Moderátor: voMacK
david456
Registrovaný: 6.3.2025
Auto: bmw g20
Rozdielny dezen pri xdrive
Štvrtok, 6. Marca 2025, 20:22
Cauko,Moze dojst poskodeniu Xdrive pri rozdielnom dezene pneu (zadne pneu maju 6,90mm a predne 4,99mm a 6,15mm)Mam pneu vymenit alebo nechat tak?
Observer
Registrovaný: 25.6.2018
Auto: naftove
Re: Rozdielny dezen pri xdrive
Piatok, 7. Marca 2025, 07:48
Áno, rozhodne to moze poškodiť xDrive, treba vymeniť pneu tak, aby bola výška dezénu rovnaká.
Piatok, 7. Marca 2025, 08:19
Pozor,niekedy nejde tak ani o vysku dezenu ako o vysku kolesa/obvod. Nie vsetci vyrobcovia vedia garantovat v dvojrozmere aj tuto vlastnost.. Odporucam premerat…
Inak ak je vyssi zadok nerobi to problemy,ako ked je vyssi predok….
bmwg31
Registrovaný: 25.3.2024
Auto: bmw g31
Sobota, 8. Marca 2025, 08:16
Observer napísal:
Pochopil by si som, keby celkový rozdiel v obvode kolesa je 1 cm , ale rozdiel 1 mm môže poškodiť xdrive ? 😅
Sobota, 8. Marca 2025, 12:01
Nie….bmw pise toleranciu 2-3mm….Na vyske dezenu…co je 4-6mm na vyske kolesa….
Naposledy upravil/-a TT-SIMIK v Sobota, 8. Marca 2025, 12:36, upravené celkom 2 krát.
xener
Registrovaný: 15.5.2016
Auto: biele, sede, modre
Sobota, 8. Marca 2025, 12:02
bmwg31 napísal:
ujasni si pojmy obvod a priemer
Sobota, 8. Marca 2025, 12:33
  • Compliance with the following requirements is required when exchanging wheels between the axles:
    • Tyre size and rim size identical on front and rear axle
    • Assess the wear pattern
    • The tread difference between the front and rear wheels must not exceed a maximum of 2-3 mm
    • Exchange the wheels between the axles every 5000 Km
Additionally for all-wheel drive vehicles:
  • The tyre size, manufacturer and tyre tread must be identical on all wheels; different tyre sizes between front and rear axles are only permissible if mixed tyres are fitted.
  • The tyre tread difference between tyres in all wheel positions must not exceed 2 mm (normal quality of the wheel control systems and wheel alignment requirement
david456
Auto: bmw g20
Sobota, 8. Marca 2025, 14:30
tak co myslite,mam vymenit pneu ?Kupoval som elektrony r19 s pneu na bmw g20 a boli tam tie pneumatiky
