pablo_s
Registrovaný: 23.2.2007
Auto: G21 320xd
Re: ako oklamat ochranu pri dvojvrstovych navi. dvd(2008.1/2)
Streda, 28. Januára 2009, 14:58
je dost mozne ze potrebujes iny typ navigacneho DVD... ale ak mas original stare navigacne DVD tak na obale musi byt napisane ci je to professional alebo business
G21 320xd
F31 320d Ex
E90 320d Ex
E46 320i Ex
simumarek
Registrovaný: 19.2.2008
Auto: BMW 318tds Touring
Streda, 28. Januára 2009, 15:15
Práve v tom je ten problém, že oriinál nemám. Nejaké mapy sú nahraté asi priamo v ňom, lebo ide aj bez akéhokoľvek DVD a v rakúsku naviguje normálne, nie je tam však sk.
BMW 318 tds Touring MaxTDi
myroslav
Registrovaný: 9.10.2008
Auto: E46 318D Touring
Streda, 28. Januára 2009, 15:23
Takze ospravedlnujem sa, teraz som si ten torrent este raz porovnaval, je to Proffesional verzia (Nie HIGH) v tom odkaze s -doc suborom, cize je to pre novsie modely, tu je podrobnejsie info:
BMW 2009-1 Road Map Europe Professional DVD inc European Speed Cameras
Due to problems with dual layer burning for some users, all language folders have been removed from the disc image, OTHER THAN ENGLISH.
This allows the image to fit onto a single-layer DVD+R / DVD+RW.
The navigation language folder will automatically default to ENGLISH, whichever European vehicle the disc is used in.
This contains the European Speed Camera Database (NOV08).
Suitable for iDrive with SatNavPro:
E81, E82, E87, E88, E9x, E60, E61, E63, E64, E70 & E71
NOT SUITABLE FOR: MK4 DVD & Business Nav (HIGH)!!!!!!!
The speed camera POIs are available for ALL languages:
ENG, FRE, GER, ITA & SPA
Forced Default language: ENG
Countries included:
AD,AT,BE,BY,CH,CZ,DE,DK,EE,ES,FI,FR,GB,GI,GR,HR,HU,IE,IT,LI,LT,LU,LV,MC,NL,NO,PL,PT,RU,SE,SI,SK,SM,U A,VA
-Improved routes
-Still NO full postcode search.. :(
-Improved POI sub-category searching
eg hotel parking availability, type of restaurants
1 Download torrent & please SEED
2 Burn iso image with NERO etc onto blank DVD+R / DVD+RW
Finalise disc, if option available
Tested ok with Verbatim, TDK & Sony DVD+R / DVD+RW x2, x4 & x8
3 Stick disc in car DVD slot
4 Follow iDrive instructions & re-start car after 5 minutes
5 Choose Euro Speed Cams in CAR category of POIs
Merry Christmas!
OO\[][]/OO E46 318D Touring
Bawarska Miłość Wieczna
pablo_s
Auto: G21 320xd
Streda, 28. Januára 2009, 15:26
Ja myslim, ze mas prave tu verziu navigacie MK4 to je starsi typ, takze tam musis hladat aj mapy pre tento typ...
G21 320xd
F31 320d Ex
E90 320d Ex
E46 320i Ex
el_fuego333
Registrovaný: 20.10.2008
Sobota, 21. Februára 2009, 14:49
pablo_s napísal:
toto je podla mna ten starsi typ navigacie a asi to bude skos business, takze potrebujes business verziu navigacie...
Toto je typ professional typ HIGH. Ked mu to nejde, tak ma bud DVD pre typ CCC (teraz pozeram, ze ma high), alebo ma stary firmware, ktory nevie citat dual layer DVD - to je ten popisovany linux server beziaci na pocitaci navigacie aj v servisnych staniciach.
Pri napalovani je dolezite pouzit co najkvalitnejsie DVD a pouzit co najnizsiu rychlost napalovania.
Opakujem: co najnizsiu rychlost napalovania.
Naposledy upravil/-a el_fuego333 v Sobota, 21. Februára 2009, 14:55, upravené celkom 1 krát.
