msakac33
Re: BMW chybové kódy a ich význam
Nedeľa, 6. Apríla 2014, 14:15
BMW DDE 5 (Bosch EDC16), DDE 6, DDE 6.2 and DDE 6.3 fault codes.
Engines: BMW M57, M67 diesel engine fault codes.
3E90 Crankshaft RPM - No Signal
3E91 Crankshaft RPM - Wrong Signal
3E95 Intake air Temperature Sensor
3EA0 Crankshaft Position Sensor
3EA1 Crankshaft Position Sensor
3EA5 Intake air Temperature Sensor
3EA6 Intake air Temperature Sensor
3EB0 RPM Calculation
3EB5 Air flow Sensor 2
3EB6 Air flow Sensor 2
3EC0 Camshaft Sensor - No Signal
3EC1 Camshaft Sensor - Wrong Signal
3EC7 Camshaft Sensor
3ED0 Camshaft Sensor - No Signal
3ED1 Camshaft Sensor - Wrong Signal
3ED5 Air Flow Sensor 2
3ED6 Air Flow Sensor 2
3EDC Variant Coding
3EDD Variant Coding
3EE0 Coolant Temperature Sensor -Short Circuit to B+ or Open
3EE1 Coolant Temperature Sensor -Short Circuit to B-
3EE2 Coolant Temperature Sensor
3EE3 Coolant Temperature Sensor
3EE5 Air Mass Flow Sensor 2
3EE6 Air Mass Flow Sensor 2
3EE7 Air Mass Flow Sensor 2
3EED Power Management Closed Circuit Current
3EF3 Coolant Temperature Sensor not Plausible
3EF5 Intake Air Temperature Sensor 2 (HFM Reference Signal)
3EF6 Intake Air Temperature Sensor 2 (HFM Reference Signal)
3EF7 Intake Air Temperature Sensor 2 (HFM Reference Signal)
3EFB Thermal Oil Level Sensor
3EFC Thermal Oil Level Sensor
3EFD Thermal Oil Level Sensor
3F00 Boost Pressure Sensor -Short circuit to B+
3F01 Boost Pressure Sensor -Short circuit to B- or Open
3F02 Boost Pressure Sensor
3F03 Boost Pressure Sensor -Plausibility
3F05 MIL OFF
3F10 Pedal Position Sensor 1
3F11 Pedal Position Sensor 1 - Short circuit to B-
3F13 Pedal Position Sensor 1 - Potentiometer Plausibility
3F15 MIL ON
3F20 Pedal Position Sensor 2
3F21 Pedal Position Sensor 2 - Short Circuit to B-
3F23 Pedal Position Sensor 2 - Potentiometer Plausibility
3F25 Input Air Flow Control
3F30 Rail Pressure Sensor - Short Circuit to B+
3F31 Rail Pressure Sensor - Short Circuit to B-
3F35 Input Air Flow Control at Idle Speed
3F40 Rail Pressure Sensor - Max for Compensation
3F41 Rail Pressure Sensor - Min for Compensation
3F47 Brake Light or Brake Light Test Switch
3F48 Brake Light or Brake Light Test Switch
3F50 Vehicle Speed Signal - Too High
3F51 Vehicle Speed Signal
3F52 Vehicle Speed Signal
3F53 Vehicle Speed Signal
3F60 Pedal Position Sensor Ref. VSS
3F62 Vehicle Speed Signal from CAN
3F67 Filling Pressure Modulator 2
3F70 Intake Air Temperature Sensor
3F71 Intake Air Temperature Sensor
3F72 Intake Air Temperature Sensor
3F77 Boost Pressure Modulator 1
3F82 Ambient Temp Sensor
3F87 Boost Pressure Modulator 2
3F97 Boost Pressure Modulator 1
3FB0 Air Flow Meter - Signal too High or Short circuit to B+
3FB1 Air Flow Meter - Signal too Low or Short circuit to B-
3FB5 Control Master/Slave
3FB6 Control Master/Slave
3FB7 Control Unit - Internal Master
3FC0 Air Flow Meter - Deviation too High at Idle Speed
3FD0 Air Flow Meter - Deviation too High
3FE0 Air Flow Meter
3FE1 Air Flow Meter
3FF0 Air Flow Meter
3FF1 Air Flow Meter
4000 Fuel Temperature Sensor
4001 Fuel Temperature Sensor
4010 Exhaust Gas Pressure Sensor -Short Circuit to B+
4011 Exhaust Gas Pressure Sensor -Short Circuit to B-
4020 EGT -Short Circuit to B+
4021 EGT -Short Circuit to B-
4030 EGT Before Cat -Short Circuit to B+
4031 EGT Before Cat -Short Circuit to B-
4032 Exhaust Gas Pressure Sensor
4060 Atmospheric Pressure Sensor DDE-Short Circuit to B+
4061 Atmospheric Pressure Sensor DDE-Short Circuit to B-
4062 Atmospheric Pressure Sensor DDE
4063 Atmospheric Pressure Sensor DDE- Plausibility Ref. Boost
4072 Automatic Gearbox Switch Signal
4080 Brake Light or Brake Light Test Switch
4082 Brake Light or Brake Light Test Switch
4083 Brake Light or Brake Light Test Switch
40A1 Alternator Signal
40E0 Alternator
4100 AirCon Power Output
4101 AirCon Power Output
4102 AirCon Power Output
4103 AirCon Power Output
4108 Control Master/Slave
410C Swirl Flap Actuactor
4117 Control Master/Slave
4118 Control Master/Slave
4120 DDE Main Relay is Switching too Late or too Early
4121 DDE Main Relay is Switching too Late or too Early
4125 Power Supply
4126 Power Supply
4130 Swirlflaps - Short Circuit to B+
4135 Power Supply
4136 Power Supply
4140 Swirlflap
4141 Swirlflaps - Short Circuit to B-
4145 Power Supply
4146 Power Supply
4152 Swirlflaps - Open Circuit
4153 Swirlflaps - Plausibility, Overtemp of Output Stage
4155 Exhaust Flap Actuator
4156 Exhaust Flap Actuator
4157 Exhaust Flap Actuator
4158 Exhaust Flap Actuator
