Moderátor: voMacK
bmitrovcak
Registrovaný: 9.2.2011
Auto: BMW 530D Touring
Studeny start - turbo - F11LCI 520xd 2015
Nedeľa, 18. Februára 2018, 13:06
Zdravim, pri studenom starte na volnobehu ked pridam pocut zvuk ako vo videu. Po prejdeni cca500 uz absolutne tichucko ide turbo. Je to ok ?
https://youtu.be/Wo-H6iZyb9w
DANOOOOO
Registrovaný: 16.11.2019
Auto: BMW 520D (F10)
Re: Studeny start - turbo - F11LCI 520xd 2015
Štvrtok, 9. Júla 2020, 20:36
Na mojej F10 to iste len v zime
filipbielik
Registrovaný: 20.7.2017
Auto: 525xD F11 (LCI)
Utorok, 14. Júla 2020, 08:21
clanok bol pisany v 02 / 2018, takze aj v jeho pipade a ja to tiez mozem len potvrdit... aj na 520 F11 aj na 525 F11 take iste chovanie turba, a na 520 mi to tak fungovalo vyse 4 rokov, potom som auto predal a vymenil za 525, takze dalej neviem ako to dopadlo.. ale aj v servise mi vraveli ze turbo je v poriadku, ked som to niesol na kontrolu, takze zrejme bezne chovanie
BMW 525xD F11 (LCI) | 160 kW A/T | 7/2014 | Luxury Line
» Imperial-blau brillant metallic & Leather Dakota/zimt-braun & BMW Style 454
» Harman&Kardan Sound, Panorama, Front & Rear Heat Seating, HUD, Navigation w/ RTI, DAB Tuner, Adaptive LED Light, High Beam Assistant, PDC, Tyre Pressure Display, Oil Monitor, Sports Leather Steering Wheel, Road Sign Detection, Active Pedestrian Protection, Trailer Coupling, Interior Mirror w/ Automatic-Dip, Ambient Light, Lumbar Support
