jimi
Registrovaný: 12.2.2008
výmena automatu na manual E46 - prosím o radu
Nedeľa, 12. Februára 2012, 23:46
pomáham kamarátovi s vymenou automatu na manuál,
našiel som pár stránok
http://forum.e46fanatics.com/showthread.php?t=659314&highlight=automatic+to+manual
http://translate.google.com/translate?sl=en&tl=sk&js=n&prev=_t&hl=sk&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fforum.e46fanatics.com%2Fshowthread.php%3Ft%3D396320
avšak nie je mi z toho jasné, kde napojiť káble zo spínača cuvacich svetiel, a či nebude problem so štartovaním kedže nebude tam zaradená "N" ani "P"
vie mi stým niekto pomôcť?
https://www.cardetail.eu/
E46 330XD 135kW, 2001
E46 320D 100kW, 2001
E46 320D 110kW, 2002
E46 320D 100kW, 2000
kosti123
Registrovaný: 18.7.2010
Auto: e46 323Ci
Re: výmena automatu na manual E46 - prosím o radu
Pondelok, 13. Februára 2012, 07:59
K cuvacim svetlam pise: For the reverse lights all I did was remove the plug from the transmission once it was installed. I ran up to radioshack and got some flat style plug electrical connectors. So I could just plug two wires into the reverse light switch. I reinstalled the sensor back on the transmission and ran the wires to the glove box were there was a reverse light terminal above the fuse panel as stated by Ivegotissues666's DIY. Just refer to it to see the proper connector, I was too lazy to tear into my glove box so I skipped on installing the reverse light switch. I just have the wires running into the "drug storage compartment" in the engine, so when I actually feel like wiring the lights, it wont be too terrible.
takze bud do terminalu v poistokovej skrinke alebo priamo od snimaca na prevodovke.
K druhej otazke, ku koncu vidis ako typek taha biely kabel od spinaca spojky do motoroveho priestoru..takze tam treba kabel podla instrukcii napichnut na spravny konektor a malo by to iste, ale auto treba aj tak prekodovat na manual cez diagnostiku, aby nesvietil achyba prevodovky na budikoch.
jimi
Pondelok, 13. Februára 2012, 09:09
dakujem ti za snahu pomôct,
zapojenie cuvacieho svetla je len menši problem,
ale
od spinača spojky taha jeden kabel ku RJ, a čo je stým druhým kablom z toho spinača? ved na ten spinač idu minimalne 2 kable, kam pripája ten druhy? a nie je to kábleovanie zo spojky len kvôli tempomatu?
kosti123
Auto: e46 323Ci
Pondelok, 13. Februára 2012, 10:09
Ved to tam vsetko popisuje:
OK! Now onto greater things! Now for the clutch switch and clutch switch module. The module is attached to the clutch master cylinder and the clutch switch is mounted on the pedal assembly's frame. The clutch switch goes in one of the mounting holes in the pedal assembly. The bottom one so that when you depress the clutch pedal, it presses the actuator in. Once you swap the transmission, to get the car to start, you will need to wire the clutch safety switch as so:
Its a 3 pin connecter
Clutch Switch:
Pin 1 - Goes to Ground (At Brake Light Switch)
Pin 2 - Goes to the DME connection at A60004 pin 23
Pin 3 - Goes to 12v+ (At Brake Light Switch)
It's connected in parallel to the Clutch Switch Module which is mounted on the side of the clutch master cylinder.
Clutch Switch Module:
Pin 4 - Goes to EWS Pinout #8
What I did was quicktap all the wires of the same together. So i quick tapped both pin 1 wires together, both pin 2 wires together and ran them up into the DME, and I quick tapped both pin 3 wires together and tapped them into the power wire of the brake light switch which I believe was pin 2. Pin 1 of the brake light switch was the ground btw.
prepaja spojkovy spinac s modulom spojky ktory je priamo na valci - prvy pin na zem, druhy do DME, treti na 12 voltov
jimi
Utorok, 14. Februára 2012, 11:44
hm...
ja ale na tom valci nemám žiadny modul....
jimi
Nedeľa, 19. Februára 2012, 12:53
nuž vyriešil som to odmontovaním spínača z prevodovky a zaradením do "P" , následne som ten spínač zaistil proti pohybu a prippevnil k autu.
na palubovke síce píše chybu prevodovky, ale nemá to vplyv na jazdu.