4160 Raise Pressure Pump - Short Circuit to B+
4161 Raise Pressure Pump - Short Circuit to B-
4162 Raise Pressure Pump - Activation Interrupted
4163 Raise Pressure Pump - Plausibility, Overtemp of Output Stage
4165 DPF -Flow Resistance too High
4166 DPF -Flow Resistance too Low
4175 Exhaust Gas Temp Sensor before DPF
4180 Boost Pressure Actuator - Short Circuit to B+
4185 Exhaust Gas Temp Sensor before Cat
4186 Exhaust Gas Temp Sensor before Cat
4188 Exhaust Gas Temp Sensor before Cat
4190 Boost Pressure Actuator
4191 Boost Pressure Actuator - Short Circuit to B-
419A Atmospheric Pressure Sensor DDE
419B Atmospheric Pressure Sensor DDE
41A0 Boost Pressure Actuator
41A1 Boost Pressure Actuator - Adjustment
41A2 Boost Pressure Actuator - Open Circuit
41A3 Boost Pressure Actuator - Plausibility, Overtemp of Output Stage
41A6 Message CBS Reset
41A7 Message CBS Reset
41AA Boost Pressure Sensor
41AB Boost Pressure Sensor
41B0 Exhaust Gas Recirculation -Short Circuit to B+
41B5 Transmission Fluid Temperature Sensor
41BA Exhaust Backpressure Sensor
41BB Exhaust Backpressure Sensor
41C0 Activation -Fan
41C1 Activation -Fan- Short Circuit to B-
41C2 Activation -Fan- Activation Interrupted
41C3 Activation -Fan- Plausibility, Overtemp of Output Stage
41CD Exhaust Backpressure Sensor - Plausibility
41D0 Exhaust Gas Recirculation Regulation
41D1 Exhaust Gas Recirculation -Short Circuit to B-
41D5 Lambda Sensor Bias -Short Circuit to B+
41D6 Lambda Sensor Bias -Short Circuit to B-
41D7 Lambda Sensor Bias -Open Circuit
41E0 Exhaust Gas Recirculation Regulation
41E2 Exhaust Gas Recirculation - Open Circuit
41E3 Exhaust Gas Recirculation -Plausibility, Overtemp of Output Stage
41E5 Lambda Sensor -Short Circuit to B+
41E6 Lambda Sensor -Short Circuit to B-
41E7 Lambda Sensor -Open Circuit
41F0 Electric Ventilator - Short Circuit to B+
41F1 Electric Ventilator - Short Circuit to B-
41F2 Electric Ventilator - Activation Interrupted
41F3 Electric Ventilator - Plausibility, Overtemp of Output Stage
41F5 Lambda Sensor Virtual Earth -Short Circuit to B+
41F6 Lambda Sensor Virtual Earth -Short Circuit to B-
41F7 Lambda Sensor Virtual Earth -Open Circuit
4203 Glow Module Communication
4205 Lambda Sensor Heating -Short Circuit to B+
4206 Lambda Sensor Heating -Short Circuit to B-
4207 Lambda Sensor Heating
420B EGR in Regen Mode
4211 Glow Plug Cyl 1 - Short Circuit to B+
4212 Glow Plug Cyl 1 - Activation Interrupted
4213 Glow Plug Cyl 1 - Plausibility, Overtemp of Output Stage
4217 Lambda Sensor
4221 Glow Plug Cyl 2 - Short Circuit to B+
4222 Glow Plug Cyl 2 - Activation Interrupted
4223 Glow Plug Cyl 2 - Plausibility, Overtemp of Output Stage
4225 Lambda Sensor -Signal
4226 Lambda Sensor -Signal too Low
422A EGR in Regen Mode
4231 Glow Plug Cyl 3 - Short Circuit to B+
4232 Glow Plug Cyl 3 - Activation Interrupted
4233 Glow Plug Cyl 3 - Plausibility, Overtemp of Output Stage
4235 Control Unit Internal 21
4236 Control Unit Internal 21
4241 Glow Plug Cyl 4 - Short Circuit to B+
4242 Glow Plug Cyl 4 - Activation Interrupted
4243 Glow Plug Cyl 4 - Plausibility, Overtemp of Output Stage
4245 Control Unit Internal 22
4246 Control Unit Internal 22
4251 Glow Plug Cyl 5 - Short Circuit to B+
4252 Glow Plug Cyl 5 - Activation Interrupted
4253 Glow Plug Cyl 5 - Plausibility, Overtemp of Output Stage
4258 Control Unit Internal 23
425D Accelerator Pedal Potentiometer Plausibility
4261 Glow Plug Cyl 6 - Short Circuit to B+
4262 Glow Plug Cyl 6 - Activation Interrupted
4263 Glow Plug Cyl 6 - Plausibility, Overtemp of Output Stage
4267 Lambda Sensor Shunt Detection
4271 Glow Plug Cyl 7 - Short Circuit to B+
4272 Glow Plug Cyl 7 - Activation Interrupted
4273 Glow Plug Cyl 7 - Plausibility, Overtemp of Output Stage
4275 Lambda Sensor Heater
4276 Lambda Sensor Heater
4281 Glow Plug Cyl 8 - Short Circuit to B+
4282 Glow Plug Cyl 8 - Activation Interrupted
4283 Glow Plug Cyl 8 - Plausibility, Overtemp of Output Stage
4288 Lambda Sensor Heater
428B Boost Pressure Control of Large Turbo Control Deviation
4293 Control Unit Internal Error 16
4296 Lambda Sensor
4298 Lambda Sensor
429A Boost Pressure Control of Large Turbo Control Deviation
42B5 RPM Control
42C0 Oil Pressure Indicator Lamp - Short Circuit to B+
42C1 Oil Pressure Indicator Lamp - Short Circuit to B-
42C2 Oil Pressure Indicator Lamp - Activation interrupted
42C3 Oil Pressure Indicator Lamp - Plausibility, Overtemp of Output Stage
42D5 Injector Cylinder 7
42D6 Injector Cylinder 7
42D7 Injector Cylinder 7
42D8 Injector Cylinder 7
