vladoslavo
Registrovaný: 8.11.2012
Auto: E61, 525 d, LCI
Brake flap control
Utorok, 5. Augusta 2014, 15:22
Pani, co su klapky na privod vzduchu k brzdam, ked sa auto nastartuje, maju sa zavriet a hned otvorit?
Re: Brake flap control
Utorok, 5. Augusta 2014, 16:19
Brake flap to je cas dsc systemu.....ziadny privod vzduchu!!!:)))))
vladoslavo
Utorok, 5. Augusta 2014, 16:33
TT-SIMIK napísal:
a neni su to tie klapky na to privode vzduchu ku brzdam?
Utorok, 5. Augusta 2014, 21:09
V tuneli k bzdam nieje nic take ani na aute pokial mi je zname,zaluzie pred chladicom su ina vec.....
vladoslavo
Utorok, 5. Augusta 2014, 21:17
TT-SIMIK napísal:
Simik, osobne ta povazujem za jedneho z najschopnejsich mechanikov pre BMW co poznam, ale naco je podla teba toto, vid obr v prilohe, polozka cislo 3 ... ta 3jka mala na diagnostike zapisanu chybu, po vymazani sa uz nezopakovala ...
Utorok, 5. Augusta 2014, 22:22
díky....vidíš ešte som taketo niečo nikdy na aute čo bolo u mna nikdy nevidel...)))))moja chyba....mal som si to čeknut........))))
Active brake air flap control
The active brake air flap control improves the aerodynamics of the vehicle. A reduction in the CO2emissions is achieved in this way. Depending on the engine variant and optional extra, the brake air flap control system is fitted in the vehicle.
Brief description of components
The system consists of:
•2 brake air flaps with 2 Hall sensors
•Vacuum supply with 2 partial-vacuum canisters
•Switchover valve
The two brake air flaps are fitted down in the vehicle bumper. The switchover valve is attached to the left-hand spring strut dome.
The brake air flaps are activated by partial vacuum. The vacuum pump on the engine generates this partial vacuum. The partial vacuum is applied to a partial-vacuum canister on the housing of the brake air flap.
Index
Explanation
Index
Explanation
1
Bumper
2
Brake air flap, right
3
Brake air flap, left
A Hall sensor is fitted to each of the two brake air flaps. The Hall sensors determine the position of the brake air flaps (open or closed).
Index
Explanation
Index
Explanation
1
Brake air flap
2
Hall-effect sensor
3
Vacuum connection
4
Partial-vacuum canister
System functions
The switchover valve is activated by the Dynamic Stability Control (DSC).
Index
Explanation
Index
Explanation
1
Switchover valve
2
From the vacuum pump
3
4
Hall sensor, right
5
Power supply, terminal 30g
6
DSC (Dynamic Stability Control)
3
Hall sensor, left
4
Activation of the brake air flaps optimises the aerodynamic characteristics of the vehicle.
Depending on engine operation, 2 states result for the brake air flaps:
Engine OFF
Brake air flaps open
Engine ON
Brake air flaps close after a few seconds
In order to prevent the brake discs from overheating, the brake air flaps are opened as of a brake-disc temperature of 250 °C.
If there is a fault, it might not be possible to open the brake air flaps.
The engine output is then reduced to provide overheating protection for the brake discs.
Notes for Service department
Warning! Perform all work with the engine switched off.
Work may only be carried out on the brake air flaps (in particular checking the flaps for stiff movement) with the engine switched off. Otherwise, there is a risk of injury.
No liability can be accepted for printing or other errors. Subject to changes of a technical nature
voMacK
Registrovaný: 9.9.2010
Auto: G30 540i x-drive
Utorok, 5. Augusta 2014, 22:29
Je to sucastou nejakej vybavy pre urcite motorizacie alebo ako?
-- P.R.
Utorok, 5. Augusta 2014, 22:38
vyzera že to maju všetky E60 face po roku 3/2007....
vladoslavo
Utorok, 5. Augusta 2014, 23:00
a najzaujimavejsie je, ze tieto klapky na ochladzovanie brzd maju asi priame spojenie na stabilizacny system auta, ked sa zaseknu, alebo proste nefunguju (su ovladane podtlakom), tak vypadne aj stabilizacny system a auto hodi motor do nudzaku, teda obmedzi krutak ... proste psychiatria ... zajtra checknem tie podtlakove hadicky ci su ok a aj klapky, ci su tam neni nejake necistoty ...
Utorok, 5. Augusta 2014, 23:05
](*,) ](*,) kokociny vymyšlaju.....
alfi666
Registrovaný: 18.3.2008
Streda, 6. Augusta 2014, 16:18
TT-SIMIK napísal:
Presne tak... vraj redukovanie aerodynamickeho odporu... nevadi ze vaha + poruchovost ide hore :roll: Nechapem comu uz uskodi, ze su chladiace kanale stale otvorene.. asi 0,01L/100km spotrebe
Zase sa mi len potvrdzuje, ze cim novsie auto, tym lepsie ho mat len pocas zaruky... lebo ked sa tych milion kravin zacne sypat...
No more BMW... chodim peso ;)
E61 530d titansilber - EX
vladoslavo
Streda, 6. Augusta 2014, 16:24
Co sa tyka tyck klapiek, bola vypadnuta podtlakova hadicka, lebo mi menili naraznik a nejak to zle nasunuli ... ale vo vysledku, nefunkcnost tych klapiek nema vplyv na chod auta, ako sa ukazalo ... som sa mylil ...
cdrritchey
Registrovaný: 30.4.2016
Auto: E60 facelift 525D
Utorok, 7. Februára 2017, 23:36
Tak chalani , na diag mi napísalo hlasku co je na fotke, dsc mi fungovalo a aj všetko ostatne fungovalo . Ale riešil som to ze co to je lebo pred týždňom to tam nebolo, bol som jazdiť po vysokom snehu + som prerazil pár nahrnutych kôp , ked som pozrel pod auto nic som nezistil, tak som začal testovať ci chodia ľahko tie klapky, odpojil som hadičky a ústami vytvoril podtlak a zatvárali sa...potom som si všimol ze hmlovka je trocha posunutá dovnútra , ulomeny držiak jeden, a bolo tam pri tej klapke vyselo to cidlo co je na fotke , pozrel som na druhu stranu kde ma byt, dal ho tam a vymazal chybu a odvtedy tu chybu uz nehlási ...
ZÁVER: nárazom do kopy snehu vypadlo to cidlo zo svojho miesta ...Ps aj tak nerozumiem ako meria teplotu bŕzd ...
peter9898
Registrovaný: 9.12.2012
Auto: BMW 530xd f10 2016
Štvrtok, 9. Februára 2017, 12:38
Mne hadze chybu:
006E62 DSC: Brake-air flap, plausibility .
Klapky su nonstop otvorene.. Menil som hadicky od elektroventilu smerom ku klapkam .. nepomohlo.. asi to bude treba komplet rozobrat co ?
BMW 530d xDrive F10 A/T, r. v.: 2016, LCI
ex BMW 530d (e60) A/T, r. v.: 2007, LCI
cdrritchey
Pondelok, 22. Januára 2018, 21:50
peter9898 napísal:
Mne hadze chybu:
Skús urobiť podtlak ústami ako ja, a sleduj ci sa zavre,tak ľahko a rýchlo zistíš či máš všetko tesne ...záber poriadne alebo zavolaj nejakú babu čo dobre saje :D
