hege
Registrovaný: 2.11.2010
Auto: e60 530
Pomoc e60 530d
Nedeľa, 29. Septembra 2013, 17:35
Ahojte! Vedeli by ste mi pomôcť čo tieto fault - kódy znamenajú?! Ďakujem vopred!
E R R O R M E M O R Y
---------------------------------------Date: 29.09.2013 08:08:28
ECU: D50M57C0
JobStatus: OKAY
Variant: D50M57C0
-------------------------------------------------------------RESULT: 2 error in error memory !
-------------------------------------------------------------4B10 4B10 (1278) engine-roughness regulator
Error counter: 2
Logistic counter: 40
Mileage 118928 km
mean engine speed 689.56 rpm
coolant temperature 33.06 deg C
max rail pressure of the recent 10ms 299.33 bar
injection mass index value without mass balance control 9.85 mg/cyc
intaken air mass per cylinder 397.00 mg/Hub
value of boost pressure 994.46 hPa
linearised APP1 0.00 %
Battery Voltage 14663.37 mV
Vehicle speed 0.00 km/h
idle running regulator torque 29.26 Nm
Korrekturmenge zu hoch
Test conditions fulfilled
Error not occurred yet
Error would not cause a warning lamp to light up
Fehler in Entprellphase
Error code: 4B 10 01 02 00 00 02 28 3A 12 19 53 26 19 3F 65
00 5A 00 56
-------------------------------------------------------------4B11 4B11 (1279) engine-roughness regulator
Error counter: 2
Mileage 118928 km
coolant temperature 35.07 deg C
max rail pressure of the recent 10ms 291.45 bar
intaken air mass per cylinder 378.10 mg/Hub
Battery Voltage 14500.44 mV
Korrekturmenge zu niedrig
Error code: 4B 11 02 04 00 00 02 28 3A 12 19 55 25 19 3C 65
00 59 00 56
TomiT
Registrovaný: 4.8.2013
Auto: Bmw 530d E60
Re: Pomoc e60 530d
Nedeľa, 29. Septembra 2013, 21:04
je tam zaznamenana vysoka odchylka rovnomernosti chodu,treba zmerat vstreky-korekcie,bude to asi niektory vstrekovac.
Bmw 530D A/T E60 Orientalblau metalic M-Packet
Audi A3 8P 2.0TDI PD S-Line Lamborghini gelb
Seat Alhambra 1.9 TDI PD Tiptronic
Alfa Romeo 156 SW 2.4 m-jtd 210PS,470Nm-EX
Alfa Romeo 156 2.4 JTD-EX
Peugeot 206 Roland Garros-EX
Škoda Favorit Silver Line Ex
alfi666
Registrovaný: 18.3.2008
Re: Pomoc e60 530d
Pondelok, 30. Septembra 2013, 10:59
jj, to bude vstrekovac... bol vtedy studeny motor ked sa to zapisalo... tym kilometrom ani sam neveris, ze? :)
No more BMW... chodim peso ;)
E61 530d titansilber - EX
