dodo.036
Registrovaný: 27.9.2008
Auto: 330i E46
Re: Zapojenie HarmanKardon Sub Bass
Streda, 8. Augusta 2012, 14:09
fox1k napísal:
aby ti to hralo normálne, musíš mať ešte HK zoslivač, nie ten čo máš k tým repro, viď dole popis pinov na zosilovač :wink:
HK Amp
5 Fuse 41 - 30A 2.5 RT/GN
38 RADLV+, Left Front Input+ 0.75 Yellow/Red
30 RADLV-, Left Front Input- 0.75 Brown/OR
9 RADRV+, Right Front Input+ 0.75 Blue/Red
17 RADRV-, Right Front Input- 0.75 Brown/OR
37 RADLH+, Left Rear Input+ 0.75 Yellow/Black
29 RADLH-, Left Rear Input- 0.75 Brown/OR
8 RADRH+, Right Rear Input+ 0.75 Blue/White
16 RADRH- Right Rear Input- 0.75 Brown/OR
26 GROUND 2.5 Brown
10 ANTENNA 0.5 White
33 HLV+, Left Front Tweeter+ 0.5 Yellow/Red
34 HLV-, Left Front Tweeter- 0.5 Yellow/Brown
40 MLV+, Left Front Mid-Range+ 0.5 White
39 MLV-, Left Front Mid-Range- 0.5 Blue/White
4 TLV+, Left Front+ 1.5 Blue/White
3 TLV-, Left Front- 1.5 Blue/Brown
31 MTHL+, Left Mid-Range+ 0.5 Yellow/Black
32 MTHL-, Left Mid-Range- 0.5 Yellow/Brown
2 LH+, Left Rear+ 1.5 Yellow
1 LH-, Left Rear- 1.5 Brown
11 HRV+, Right Front Tweeter+ 0.5 Blue/Black
12 HRV-, Right Front Tweeter- 0.5 Blue/Brown
42 MRV+, Right Front Mid-Range+ 0.5 Green
41 MRV-, Right Front Mid-Range- 0.5 Blue/Green
23 TRV+, Right Front+ 1.5 Blue/Red
22 TRV-, Right Front- 1.5 Blue/Brown
13 MTHR+, Right Mid-Range+ 0.5 Yellow
21 MTHR-, Right Mid-Range- 0.5 Blue/Yellow
25 RH+, Right Rear+ 1.5 Blue
24 RH-, Right Rear- 1.5 Brown
7 SUB_ON, (X18774-2) 0.5 WS
19 TAA, Speedometer Signal (X18774-7) 0.35 SW/GN
6 SUB_IN+, Out+ to subwoofer amp (X18774-1) 0.5 GN
14 SUB_IN-, Out- to subwoofer amp (X18774-6) 0.5 BL/GN
Diky moc,vidim ze sa vyznas
Velky HK dava tomuto malemu zosiku iba signal NIC viac,dokonca ani nie odfiltrovany,kedze maly HK ma
lowpass vyhybku a aktivny 2 x 40W koncak
Chcel som iba odpovede na moje otazky hore,ale.......
Ak to niekedy bude niekto riesit:
Speed signal nemusi byt zapojeny,ale ak mu date 0 - 5V tak budete ovladat jeho vybudenie
Bass je odfiltrovany,cize hra iba spodok
Ma to vysokourovnovy vstup (dokonca aj BOSE u mercedesu to tak ma )
A ako to hra... no mam to zapojene v robote na stole,a co ja viem,chyba tomu samozrejme ozvucnica,
ale bass je pekne makky,ale urcite mu bude chybat vykon...
Dam do auta a uvidim,urcite to tam necham,kedze ma to nic nestalo....
Bohus,mozem za Tebou zbehnut niekedy a mozes si to vypocut ak chces.
_________________
BMW 320i E36. M52
BMW 320i E36. M52
Užívatelia prezerajúci toto fórum: Google [Bot] a 13 neregistrovaných