42E2 Changeover Rail Pressure Control
42F2 Changeover Rail Pressure Control
42F5 Injector Cylinder 8
42F6 Injector Cylinder 8
42F7 Injector Cylinder 8
42F8 Injector Cylinder 8
4302 Quantity Regulation Valve - Activation interrupted
4303 Quantity Regulation Valve - Plausibility, Overtemp of Output Stage
4310 Quantity Regulation Valve - Short Circuit to B+
4321 Quantity Regulation Valve - Short Circuit to B-
4332 Rail Pressure Regulation Valve - Activation Interrupted
4333 Rail Pressure Regulation Valve - Plausibility, Overtemp of Output Stage
4340 Rail Pressure Regulation Valve - Short Circuit to B+
4351 Rail Pressure Regulation Valve - Short Circuit to B-
4360 Rail Pressure Regulation Valve - Current Regulation
4361 Rail Pressure Regulation Valve - Current Regulation
4362 Rail Pressure Regulation Valve - Current Regulation
4373 Air Flow Mass not Plausible
4378 Rail Pressure Regulation Valve - Defect
4382 Rail Pressure Valve Position Test
4390 Boost Air Temperature Sensor - Short Circuit to B+
4391 Boost Air Temperature Sensor - Short Circuit to B-
4392 Boost Air Temperature Sensor
4397 Position Test Volume Adjust Valve
43A0 Start-block Relay
43A1 Start-block Relay
43A2 Start-block Relay
43A3 Start-block Relay
43C0 Throttle Valve Actuator -Short Circuit to B+
43D1 Throttle Valve Actuator -Short Circuit to B-
43E2 Throttle Valve Actuator -Open Circuit
43E3 Throttle Valve Actuator -Plausibility, Overtemp of Output Stage
43F0 Electrical Aux Heater - Short Circuit to B+
43F1 Electrical Aux Heater - Short Circuit to B-
43F2 Electrical Aux Heater - Activation Interrupted
43F3 Electrical Aux Heater - Plausibility, Overtemp of Output Stage
4403 Control Unit Internal Error 17
4410 Injector Cylinder 1- Activation
4411 Injector Cylinder 1- Activation
4412 Injector Cylinder 1- Activation
4413 Injector Cylinder 1- Activation
4417 Control Master/Slave
441C Injector Cylinder 1 - Earth Side Activation or Open Circuit
4420 Injector Cylinder 2- Activation
4421 Injector Cylinder 2- Activation
4422 Injector Cylinder 2- Activation
4423 Injector Cylinder 2- Activation
4428 Control Master/Slave
442C Injector Cylinder 2 - Earth Side Activation or Open Circuit
4430 Injector Cylinder 3- Activation
4431 Injector Cylinder 3- Activation
4432 Injector Cylinder 3- Activation
4433 Injector Cylinder 3- Activation
4438 Control Master/Slave
443C Injector Cylinder 3 - Earth Side Activation or Open Circuit
4440 Injector Cylinder 4- Activation
4441 Injector Cylinder 4- Activation
4442 Injector Cylinder 4- Activation
4443 Injector Cylinder 4- Activation
444C Injector Cylinder 4 - Earth Side Activation or Open Circuit
4450 Injector Cylinder 5- Activation
4451 Injector Cylinder 5- Activation
4452 Injector Cylinder 5- Activation
4453 Injector Cylinder 5- Activation
445C Injector Cylinder 5 - Earth Side Activation or Open Circuit
4460 Injector Cylinder 6- Activation
4461 Injector Cylinder 6- Activation
4462 Injector Cylinder 6- Activation
4463 Injector Cylinder 6- Activation
446C Injector Cylinder 6 - Earth Side Activation or Open Circuit
4473 Control Unit Internal Error 18
4480 Control Unit Internal Error 19
4491 Control Unit Internal Error 20
44A0 Injectors: Activation Cylinder. 1, 2, 3
44A1 Injectors: Activation Cylinder. 1, 2, 3
44A3 Injectors: Activation Cylinder. 1, 2, 3
44AC Injectors: Activation Cylinder. 1, 2, 3
44B0 Injectors: Activation Cylinder. 1, 2, 3
44B1 Injectors: Activation Cylinder. 4, 5, 6
44B3 Injectors: Activation Cylinder. 4, 5, 6
44BC Injectors: Activation Cylinder. 4, 5, 6
44C0 Number of Requested Injections Limited
44C1 Number of Requested Injections Limited
44C2 Number of Requested Injections Limited
44D0 Alternator
44D2 Alternator
44D3 Alternator
44E2 Alternator
44E3 Alternator
44F0 Rail Pressure not Plausible
4500 Exhaust Gas Recirculation- Deviation
4501 Exhaust Gas Recirculation- Negative Deviation or Air Mass too High
4506 Exhaust Gas Recirculation- Deviation
4507 Exhaust Gas Recirculation- Posative Deviation or Air Mass too Low
4512 Thermal Oil Level Sensor
4513 Thermal Oil Level Sensor
4521 Boost Pressure Actuator - Regulation Pressure too High
452A DPF System 4530 Boost Pressure Actuator - Regulation Pressure too Low
4536 Power Management
453B PT Can Bus
453C PT Can Bus
453D PT Can Bus
4541 Thermal Oil Level Sensor
454B Private CAN bus(master)
454C Private CAN bus(master)
454D Private CAN bus(master)
4550 Boost Pressure Modulation 2
4560 Rail Pressure Sensor - Plausibility - Pressure too Low
4570 Rail Pressure not Plausible
