wixter
Registrovaný: 23.7.2008
Auto: BMW E91 318d
Re: e91 LCI vstreky
Sobota, 20. Februára 2016, 13:48
donedavna ano... este som pletenec roztrhnuty... odrezal sa a navaril sa tam novy... odvtedy mi 2x vyhodili chybu motora (tankoval som aj na pumpe kde nazvyknem, starsia slovnaft pumpa).
chyby sme moc nestudovali, ale bolo tam nieco s dpf, s vyfukovymi plnynmi a neviem co este... vymazali sa a teraz pred par dnami mi to spravilo zas, ale chyby som este nedal vycitat :/ kazdopadne chybu vstrekov tam zobrazuje stale
E91 318d LCI
E60 530d - ex
E46 316i - ex
Re: e91 LCI vstreky
Sobota, 20. Februára 2016, 13:49
Da sa to.....pisal som pozrem sa na to po viku a dam vediet..
Re: e91 LCI vstreky
Pondelok, 22. Februára 2016, 09:39
Zero-quantity adaptation
Zero-quantity adaptation is the adaptation process which is used after the running-in phase (approx. 1500 km) for every single injector to assure the presence of a defined level of pre-injection.
To achieve compliance with exhaust emission standard EURO 4, precise metering of the very small fuel injection rate is required for pre-injection purposes.
Due to the deviation for the fuel injection rate over the operating time, the zero-quantity adaptation is performed continuously by the DDE control unit.
For every cylinder in coasting (overrun) mode, a small quantity of fuel is injected. This quantity is then varied until the desired torque rating is detected by the DDE. To calculate the torque rating, the irregular rotation of the crankshaft is incorporated in the equation. This irregular rotation is recorded on the crankshaft sensor.
This enables the DDE to detect the activation duration after which the cylinder starts to operate. The quantity of fuel injected during the zero-quantity adaptation period is used by the DDE as a correction value for the gearshift map of the pre-injection process.
The zero-quantity adaptation process switches from one cylinder to another in each overrun phase at:
engine speed 1500 to 2500 rpm (engine at operating temperature)
The zero-quantity adaptation has no impact on fuel consumption because only a small quantity of fuel is injected into each cylinder (approx. 1 mm3
wixter
Auto: BMW E91 318d
Re: e91 LCI vstreky
Pondelok, 22. Februára 2016, 09:43
Diky za specifikaciu, ale moja anglictina nie je az taka dobra. co to pls znamena?
E91 318d LCI
E60 530d - ex
E46 316i - ex
upir156
Registrovaný: 25.11.2012
Re: e91 LCI vstreky
Pondelok, 22. Februára 2016, 10:10
Nepoznáš Google translate?
wixter
Auto: BMW E91 318d
Re: e91 LCI vstreky
Pondelok, 22. Februára 2016, 10:14
Uz som to tam hodil ale z toho prekladu mi aj tak nie je uplne jasne co teda robit
E91 318d LCI
E60 530d - ex
E46 316i - ex
badbat329
Registrovaný: 20.5.2012
Auto: F31
Re: e91 LCI vstreky
Pondelok, 22. Februára 2016, 10:31
Zero-quantity adaptation je adaptacia ako kazda ina, v DISe sa to da resetnut, cez vikend som to skusal na mojom, ale moj DIS zacal strajkovat a vyhodil chybu 100.723 ... bla bla bla ... choj na diagnostiku a nechaj si to resetnut.
wixter
Auto: BMW E91 318d
Re: e91 LCI vstreky
Pondelok, 22. Februára 2016, 10:36
Resetnut v akom zmysle? To je ine ako premazat chyby?
E91 318d LCI
E60 530d - ex
E46 316i - ex
badbat329
Auto: F31
Re: e91 LCI vstreky
Pondelok, 22. Februára 2016, 10:42
adaptacia je nieco ako samonastavenie, konkretne v tvojom aute ich je viac, adapatacia vstrekov, vahy vzduchu, snimaca tlaku v raily a par dalsich, napr pri vymene vahy vzduchu sa hodnoty povodnej vahy zmazu a jednotka sa tym adaptuje na novu vahu. Po tej oprave co si mal to bolo asi treba spravit, je to len typ .. osobne som taky problem este nemal.
wixter
Auto: BMW E91 318d
Re: e91 LCI vstreky
Štvrtok, 25. Februára 2016, 12:50
takze mam diagnostiku v servis motiv na trnavskej v bratislave.
Diagnostikovali mi to, vypisalo im to opat chybu 3 vstrekov (aj EGR ale to predtym nevypisovalo)
Adaptacia je zevraj ok (poradie v strekov v motore bolo rovnako zapisane ako na diagnostike).
Lamali si hlavu s tym, ze nevedia co to moze sposobavat. Vynuloval mi stredove korekcie, ale povedal ze nevie ci ot daco spravi.
Neviete mi poradit co dalej? uz som fakt zufaly
E91 318d LCI
E60 530d - ex
E46 316i - ex
badbat329
Auto: F31
Re: e91 LCI vstreky
Štvrtok, 25. Februára 2016, 16:47
pod stredovymi korekciami myslel Zero-quantity adaptation? Ci nevies? tiez som z toho jelen.
wixter
Auto: BMW E91 318d
Re: e91 LCI vstreky
Štvrtok, 25. Februára 2016, 16:55
to neviem, len tak ako mi bolo povedane :/
E91 318d LCI
E60 530d - ex
E46 316i - ex
wixter
Auto: BMW E91 318d
Re: e91 LCI vstreky
Pondelok, 29. Februára 2016, 11:58
Chlapi nevie nikto co dalej?
pre zhrnutie:
Na diag ukazuje chybu troch vstrekov, vstreky boli na stolici a su ok
Najnovsie ukazuje uz aj chybu EGR (chybu vtrekov zobrazovalo aj pred tym)
Vstreky su ulozene spravne, diag ukazuje rovnake poradie strekov ako realne su dane v motore
Nikto kto by s tym mal realne skusenosti ???
E91 318d LCI
E60 530d - ex
E46 316i - ex
patriotXT
Registrovaný: 6.3.2012
Auto: E91 330xd
Re: e91 LCI vstreky
Streda, 2. Marca 2016, 08:55
zajdi k simikovi do TT, z BA to nemas daleko
ak to nevyriesi on tak asi nikto na slovensku
eddy159
Registrovaný: 15.2.2008
Re: e91 LCI vstreky
Piatok, 4. Marca 2016, 08:25
mal som podobny problem x5 e70 3.0d. chlapik kupil auto v pamati vtedy neboli ziadne chyby korekcie 0,1-0,5 cize vstreky na 100 percent. jazdil na tom mesiac a zacal sa stazovat ze mu zhasina motor za jazdy. pocitac ukazal vstreky uz neviem kolko ale myslim 3,4,5,6. zacal do toho davat aditivum prolong a pomohlo to na cas az jedneho dna rano nastartoval auto na vsetkych 6 a potom zdochol a takto to islo dokola na koniec to bol vstrek na 6 valci.
