Re: E60 reset intervalu prednych brzd - problem
Pondelok, 3. Februára 2014, 21:34
m4x napísal:
Ok a ked vymenim ten snimac ako by som mal postupovat na reset intervalu?
The system looks for two "untriggered" sensors when you reset the brake service mileage. If it sees even the preliminary trigger on any of the sensors it will give you this error. The preliminary trigger as stated above does not mean that there is no brake pad left. In my case the front pads had at least a little under 50% life left in them and therefore I did not replace them or the sensor. So this is what I did to fix it.
I took the old sensor I just removed from the rear and cut of the sensor portion. I then stripped the two wires back and twisted them together which creates a short and mimicks the reading a new sensor gives. Unplug the partially used sensor at the socket connection on the car (not the brake) and plug in the shorted old sensor. Do the brake reset procedure and you will get the appropriate mileage restored. Go back and remove the shorted sensor and plug back in the partially used sensor. At this point everything should be back to normal with the new sensor showing 90,000 miles and the partially used sensor showing whatever miles that were there before you created the error.
Hopefully this helps you. I think you should be able to use this procedure to reset the front or rear sensor one at a time without having to replace both sensors.
Pondelok, 3. Februára 2014, 22:36
Aaaaa zase som o nieco mudrejsi,to by ma nenapadlo::)))Diky
tomas.ss
Registrovaný: 5.2.2011
Auto: BMW 520i
Nedeľa, 18. Januára 2015, 16:58
Tiez som mal ten isty problem a VYRIESENE!!!!
staci kupit jeden napr.predny sensor....ten stary odstrihnut spojit kabliky dokopy a znovu ho nasadit...a vyskusat reset...ukaze to okolo 500000km na predne....potom nahodit novy a je to....
peter9898
Registrovaný: 9.12.2012
Auto: BMW 530xd f10 2016
Nedeľa, 25. Októbra 2015, 22:31
Cize ak ten postup chapem spravne, tak treba
1.) splasit nejaky stary senzor, ktory prestrihnem.
2.) Vyskratujem a pripojim stary senzor do konektora auta pricom s novym senzorom nerobim nic a necham ho zapchaty v brzde.
3.) Po pripojeni vyskratovaneho zresetujem interval v iDrive.
4.) Vypnem auto a znovu len pripojim novy senzor, ktory je namontovany na brzdach ..
Spravne :D ? Trosku jak pre debilov ale aby som nahodou daco nedos*al..
Dik
BMW 530d xDrive F10 A/T, r. v.: 2016, LCI
ex BMW 530d (e60) A/T, r. v.: 2007, LCI
zsozso111
Registrovaný: 20.6.2020
Auto: BMW E60
Streda, 9. Septembra 2020, 19:27
Reset po červenéj výstrahe ktrorá sa už nedá vynulovať BMW E60 (Problém vyriešení)
Postup : 1_ Palubný počítač ukazuje červenú ikonu zadných brzd aj po resetovaní
2_ Daj na hever odmontuj pravé zadne koleso (lavé zadné zaisti klinom)
3_ Otvor kryt na konektory (čierná krabička veľkosti starých iphonov)
4_ Odpoj (starý alebo nový) konektor čidla brzdy
5_ Nastrihni si vodivý drot dlžky 15cm a nastrč ich do konektoru ktorá ide od vozidla do (+) a do (-) proste tak aby si spravil skrat. Všetko robíme pri vypnutom zapalovaní !
6_ Zapni zapalovanie, vynuluj na palubnom počítači interval výmeny zadných brzd. Červená výstraha by mala zmiznúť. Vypni zapalovanie, napoj nový snímač.
7_ Hotovo ! Červena výstraha sa zmení na oranžovú interval naskočí na 50 000 km. Hláška zmizne až do nasledujúcej výmeny.
8_ Veľa Štastia !
Naposledy upravil/-a zsozso111 v Štvrtok, 21. Júla 2022, 20:38, upravené celkom 1 krát.
spacewerk
Registrovaný: 19.5.2019
Auto: 528i,530d,535d,650i
Sobota, 9. Januára 2021, 22:15
Mohu potvrdit, funguje to....
U mě rovnež červená porucha, po výměně desek a nového čidla reset nepomohl, musel jsem udělat zmíněný postup, za který tímto děkuji !!!! FUNGUJE !!!
300C 5.7 HEMI AWD
E63 650i At
E60 535D At
E60 530D Mt
E39 528i Mt
Y60 RD28T Mt
ex. S2, S1,B5, ARO243, O1, Fanous
zsozso111
Auto: BMW E60
Sobota, 9. Januára 2021, 22:23
Hold zdar ! Rado sa stalo !