4580 Rail Pressure Sensor - Plausibility - Pressure too High
4587 Fuel Filter
4590 Rail Pressure not Plausible
45A0 Rail Pressure Sensor - Plausibility - Pressure too High
45A5 Boost Air Temp Sensor 2- Signal
45A6 Boost Air Temp Sensor 2- Signal
45C0 Rail Pressure not Plausible
45E3 Control Master/Slave
45F2 Control Master/Slave
45F3 Control Master/Slave
4600 Rail Pressure Sensor - Plausibility - Pressure too Low
4605 DPF System
4610 Rail Pressure not Plausible
4618 DPF -Plausibility -Pressure Reference
4620 Rail Pressure Sensor - Plausibility - Pressure too High
4628 DPF System
4630 Rail Pressure not Plausible
4640 Rail Pressure not Plausible
4645 EGR Controller
4650 Rail Pressure not Plausible
4656 Control Unit Internal 24
4660 Power Supply
4661 Power Supply
4665 DPF Bank 1
4666 DPF Bank 1
4667 DPF Bank 1
4670 Power Supply 1 - Short Circuit to B+
4671 Power Supply 1 - Short Circuit to B-
4677 Throttle Valve Actuator
4680 Power Supply 2 - Short Circuit to B+
4681 Power Supply 2 - Short Circuit to B-
4687 Throttle Valve Actuator
4690 Power Supply
4691 Power Supply
4697 Throttle Valve Actuator
46A0 Control Unit Internal Error 1
46A1 Control Unit Internal Error 1
46A2 Control Unit Internal Error 1
46A3 Control Unit Internal Error 1
46A7 Swirl Flap Actuator
46B0 Control Unit Internal Error 2
46B1 Control Unit Internal Error 2
46B2 Control Unit Internal Error 2
46B3 Control Unit Internal Error 2
46B7 Swirl Flap Actuator
46C0 Control Unit Internal Error 3
46C1 Control Unit Internal Error 3
46C2 Control Unit Internal Error 3
46C3 Control Unit Internal Error 3
46C7 Swirl Flap Actuator
46D0 Control Unit Internal Error 4
46D1 Control Unit Internal Error 4
46D2 Control Unit Internal Error 4
46D3 Control Unit Internal Error 4
46D5 Compressor Bypass Activation
46D6 Compressor Bypass Activation
46D7 Compressor Bypass Activation
46D8 Compressor Bypass Activation
46E0 Control Unit Internal Error 5
46E1 Control Unit Internal Error 5
46E2 Control Unit Internal Error 5
46E3 Control Unit Internal Error 5
46E5 Wastegate Valve Activation
46E6 Wastegate Valve Activation
46F0 Control Unit Internal Error 6
46F1 Control Unit Internal Error 6
46F2 Control Unit Internal Error 6
46F3 Control Unit Internal Error 6
4700 Control Unit Internal Error 7
4701 Control Unit Internal Error 7
4702 Control Unit Internal Error 7
4703 Control Unit Internal Error 7
4707 Wastegate Valve Activation
4708 Wastegate Valve Activation
4710 Control Unit Internal Error 8
4711 Control Unit Internal Error 8
4712 Control Unit Internal Error 8
4713 Control Unit Internal Error 8
4720 Control Unit Internal Error 9
4721 Control Unit Internal Error 9
4722 Control Unit Internal Error 9
4723 Control Unit Internal Error 9
4730 Quantity Regulation Current Regulation
4731 Quantity Regulation Current Regulation
4732 Quantity Regulation Current Regulation
4740 Control Unit Internal Error 11
4747 Injectors - Amplifier Adjustment(control unit internal)
4750 Control Unit Internal Error 12
4753 Control Unit Internal Error 12
475A Exhaust Backpressure Sensor- Bank 2
475B Exhaust Backpressure Sensor- Bank 2
4763 Control Unit Internal Error 13
4765 Injector Cyl 1 - Activation
4766 Injector Cyl 1 - Activation
4767 Injector Cyl 1 - Activation
4768 Injector Cyl 1 - Activation
476A Injector Cyl 4/5/6 Buffer Voltage Measurement(control unit internal)
476B Injector Cyl 4/5/6 Buffer Voltage Measurement(control unit internal)
4770 Control Unit Internal Error 14
4771 Control Unit Internal Error 14
4772 Control Unit Internal Error 14
4773 Control Unit Internal Error 14
477C Injectors Activation Duration(control unit internal)
4780 Control Unit Internal Error 15
4781 Control Unit Internal Error 15
4782 Control Unit Internal Error 15
4783 Control Unit Internal Error 15
4785 Injector Cyl 2 - Activation
4786 Injector Cyl 2 - Activation
4787 Injector Cyl 2 - Activation
4788 Injector Cyl 2 - Activation
478C Injector Activation Duration(control unit internal)
4792 Monitoring Master/Slave
4793 Monitoring Master/Slave
4795 Injector Cyl 3 - Activation
4796 Injector Cyl 3 - Activation
4797 Injector Cyl 3 - Activation
4798 Injector Cyl 3 - Activation
47A5 Injector Cyl 4 - Activation
47A6 Injector Cyl 4 - Activation
47A7 Injector Cyl 4 - Activation
47A8 Injector Cyl 4 - Activation
47AB Private CAN Bus(Slave)
47AC Private CAN Bus(Slave)
47AD Private CAN Bus(Slave)
47B5 Injector Cyl 5 - Activation
47B6 Injector Cyl 5 - Activation
47B7 Injector Cyl 5 - Activation
47B8 Injector Cyl 5 - Activation
