bramborak
Registrovaný: 28.5.2010
Auto: e91 "07
Re: Čo by bolo treba vymeniť po kúpe (e91 330xd AT 2007)
Piatok, 17. Októbra 2014, 10:11
ja som membranu nevidel zlu , ani na 7rocnom aute ani dvoch 13rocnych autach co sa to menilo zbytocne.
Piatok, 17. Októbra 2014, 10:14
bramborak napísal:
na hadici od separatora teda nebol olej?
lieceny syndrom - tiekla vakuovka a hadica od separatora riadne mokra, separator bezudrzbovy, po vymene sucho
bramborak
Auto: e91 "07
Piatok, 17. Októbra 2014, 10:57
po vymene noveho obalu separatora s membranou ? ja si myslim ze poskodena-dierava je len v extremnych pripadoch ak vobec, ale moze byt stvrdnutá... :-k
Piatok, 17. Októbra 2014, 11:05
bramborak napísal:
neviem co s nou bolo ale proste ta vymena pomohla :-#
vystrihnute z e90post:
Quote:
Originally Posted by Will0800 View Post
Your right, it is a venturi style filter, but beleive me, they can block! I work on these all day long and it's not uncommon for the pipes leading to the crank case block up with thick oil and oil sludge which causes the oil separator to block and causes all sorts of issues!
100% correct. I'm the service manager for an indy dealership and boy do we get through some breathers.
//end of quote
Best course of action for me is to always recommend its changed if in any doubt when going over the cars history when the service book or info regarding the cars history is given to me. Its a small price for the security it offers and can solve many issues the customers report. The shocking thing for many is finding cars that have been though the main dealer network that haven't had the work done and have eked the service intervals out to get max mileage between oil changes... on 320d's especially someone will pick up a nice £1500+bill if the basics are ignored.
As for this quote "speaking to one dealer the E90 does not need its breather valve replacing and should last the life of the car" my god but it shows that in many cases the front desk simply have no idea and are there to process customers and take the money... knowledge is key.. very worrying indeed as many customers would rely 100% on the info given to them by their dealer
Naposledy upravil/-a PeqpeK v Piatok, 17. Októbra 2014, 12:18, upravené celkom 2 krát.
mikem101
Registrovaný: 20.6.2011
Auto: E90 330xd, 170kw.
Piatok, 17. Októbra 2014, 11:54
Ako sa meni olej v zadnom diferencialy ?
Vedel by niekto poradit postup?
bl4ckbox, menil si alebo sa chystas menit olej v diferakoch?
E90 330xd M6 M57D30 - 3,00l (170kW), r.v. 04/2006 ......príbeh......
Ex: 330xd AT, 2003, combi, facelift
Ex: Alfa Romeo 156, 1.9JTDm, 103kw/140PS
Piatok, 17. Októbra 2014, 12:04
mikem101 napísal:
otvoris napustaci otvor, vytiahnes vsetok olej, naplnis novy kym nevyteka, zavries, dovi
dibarbora
Registrovaný: 22.1.2013
Piatok, 17. Októbra 2014, 14:24
mikem101 napísal:
vedu v tom netreba hladat, len treba pocitat, ze vytiahnes menej ako ho tam das, podla ETK je u mna na vymenu potreba 0,85l. Podla mazacieho planu castrol 1l. V skutocnosti bolo u mna po vypustak treba cca. 1,1l oleja.
Treba si este zistit ci mas diff s obmedzenou svornostou alebo bez a podla toho vyberat olej aj ked som cital, ze olej pre diferencial s obmedzenou svornostou je dobre dat aj do obycajneho diffu vzhladom na opotrebenie a eliminaciu pripadne zacinajucej hlucnosti.
mikem101
Piatok, 17. Októbra 2014, 14:57
Chlapi, dakujem za odpovede.
