bnykolass
Registrovaný: 4.8.2012
Auto: vela
IHKA automaticka klima
Piatok, 28. Novembra 2014, 10:38
Kazdy kto mate tuto kurenie tak snim mate urcite aspon jeden problem. Ci uz nefuka niekde, nekuri alebo nejde vobec..... :roll:
Moj problem je nasledovny :-k Ked dam vsetko na auto a na najvedsie teplo tak mi ide teplo len s fukara co fuka na celne sklo. Ked prepnem na studene tak mi zacne pekne fukat z fukarov co su v predu (lave stred prave). Ked opat prepnem na teplo tak mi prestanu fukat predne fukare a ide len na okno a tusim na nohy.
Kde by mohol byt problem ? Zapchaty filter ?
Diky
E53 4.4i on
E32 730iA on
E32 740iA on
E32 pickup on
E34 540i on
E34 525i on
E34 525tdsA off
darklord
Registrovaný: 15.12.2011
Auto: stara haraburda
Re: IHKA automaticka klima
Sobota, 29. Novembra 2014, 08:04
Precitaj si naskor ako to ma fungovat :) Pretoze ja tam chybu nevidim.
AUTO - kurenie na sklo a na nohy, chladenie do ksichtu. Alebo tak nejak. Kazdopadne ti to funguje tak ako to bolo vymyslene.
Keby si nevedel co a ako okolo IHKA, tak tu mam jeden dokument sice z E31, ale je to vsetko rovnake s E32/E34 http://e34.skoda-katalog.eu/
Automatic Button: When the “AUTO” button is pressed, the control
module operates all the air discharge flap motors according to Y-factor.
If cooling is needed, the face vent outlet flaps are fully opened, while
the windshield defroster and footwell flaps are fully closed. If heating
is called for, the face vent outlet flaps are closed, and the footwell and
windshield defroster flaps are fully opened. For some mid-range Yfactor
values (e.g. 40%) all air distribution flaps are partially open.
bnykolass
Auto: vela
Pondelok, 1. Decembra 2014, 17:25
No ale zda sa mi cudne ze by z celeho predku (nie len zo stredu) isiel vzdy iba studeny vzduch. Ved ked si nastavujem teplotu pre pravu a pre lavu stranu tak by snad malo fukat aj zdakade teple (nie len na nohy a na celne)
Vsimol som si to lebo si nemam kde ohrievat ruky ked si sadnem do vyhriateho auta :(
E53 4.4i on
E32 730iA on
E32 740iA on
E32 pickup on
E34 540i on
E34 525i on
E34 525tdsA off
darklord
Utorok, 2. Decembra 2014, 12:15
No tak si to z auto polohy prepni na tu tretiu, a stredny vyduch si nastav na teple, potom ti to pusti teplo aj tam. Precitaj si ten dokument, tam je to fungovanie popisane uplne presne.