47BB Power Train CAN Bus(Slave)
47BC Power Train CAN Bus(Slave)
47BD Power Train CAN Bus(Slave)
47C5 Injector Cyl 6 - Activation
47C6 Injector Cyl 6 - Activation
47C7 Injector Cyl 6 - Activation
47C8 Injector Cyl 6 - Activation
47D5 Injector Cyl 7 - Activation
47D6 Injector Cyl 7 - Activation
47D7 Injector Cyl 7 - Activation
47D8 Injector Cyl 7 - Activation
47E5 Injector Cyl 8 - Activation
47E6 Injector Cyl 8 - Activation
47E7 Injector Cyl 8 - Activation
47E8 Injector Cyl 8 - Activation
47F8 Message : Seat Occupancy Sensor/Belt Buckle
4803 Torque Control ACC
480A DPF -Bank 1
4810 Torque Control ACC
481A DPF -Bank 1
4830 Intake Air Temperature Sensor
4831 Intake Air Temperature Sensor
483D Throttle Actuator
4841 Exhaust Gas Recirculation Regulation 2
484A Accelerator Pedal Potentiometer -Signal
4850 Exhaust Gas Recirculation Regulation 2
4857 Swirl Flap Actuator
4863 Vehicle Speed Regulation
4867 Swirl Flap Actuator
486D Control Unit Software Fault
4877 Swirl Flap Actuator
487A Lambda Sensor Bank 2 - Bias Voltage
487B Lambda Sensor Bank 2 - Bias Voltage
487C Lambda Sensor Bank 2 - Bias Voltage
4887 Swirl Flap Actuator
488A Lambda Sensor Bank 2 - Pump Current
488B Lambda Sensor Bank 2 - Pump Current
488C Lambda Sensor Bank 2 - Pump Current
4896 Swirl Flap Actuator
489A Lambda Sensor Bank 2 - Virtual Ground
489B Lambda Sensor Bank 2 - Virtual Ground
489C Lambda Sensor Bank 2 - Virtual Ground
48A2 CAN Communication with ASC
48A3 CAN Communication with ASC
48B2 CAN Communication with ASC
48B3 CAN Communication with ASC
48B5 Injectors Voltage Measurement(control unit internal)
48B6 Injectors Voltage Measurement(control unit internal)
48B7 Injectors Voltage Measurement(control unit internal)
48BC Lambda Sensor Bank 2
48C2 CAN Communication with EGS
48C5 Injectors Voltage Measurement(control unit internal)
48C6 Injectors Voltage Measurement(control unit internal)
48C7 Injectors Voltage Measurement(control unit internal)
48CA Lambda Sensor Bank 2
48CB Lambda Sensor Bank 2
48D2 CAN Communication with Instrument Cluster
48D3 CAN Communication with Instrument Cluster
48DA Control Unit Internal 25
48DB Control Unit Internal 25
48EA Control Unit Internal 26
48EB Control Unit Internal 26
48F2 CAN BUS Hardware
48F3 CAN BUS Hardware
48F7 Injectors Wiring Loom
48FD Control Unit Internal 27
4900 DSC Torque Intervention
4907 Injectors Selector Switch(control unit internal)
490B Control Unit Internal 28
4912 CAN BUS Hardware Defect in Operation
4913 CAN BUS Hardware Fault in Initialisation
4917 Injectors Charge Switch(control unit internal)
4920 Transmission Link
4925 Throttle Valve Actuator 2 Activation
492A Lambda Sensor Bank 2 Heater
492B Lambda Sensor Bank 2 Heater
4936 Throttle Valve Actuator 2 Activation
493D Lambda Sensor Bank 2
4947 Throttle Valve Actuator 2 Activation
4948 Throttle Valve Actuator 2 Activation
494D Lambda Sensor Bank 2
4957 Throttle Valve Actuator 2
495A Exhaust Temp Sensor before DPF Bank 2
495B Exhaust Temp Sensor before DPF Bank 2
4967 Throttle Valve Actuator 2
496A DPF Bank 2
497A DPF Bank 2
4991 Message : Instrument Cluster
4992 Message : Instrument Cluster
4997 Throttle Valve Actuator 2
49A2 Message : Ambient Temperature
49A3 Message : Instrument Cluster
49B0 Message : Torque Request
49C0 Message : Torque Request
49D2 Message : Torque Request
49E0 Message : Torque Request
49E7 Throttle Actuator
49F2 Message : Vehicle Speed
49F3 Message : Vehicle Speed
4A02 Terminal 15
4A03 Terminal 15
4A07 Alternator
4A08 Alternator
4A10 BSD Interface
4A13 BSD Interface
4A15 Alternator
4A17 Alternator
4A18 Alternator
4A22 Boost Air Pressure Actuator 2 Activation
4A23 Boost Air Pressure Actuator 2 Activation
4A25 Intelligent Battery Sensor
4A27 Intelligent Battery Sensor
4A28 Intelligent Battery Sensor
4A30 Multifunction Steering Wheel- Toggle Bit
4A31 Multifunction Steering Wheel- Frequency Counter
4A32 Multifunction Steering Wheel- No Signal
4A33 Multifunction Steering Wheel- Signal not Plausible
4A35 Intelligent Battery Sensor
4A37 Intelligent Battery Sensor
4A38 Intelligent Battery Sensor
4A41 EWS Interface
4A42 EWS Interface
4A43 EWS Interface
4A45 Intelligent Battery Sensor
4A47 Intelligent Battery Sensor
4A48 Intelligent Battery Sensor
4A50 EWS Code Storage
4A51 EWS Code Storage
4A56 Power Management Battery
4A58 Power Management Battery
4A60 EWS Manipulation
4A61 EWS Manipulation
4A62 EWS Manipulation
4A63 EWS Manipulation
4A65 Power Management Vehicle Electrical System
4A66 Power Management Vehicle Electrical System
