AXL
Registrovaný: 26.5.2009
BMW M3 E46 CSL Detailing washing
Pondelok, 1. Novembra 2010, 16:49
Takže trošku detailné umývanie tejto mašinky..enjoy :)
Day 1 - Before:
Dead flies welded to the bonnet!
Stone peppered corner splitter
Plenty of tyre rubber deposits
Tar spots
More rubber marks
Work starts! Pre-wash with Valet Pro pH Neutral Snow Foam
Paying attention to badges with Meguiar's APC and round brush
Fuel flap housing and door/boot shuts also done. Car then jetted off before washing using 2BM with Meguiar's Shampoo Plus & sheepskin mitt.
Car then dried before de-tarring with AG Intensive Tar Remover
Car was then washed/rinsed once again.
Clayed with Meguiar's Mild Detailing Clay using Last Touch Spray Detailer as lube
Car jetted off and early indications of paint condition looked ok
Carbon fibre roof reflections looked rather dull/fuzzy
Roof first pass with Menzerna RD3.02 & polishing pad
Roof, boot & front end of car done by the end of first day
Day 2 - the following weekend. Ready to crack on with the rear and sides after a quick wash/dry process
DAS 6 PRO with 85RE Final Finish & finishing pad
Rear light cluster showing swirls
Rear lights after correction
I had a 'mishap' when a finishing pad had a blow out! I think i was using too fast a setting.
Naposledy upravil/-a AXL v Pondelok, 1. Novembra 2010, 21:55, upravené celkom 1 krát.
AXL
Re: BMW M3 E46 CSL Detailing washing
Pondelok, 1. Novembra 2010, 16:55
next
With paintwork almost done it was time to try and make the front end look better - polishing the carbon fibre kidney grille surrounds
Headlight covers
It was at this point i noticed that the headlights looked a little manky inside the housings themselves so i got a little carried away and began dismantling them to get inside!
A quick clean with APC still didn't make the shrouds look that good so i decided to coat the them with Gtechniq C4 Permanent Trim Restorer to restore some blackness
Definite improvement and less marks on the outer cover too!
I also decided to clean and treat the kidney grille insert slats using C4 and there ended day 2!
Day 3. Impressed with my first use of Gtechniq C4 the previous day, i decided to apply it to a few other areas.
Firstly i decided to clean and coat the areas visible through the kidney grilles
Fan assembly cleaned prior to application of C4
Blade 50/50
All done - the sheen lessens when it dries
Fan guard back in place
Bonnet vent before C4
Bonnet vent after C4 application
Pause for a quick roof reflection
Tyre sidewalls cleaned with Meguiar's APC and stiff brush before being wiped with Zaino Z16 Perfect Tire Gloss
Arches cleaned with APC and old microfibre wash mitt
Arches then treated with Meguiar's All Season Dressing
The Supersprint exhaust received some work next
Washed with Meguiar's APC
Polished with AG Metal Polish
Onto the interior - over mats removed, vacuumed and scrubbed with Meguiar's APC and brush
Wiped down and vacuumed again
Then dried in the sun
Interior carbon fibre door panels lightly polished
Naposledy upravil/-a AXL v Pondelok, 1. Novembra 2010, 21:59, upravené celkom 1 krát.
AXL
Pondelok, 1. Novembra 2010, 16:59
last 8)
Foot pedals cleaned with Meguiar's APC & brush
Dash & interior plastics wiped down with mild APC solution
Windows cleaned with 3M Glass Cleaner spray
Alcantara seats were cleaned using Raceglaze Alcantara Cleaner, including this baby milk stain on the rear seats (yes, baby milk lol!)
Alcantara trimmed steering wheel wiped down
Interior trim & plastics treated with Werkstat Satin Prot
Mats replaced - interior done!
Finally with daylight beginning to fade i turned to the protection stage.Bonnet vent looking good
A final rinse off to be rid of all polish dust & residue
Car was then dried with a PB Luxury Drying Towel before applying the protection.
I plumped for the Werkstat Acrylic Jett from recommendations that it would work well on my mid-tone metallic grey paint.
One coat applied
Luckily the light remained long enough for me to apply a second coat before calling it a day after 3 days and some 25 hours or so of work! After:
Job done - tucked away ready for this coming weekend's trip to the Nurburgring
Naposledy upravil/-a AXL v Pondelok, 1. Novembra 2010, 22:02, upravené celkom 1 krát.
blesk
Registrovaný: 15.7.2010
Auto: x1 18xd (2015)
Pondelok, 1. Novembra 2010, 17:32
tak to je presn eauto ktoremu by som to doprial s pasiou, paradna praca. co vyjde takyto komplet?
dzyko
Registrovaný: 19.9.2009
Auto: E46 323Ci
Pondelok, 1. Novembra 2010, 20:05
super konecne sa tu ukazuje nejaky detailing mohol si dat nejaky ten popis prace a prostriedkov
AXL
Pondelok, 1. Novembra 2010, 22:04
Doplnený stručný popis prác a použitých prípravkov v poznámkach medzi fotkami..Podotýkam v angličtiine..Rozhodne sa mi to už nechcelo prekladať.. :roll:
to blesk : netuším koľko vyjde taký špás ale myslím že to bude dosť drahé.už len tie prípravky.Na tej stránke to vačšinou každý čistí doma sám. Všetko poctivá homework.. :)
Peter92
Registrovaný: 20.4.2009
Auto: BMW E92 -330 xd
Pondelok, 1. Novembra 2010, 22:49
tu mate najdrahsiu umyvarku na svete a priblizne ceny:
http://www.luxuo.com/automobile/car-wash.html
MattyX
Registrovaný: 29.6.2009
Auto: 325i mtech
Utorok, 2. Novembra 2010, 12:34
hm a tedka se na to tak rok bude jen divat aby to nezaspinil :mrgreen:
VT-535BH
Registrovaný: 29.8.2009
Auto: E60 535d
Utorok, 2. Novembra 2010, 18:39
Nááádhera. No nerob to s láskou... [-o<
Tomáš
snoo
Registrovaný: 9.8.2007
Štvrtok, 16. Decembra 2010, 02:49
podobnu pracu na slovensku robi aj www.umysi.sk
BMW G05 40i
BMW G01 M40i
BMW F15 40d EX
Ford mondeo mk4
BMW E91 318d EX
BMW F07 530d EX
BMW E61 530DT A/T EX
BMW e53 4,8is EX
BMW e53 4,6is EX
BMW e36 323i coupe EX
BMW e30 325i coupe EX
BMW e34 520iA sedan EX
BMW e46 323i sedan EX
mys_iak
Registrovaný: 14.3.2009
Auto: Bmw F31 316d
Sobota, 18. Decembra 2010, 20:19
popripade www.snoolux.sk
Bmw F31 316dAT
ex: e61 530iA+LPG
e36 320Ci+LPG
e39 530dAT
e46 320dT
e91 320d
BMWpositiv
Sobota, 18. Decembra 2010, 21:26
...obrazok 56.jpg :D
...ze vraj detske mlieko, to isto... :mrgreen:
Šubo
Registrovaný: 9.3.2009
Auto: BMW Power
Streda, 9. Februára 2011, 21:09
AXL
Streda, 9. Februára 2011, 22:38
:-k hmm čakal som nejaké video detailneho umývania CSLka a ono to je len photoshoot M3ky :-k neva..aj tak tá M3ka je krute naložená..brutal =P~
Šubo
Auto: BMW Power
Štvrtok, 10. Februára 2011, 20:56
mno sak po poriadnom umytii treba este riadne foto :wink:
