marian933
Registrovaný: 5.11.2011
Auto: 530D, E60, 2007
Stahovanie okna ??? - Zaseknute okno
Sobota, 3. Júna 2017, 17:59
Na e60 2007 LCI sa mi zaseklo zadne okno a ide hore /dole len po kuskoch asi 4cm - ja samozrejme chcem aby islo cele hore / dole...
Pri startovani sa mi rozsvieti zlta ikona okna a pise nieco ako window anti-trap bla.bla.bla....
Nejake rady? - Ide leto...
BMW 530D, E60,r.v. 04/2007
Re: Stahovanie okna ??? - Zaseknute okno
Sobota, 3. Júna 2017, 18:13
Treba urobiť inicializaciu okna na diag.
marian933
Sobota, 3. Júna 2017, 22:41
Aha. OK. Dakujem.
Este som nasiel takyto postup na nete. Zajtra vyskusam.
1) I had the car started
2) Roll down the window all the way from the "broken" window (it wants to stop every xx inches, keep making it go down all the way)
3) I released the switch
4) I pushed and held down (I heard from another place that it needs to be exactly 17 seconds)
5) After 17 seconds I immediatly pulled up on the switch to roll the window up (it went all the way up).
6) after the window went all the way up, and still holding the up switch, it rolled all the way down, and then all the way up once more.
7) After #6 the process was complete and the window was functioning normal again.
marian933
Pondelok, 5. Júna 2017, 06:58
Funguje.
Pondelok, 5. Júna 2017, 19:04
No jo....nebolo to 18...:-)
er2171
Registrovaný: 6.9.2017
Auto: bmw1
Piatok, 27. Októbra 2017, 16:30
Mne to nefunguje po xy pokusoch. Niekto z vychodu kto to vie dat dokopy cez diag? Diik
BMW e87 (118d) ex
BMW e60 (530xi A)
BMW f36 (428xi)
petersamer
Registrovaný: 2.6.2016
Auto: BMW E65 730D
Piatok, 27. Októbra 2017, 17:29
ahoj som ti napomoci :)
er2171
Auto: bmw1
Nedeľa, 5. Novembra 2017, 20:29
Okno vyriesene a pekne funguje bez chybovych hlasok.
Petersamer to rychlo a uspesne opravil.
BMW e87 (118d) ex
BMW e60 (530xi A)
BMW f36 (428xi)
rely
Registrovaný: 21.4.2014
Auto: BMW E46 320
Štvrtok, 7. Decembra 2017, 10:29
Ahojte,
niekto z okolia NR? :(
BMW E60 535D mpaket
Ex:BMW E46 320 (Automat)
Ex BMW E36 Compact <3
Ex: Audi A6 Avat
Ex: Alfa 147 (Nikdy viac)
Ex: Fiat Punto (Nikdy viac)
Ex: Mazda 626
Ex: Audi A4 (R.I.P) <3
Ex: Peugeot 306 ( R.I.P)
Ex: WV Jetta 1989 ( Automat) <3
Ex: Renault 5