4A67 Power Management Vehicle Electrical System
4A70 Reference Values Incorrect
4A80 Intake Air Hose
4AA2 CAN Communication with EGS
4AA3 CAN Communication with EGS
4AB0 Electrical Aux Heater
4AD5 Zero Quantity Adaptation Injector 1
4AD6 Zero Quantity Adaptation Injector 1
4AE0 E-Box Ventilator -Short circuit to B+
4AE1 E-Box Ventilator -Short circuit to B-
4AE2 E-Box Ventilator -Activation Interrupted
4AE3 E-Box Ventilator -Plausibility, Overtemp of Output Stage
4AE5 Zero Quantity Adaptation Injector 2
4AE6 Zero Quantity Adaptation Injector 2
4AF0 Control Unit Temperature Sensor
4AF1 Control Unit Temperature Sensor
4AF5 Zero Quantity Adaptation Injector 3
4AF6 Zero Quantity Adaptation Injector 3
4B00 Control Unit Temperature
4B05 Zero Quantity Adaptation Injector 4
4B06 Zero Quantity Adaptation Injector 4
4B10 Smooth Running Regulation -Correction Quantity too High
4B11 Smooth Running Regulation -Correction Quantity too Low
4B15 Zero Quantity Adaptation Injector 5
4B16 Zero Quantity Adaptation Injector 5
4B20 Electro ventilator -Blocked
4B22 Electro Ventilator
4B25 Zero Quantity Adaptation Injector 6
4B26 Zero Quantity Adaptation Injector 6
4B35 Oil Sensor
4B36 Oil Sensor
4B37 Oil Sensor
4B38 Oil Sensor
4B45 Injector Cyl 1 Energy Consumption Measurement
4B50 Quantity Compensation
4B55 Injector Cyl 2 Energy Consumption Measurement
4B60 Quantity Compensation
4B65 Injector Cyl 3 Energy Consumption Measurement
4B75 Injector Cyl 4 Energy Consumption Measurement
4B80 Rail Pressure not Plausible
4B85 Injector Cyl 5 Energy Consumption Measurement
4B90 Rail Pressure Control at Engine Start
4B95 Injector Cyl 6 Energy Consumption Measurement
4BA0 Intake Air Temperature Sensor -Signal too High or Short
4BA1 Intake Air Temperature Sensor -Signal too Low
4BB0 Air Flow Sensor Power Supply
4BB1 Air Flow Sensor Power Supply
4BB5 Air Flow Meter -Signal too Low
4BB6 Air Flow Meter -Signal too High
4BC0 Air Flow Meter -Signal too Low
4BC1 Air Flow Meter -Signal too High
4BC2 Air Flow Meter -Short Circuit
4BC5 Intake Air Temperature Sensor
4BC6 Intake Air Temperature Sensor
4BC7 Intake Air Temperature Sensor
4BD2 ARS Torque Request
4BD5 Engine Support
4BD6 Engine Support
4BD7 Engine Support
4BD8 Engine Support
4BE2 Message : Transmission data
4BE7 Message : Transmission data 2
4BF2 Message : Air Conditioning
4BF3 Message : Independent Heater
4BF7 Message : Range
4C00 Message : Cruise Control
4C01 Message : Cruise Control
4C02 Message : Cruise Control
4C03 Message : Column/Wheel Switches
4C06 Message : ARS Status
4C07 Message : ARS Status
4C12 Message : DSC Status
4C15 Message : Terminal 15
4C16 Message : Terminal 15
4C17 Message : Terminal 15
4C18 Message : CAS
4C20 Message : DSC Torque
4C21 Message : DSC Torque
4C22 Message : DSC Torque
4C23 Message : DSC Torque
4C27 Message : Vehicle Speed
4C28 Message : Vehicle Speed
4C45 Injector Cyl 7 Energy Consumption Measurement
4C55 Injector Cyl 8 Energy Consumption Measurement
4C65 Zero Quantity Adaptation Injector 7
4C66 Zero Quantity Adaptation Injector 7
4C75 Supply Voltage Air Mass Flow Sensor 2
4C76 Supply Voltage Air Mass Flow Sensor 2
4C95 Zero Quantity Adaptation Injector 8
4C96 Zero Quantity Adaptation Injector 8
4CA2 Message : Power Management
4CB2 Message : Power Management
4CB3 Message : Power Management
4CF3 DPF -Plausibility -Exhaust Gas Pressure
4D00 Exhaust Backpressure Sensor Bank 1
4D03 Exhaust Backpressure Sensor Bank 1
4D25 Exhaust Temp Sensor before Catalytic Converter Bank 2
4D26 Exhaust Temp Sensor before Catalytic Converter Bank 2
4D45 Exhaust Temp Sensor before DPF Bank 2
4D46 Exhaust Temp Sensor before DPF Bank 2
4D56 DPF Bank 2
4D65 DPF System
4D75 DPF System
4D81 Boost Pressure Actuator 2 Activation
4D98 Exhaust Backpressure Sensor Bank 2
4DA3 Boost Pressure Control
4DA5 Exhaust Backpressure Sensor Bank 2
4DA8 Exhaust Backpressure Sensor Bank 2
4DB0 EGR Controller 2 Activation
4DC1 EGR Controller 2 Activation
4DD2 EGR Controller 2 Activation
4DD3 EGR Controller 2 Activation
4DD5 Exhaust Temp Sensor before DPF Bank 2
4DE0 Monitoring Master/Slave - Private CAN
4DE1 Monitoring Master/Slave - Private CAN
4DE3 Monitoring Master/Slave - Private CAN
4DF0 Message : Transmission Torque
4DF1 Message : Transmission Torque
4DF2 Message : Transmission Torque
4DF3 Message : Transmission Torque
4DF5 Exhaust Temp Sensor before DPF Bank 2
7073 Automatic Gearbox Switch Signal
CD87 CAN Bus Communication Error
CD8B CAN Bus -Control Module has Left the Bus
msakac33
BMW ABS fault codes.
ABS 1
1 ABS Hydraulic Unit
2 TPS
3 Ignition Timing Error
4 Rear Left Speed Sensor or ABS Inlet Valve
5 Rear Right Speed Sensor or ABS Inlet Valve
6 Front Right Speed Sensor or ABS Inlet Valve
7 Front Left Speed Sensor or ABS Inlet Valve
8 Rear Left ABS Valve
9 Rear Right ABS Valve
10 Front Right ABS Valve
11 Front Left ABS Valve
12 EGS Intervention
13 Idle Speed RPM Increasing
14 Valve Relay Fault
15 ABS Delivery Pump Fault
16 Throttle Valve Reduction
17 Front Left Wheel Sensor
18 Front Left Wheel Sensor
19 Accumulator -Pressure Limit
20 Front Left Wheel Sensor or EGS-Intervention Error
21 Front Left Wheel Sensor or ABS/ASC ECU Fault
22 Speed Sensor Signal
23 Equipment ERROR (Automatic/Manual)
24 Incorrect Pulse Generator
25 Brake Light Switch
27 Idle Speed Signal
30 Left Rear Wheel Speed Sensor Cable
31 Right Rear Wheel Speed Sensor Cable
32 Right Front Wheel Speed Sensor Cable
33 Left Front (E38/E39) or Right (E46) Wheel Speed Sensor Cable
34 Front Right Wheel Sensor or ASC Switch Over Valve
35 Brake Fluid Level Signal
36 Front Right Wheel Sensor or Ignition Signal Error
37 Front Right Wheel Sensor or ABS/ASC Control Unit -Internal Error
38 Gas Valve Adjustment Error
39 Servo Motor - Electrical Error
40 Gas Valve - Potentiometer Error
41 Steering Angle Sensor Error
47 Outlet Valve - Rear Left
48 Outlet Valve - Rear Right
49 Wheel Sensor - Rear Left or Outlet Valve - Front Right
50 Wheel Sensor - Rear Left or Outlet Valve - Front Left
51 Inlet Valve - Rear Left
52 Wheel Sensor - Rear Left or Inlet Valve - Rear Right
53 Wheel Sensor - Rear Left or Inlet Valve - Front Right
54 Inlet Valve - Front Left
55 ASC Shutoff Valve
56 CAN ERROR (Short Circuit)
57 Throttle Valve Signal from DME
58 CAN ERROR (Open Circuit)
59 ASC Shutoff Valve
60 Signal Fault - Pin 30
61 Central Wheel-Blocking
62 Max Anti Blocking Adjustment Time
63 Processor Fault ECU
64 Continuous Control due to Undefined Signal Interference
65 Wheel Sensor - Rear Right or Feedback Signal
66 Wheel Sensor - Rear Right or Wheel Speed Sensor Power Supply
67 CAN ERROR
68 Wheel Sensor - Rear Right
69 Wheel Sensor - Rear Right
70 Error 70
75 ASC Indication Lamp
81 Inlet Valve Front Left
82 Inlet Valve Front Right
83 Inlet Valve Rear Left
84 Inlet Valve Rear Right
85 Outlet Valve Front Left
86 Outlet Valve Front Right
87 Outlet Valve Rear Left
88 Outlet Valve Rear Right
89 Power Supply Low
90 TimeOut - Passive Switching
91 CAN ERROR
92 Pressure Sensor Pre Charge Pump
94 RPM Sensor (Test)
95 Activation
96 Actuator Test
97 ASC Intake Valve / Steering Angle Sensor
98 Separate Valve
99 Electro Magnetic Switch Over Valve
100 Electro Magnetic Switch Over Valve
103 Brake Light Switch
104 Steering Angle Sensor
105 Brake Light Switch
106 Lateral Acceleration Sensor
107 RPM sensor (Gradient)
113 ABS /ASC Feed Back Pump
115 ABS/ASC Control Unit - Internal Error
118 Electromagnetic or Mechanical Interference -Wheel Speed Signals
120 Power Supply too High (> 18V)
129 ABS/ASC Main Relay Circuit
130 Power Supply - Solenoid Valves
131 Wrong Current - Solenoid Valves
133 Power Supply - too High
145 CAN chip in the ABS/ASC control unit
146 CAN ERROR
147 CAN ERROR - Engine Intervention
148 CAN ERROR - Engine speed (RPM)
149 CAN ERROR - DME/DDE connection
150 CAN ERROR - EGS
151 Coding Error
152 DSC Button
161 RPM Sensor
162 RPM Signal
163 Lateral Acceleration Sensor
164 Lateral Acceleration Sensor
165 Pressure Sensor 1
166 Pressure Sensor 2
167 Pressure Sensors
168 Pressure Sensors Power Supply
177 Pre Charge Pump
178 Pre Charge Pump
180 Steering Angle Sensor -Signal 1
181 Steering Angle Sensor -Identification
182 Steering Angle Sensor -CAN
183 Steering Angle Sensor -Internal
184 Steering Angle Sensor -Offset
msakac33
Nedeľa, 6. Apríla 2014, 14:16
ABS 2
2 EML Interface Fault
3 DME Interface Fault
4 Sensor Fault Rear Left
5 Sensor Fault Rear Right
6 Sensor Fault Front Right
7 Sensor Fault Front Left
8 ABS Valve Fault Rear Left
9 ABS Valve Fault Rear Right
10 ABS Valve Fault Front Right
11 ABS Valve Fault Front Left
12 Solenoid Valve Fault Rear Left
