Prody
Registrovaný: 17.4.2014
Auto: E61 LCI 530D xd 11/7
Okno sa nezatvori na doraz
Sobota, 20. Augusta 2016, 10:56
Mam problem so zadnym oknom. Ked ho dam zatvorit tak vyjde hore a nasledne sa vrati ccca cm dole.
Vycistil som tesnenia ci tam nahodou nieco nieje, vyzera to byt ciste.
Skusal som navod na nete a to stiahnut dole okno, drzat cez 15 sec., potom vytiahnut. Ale mne vzdy vybehne hore a potom sa vrati o par centy nizsie. Reset som skusal v roznych rezimoch, auto on, off, .... Aj s klucom, aj s dialkovym.
Skusal som aj odpojit baterku, ci to nahodou nepomoze.
Pred tym ako nastal problem nebolo s autom nic robene, ani umyvane.
Manualne viem po kuskoch dat okno skoro do najvyssej polohy - nevydno ci je to na maximum.
Ostatne okna v pohode.
Diagnostiku pouzivam BMWHAT - ivini a nic neukazuje
Re: Okno sa nezatvori na doraz
Sobota, 20. Augusta 2016, 13:53
Treba z diag nadstavit antiwrap function....
Prody
Sobota, 20. Augusta 2016, 14:28
vdaka,
niekto z Kosic co ma diagostiku a by mi to vedel nastavit?
Prody
Sobota, 20. Augusta 2016, 15:14
OPRAVENE
riadil som sa ciatocne tymto
YES you can ! This is what you do , turn ignition all the way before starting car. Now go sit in the back seat with the door closed and bring the window down , this will have to be brought down in increments since its not going down automatically. When you get the window down fully with the last push of the button ,hold down for exactlly 17 seconds and let go the window at this point will go up by itself and back down by itself. Thats it !!! Try 17 seconds , if that doesnt work try 23 seconds . I know this because it happened to me 3 times. And it has fixed it 3 times. GOOD LUCK !
Remember this has to be done with a stop watch ! Unfortunatley its precise timing in order to work.
Len s tym rozdielom, ze:
Skusal som x krat 17 aj 23 sekund so zapnutym zapalovanim podla horneho navodu a nic.
Potom som nastartoval a skusil obe casy. Nasledne som potiahol gombik hore a drzal. Okno sa zatvorilo a otvoril a myslim ze znova zatvorilo (gombik zatvorenia okna som stale drzal)
A uz je to ok.