Poloboh vetra a mora, hrdina muzov. Radikalny ultraheterosexual.
X5 e70
el_fuego333
Sobota, 21. Februára 2009, 14:53
Tento typ navigacneho systemu je mk4, HIGH. Treba donho nahrat najnovsi firmware od BMW (v32). Po nahrati noveho firmware budu pristupne nove funkcie (pokial uz nie su - zalezi na aktualnej verzii v aute) a to: Prespektivny mod zobrazenia mapy, podpora Dual Layer DVD atd.. viac v SIB pre bmw navigation software v32.
Na tomto softe som spravil aj podporu slovenciny s hlasovymi instrukciami. Pokial by mal niekto zaujem, 0903 255 823.
X5 e70
kamelot
Registrovaný: 14.9.2008
Auto: BMW E46 330dT
Utorok, 14. Apríla 2009, 13:28
:arrow: ...
FAKT SA NENAJDE NIKTO KTO BY PORADIL :?: :-k :-k
Naposledy upravil/-a kamelot v Utorok, 14. Apríla 2009, 19:14, upravené celkom 1 krát.
E46 330dT Orientalblau
pablo_s
Auto: G21 320xd
Utorok, 14. Apríla 2009, 13:33
myslim ze ak tam mas prefessional mavi s idrive tak by to mali byt tie iste mapy, ale skus sa pohrabat neikde na nete alebo si zavolaj do bawarie alebo do nejakeho origo servisu ze ci ti neporadia ze ci je to to iste, ze mas moznost kupit origo mapy z E90 ky a ci ti pojdu an na E60 ke...
G21 320xd
F31 320d Ex
E90 320d Ex
E46 320i Ex
kamelot
Auto: BMW E46 330dT
Utorok, 14. Apríla 2009, 14:52
no zistoval som, mapy by mali byt rovnake, jedno ci E9x,6x... ide o verziu buisness, professional. v aute je PRO...
dokonca sme skusili aj original dvd 2009-1 a ide... ale napalene za ziadnu cenu (a pritom vyskusane bolo snad vsetko mozne, DVD+R (emtec), DVD+RW (benq), DVD-R (benq)).
netreba nieco nastavit pri napalovani? davam to v nere na 4x, disk-at-once, finalizovat disk...
pablo_s
Auto: G21 320xd
Utorok, 14. Apríla 2009, 15:15
plusko ani minusko by na to nemalo mat vplyv, idealne je to palit nejakou 4 kou rychlostou, je si uz nepamatam ze ci to je na tom torente ako iso alebo ako, ale predpokladam, ze by to malo bit po rozbaleni iso a to ked das otvorit v nere tak ti uz moc moznosti ako to vypalit neostane.. maximalne tambudes moct nastvit rychlost vypalovania, ale inak by vsetko malo ostat tak ako je... malo by to na 100% fungovat...
G21 320xd
F31 320d Ex
E90 320d Ex
E46 320i Ex
kamelot
Auto: BMW E46 330dT
Utorok, 14. Apríla 2009, 19:13
uz funguje :smile:
psycho
Registrovaný: 20.4.2008
Auto: X5,Z3roadster
Pondelok, 20. Apríla 2009, 16:11
ako si to vyriesil?
740i-ZV
Registrovaný: 3.1.2009
Auto: BMW 740i E38
Re:
Pondelok, 13. Júla 2009, 18:08
pablo_s napísal:
ak by mal niekto zaujem, tu je torrent s mapami 2009-1 s uz vysekanymi jazykmi, takze staci stiahnut a napalit iso na jednovrstve DVD, odporucam 4x rychlostou na pluskove DVD, funkcne je aj minuskove...
a co mam stim robit?
740i-ZV
Auto: BMW 740i E38
Pondelok, 13. Júla 2009, 18:09
Ja mam E38 z 1996 aku si mozem dat tam?
myroslav
Streda, 19. Augusta 2009, 12:51
chlapi, akurat som dotahal 2009-2 pre system HIGH (MK4) (E46, ...) a je to na jednovrstvove dvd, len nikde nepise ze v akom programe to palit, mam uz pripravene Verbatim DVD-R medium, v com to vypalit, aby to fungovalo?