13 Solenoid Valve Fault
14 ABS Valve Relay Fault
15 Rear Feed Pump Fault
16 ASC+T Storage Valve Fault
17 Wheel Sensor / Inlet Valve Front Left
18 Wheel Sensor / Outlet Valve Front Left
20 Wheel Sensor / Inlet Valve Front Right
24 Wheel Sensor / Outlet Valve Front Right
33 Wheel Sensor / Inlet Valve Rear Left
34 Wheel Sensor / Outlet Valve Rear Left
36 Inlet Valve Rear Right
37 Front Right Wheel Speed Sensor
40 Rear Output Valve
49 Power Supply Solenoids
50 Throttle Valve Mechanical Fault
56 ASC Separator Valve Fault
65 ASC Computer Fault
66 DME RPM signal Fault
68 Control Unit Defect
72 Internal Fault
81 Speed Sensor Front Left Connection
82 Speed Sensor Front Right Connection
84 Speed Sensor Rear Left Connection
88 Speed Sensor Rear Right Connection
97 Speed Signal Front Left
98 Speed Signal Front Right
100 Speed Signal Rear Left
104 Speed Signal Rear Right
113 Speed Information Front Left
114 Speed Information Front Right
116 Speed Information Rear Left
120 Speed Information Rear Right
129 DME Connection
130 TPS
132 Brake Pedal Travel Sensor
133 Valve Power Supply too High
136 Brake Hydraulics -Quality
145 Hydro Pump Failure
146 Coding Faulty
148 Motor Temperature over CAN bus
152 Brake Pedal Travel Sensor -Hydraulics
161 Outlet Valve Front Left or Front Left Wheel Sensor
162 Outlet Valve Front Right or Front Right Wheel Sensor
164 Rear Left Output Valve or Rear Left Wheel Sensor
168 Rear Right Output Valve or Rear Right Wheel Sensor
177 Valve Power Failure
184 CAN ERROR
193 DME Ignition Signal
255 Accumulator Fault
msakac33
ABS 3
5D90 Left Front Wheel Speed Sensor : Accident Recognition
5D91 Left Front Wheel Speed Sensor : Extrapolation
5D92 Left Front Wheel Speed Sensor : Periodical Control
5D93 Left Front Wheel Speed Sensor : Accident Recognition
5D94 Left Front Wheel Speed Sensor : Long Term Control
5DA0 Right Front Wheel Speed Sensor : Accident Recognition
5DA1 Right Front Wheel Speed Sensor : Extrapolation
5DA2 Right Front Wheel Speed Sensor : Periodical Control
5DA3 Right Front Wheel Speed Sensor : Accident Recognition
5DA4 Right Front Wheel Speed Sensor : Long Term Control
5DB0 Left Rear Wheel Speed Sensor : Accident Recognition
5DB1 Left Rear Wheel Speed Sensor : Extrapolation
5DB2 Left Rear Wheel Speed Sensor : Periodical Control
5DB3 Left Rear Wheel Speed Sensor : Accident Recognition
5DB4 Left Rear Wheel Speed Sensor : Long Term Control
5DC0 Right Rear Wheel Speed Sensor : Accident Recognition
5DC1 Right Rear Wheel Speed Sensor : Extrapolation
5DC2 Right Rear Wheel Speed Sensor : Periodical Control
5DC3 Right Rear Wheel Speed Sensor : Accident Recognition
5DC4 Right Rear Wheel Speed Sensor : Long Term Control
5DF0 Pump Motor
5DF2 Internal Error, Valve/ECU Hardware Error, ROM/RAM Check
5DF4 Power Supply too Low
5DF5 Control Unit Internal Error
5DF7 Power Supply too High
5E00 Tyre Test Active
5E01 Tyre Test Timeout
5E02 Tyre Test Gyration Sensor Justification Error
5E03 Tyre Test Gyration Sensor Error
5E04 Tyre Test Lateral Acceleration Sensor Error
5E05 Tyre test Lateral Acceleration Sensor Error and Gyration Sensor
5E06 Tyre Test Gyration Sensor Fault
5E07 Tyre Test Lateral Acceleration Sensor Error and Gyration Sensor Fault
5E08 Tyre Test Steering Angle Sensor Error
5E11 Internal Error CAN-Controller
5E14 CAN Timeout DME/DDE
5E15 CAN Timeout EGS
5E16 CAN Timeout Instrument Cluster
5E18 CAN DME/DDE Message
5E19 CAN DME/DDE Torque Reduction Not Possible
5E1A CAN DME/DDE Signal Error
5E1E CAN Timeout LWS
5E1F Steering Angle Sensor - not Initialised
5E20 Pressure Sensor 1
5E21 Pressure Sensor 2
5E24 Pressure Sensor 1/2 not Plausible
5E26 Sensor Power Supply
5E2F Temperature Sensor
5E30 Lateral Acceleration Sensor
5E32 Lateral Acceleration Signal not Plausible
5E38 Wheel Speed Sensor
5E3C Wheel Speed not Plausible
5E40 Lateral Acceleration Signal not Plausible, Offset
5E43 Lateral Acceleration Internal Error
5E4E DSC Sensor Offset Check
5E4F Long Time Regulation DSC
5E59 Coding Error
5E5B Switch Pressed Longer than 10s or Faulty
5E5D Brake Fluid Level Switch
5E5E Brake Light Switch
