very light adults or young persons that the
front passenger airbags are deactivated. In
these cases, have the pe
rson ride in the rear
seat, refer to Passenger airbag status lamp
below. Do not load the
passenger seat with any
items in addition to the person to be trans-
ported. Do not attach se
at covers, seat cushion
padding, ball mats or other items to the front
passenger seat unless th
ey are specifically rec-
ommended by BMW. Do not place any items
under the seat. Otherwise, the function of the
ion could be impaired
amand
Auto: 320d
Sobota, 2. Marca 2013, 12:04
Empiria je sice pekna vec, ale nerad by som to skusal na svojej dcere, ktora z tychto variant je ta moja :) Ja to tam ten switch nemam, aj ked manual pise, ze to tam mam. Posledna veta v manuale ale hovori, ze ked to tam nie je, neda sa to vypnut. ISOFIX som vpredu nenahmatal (mam ho len vzadu) takze sedacka by musela ist na pas.
Mam este nejake posuvne tlacidlo v priestore pod laktovou opierkou (polohy I a O) nemoze to byt ono, len mi to prehodili blizsie k ruke? :) To by bolo user friendly riesenie...
Kallon
Registrovaný: 6.2.2008
Auto: VW Passat Variant
Sobota, 2. Marca 2013, 13:56
amand napísal:
nie, to tlacidlo pod laktovkou je zapnutie/vypnutie ventilacie priehradky.
Naposledy upravil/-a Kallon v Nedeľa, 3. Marca 2013, 15:32, upravené celkom 1 krát.
VW Passat Variant, 140kW,´18
PEUGEOT 308 SW, 73kW,´16
LADA Kalina SW, 72kW,´17
EX:
PEUGEOT 301, 68kW,´14
ROVER 25, 63kW, ´00
CITROEN C3 Picasso, 68kW, ´13
SUZUKI SX4, 88kW, ´12
BMW E90 320D, 120kW, ´06
BMW E36/5 318ti, 103 kW, ´97
ŠKODA 120LS, 40,5kW, ´86
amand
Auto: 320d
Sobota, 2. Marca 2013, 21:25
Super kubog, dakujem za tento text. Slovensky manual je riadny shit, nic taketo v nom nie je. Toto mas niekde z netu? Mohol by si mi poslat link na komplet tento manual - ktovie co sa este dozviem o svojom aute co v SK manuale nepisu :)
