Patricius
Registrovaný: 11.9.2009
vyblikanie na e34...19x ??? už len 8x
Štvrtok, 6. Mája 2010, 21:44
Chlapi, neviem to nikde nájsť...kontrolka bratovi na e34ke 525tds blikne 19x, čo to môže byť. Presne je to tak, že po našlapaní plyn pedálu blikne raz a potom pauza...potom 19x za sebou. Už som prehladaj všetko a všade je to len takto:
1 rpm transmitter
2 temperature sensor - fuel
3 temperature sensor - engine coolant
4 pedal position transmitter
5 boost pressure sensor
6 throttle position potentiometer
7 boost pressure regulator
8 air mass position
10 speed regulator
11 compute coupling
12 temperature sensor - air
13 rpm data line
14 start of injection
15 exhaust gas recirculation
16 start of injection regulator
17 brake test switch
36 water level sensor
DDE2
0 undefined fault
1 air mass sensor
3 electronic turn off unit
5 start of injection transmitter
6 glow period regulator
10 start of injection regulator
15 voltage supply DDE control unit
20 speed regulator
21 throttle position potentiometer
28 clutch switch
29 speed signal
31 brake switch
35 temperature sensor - fuel
36 water in fuel sensor
37 pedal position transmitter
41 glow period regulator
45 theft protection system
47 rpm transmitter
52 temperature sensor - charge air
53 temperature sensor - engine coolant
54 boost pressure sensor
56 internal control unit fault
58 disturbance of high level stage
59 deviation of boost pressure
Naposledy upravil/-a Patricius v Utorok, 11. Mája 2010, 16:27, upravené celkom 1 krát.
[E61 525dA] ex
[E39 530dA] ex
Patricius
Re: vyblikanie na e34...19x ???
Piatok, 7. Mája 2010, 17:24
:-k
[E61 525dA] ex
[E39 530dA] ex
starML
Registrovaný: 26.7.2007
Piatok, 7. Mája 2010, 20:17
Záleží na roku výroby. A nehledej to u DDE ale u SRS/Airbag : http://vs31.sweb.cz//DiagnosticTroubleCodes.pdf
SRS 1 (1988-91)...........
19==>CRASH DETECTION ACCUMULATOR ACTIVATED - The detection accumulator is activated by the operation of the SRS system.
* ATTENTION! THIS ACCUMULATOR CAN ONLY BE DIAGNOSED AND RESET BY THE BMW DEALER.
SRS 2 (1991-93)...........
19==>FRONT SENSOR SUPPLY VOLTAGE - LEFT FAULT
SRS 3 (1993-98).........
19==>SRS WARNING LAMP FAULT
Audi A3 30 gtron automat CNG
Octavia 1,4 TSI manual CNG Ex
E60 530iA Ex
E39 530dA Ex
Patricius
Piatok, 7. Mája 2010, 22:01
starML napísal:
Tak toto sa nás týka...viete to, plís preložiť? Ja nie som ingliš mén :roll:
A ďakujem :-"
[E61 525dA] ex
[E39 530dA] ex
starML
Piatok, 7. Mája 2010, 22:47
SRS = Supplemental Restraint System = doplňkový zádržný systém = airbagy vozu
WARNING LAMP FAULT = výstražná žárovka vadná
Takže buď vadná, nebo vymontovaná žárovka, aby neupozorňovala, že airbagy jsou nefunkční, nebo už taky vystřelené. Zpravidla úprava tureckých a ruských prodejců v Německu. Současně bývá napsáno, že auto určeno pouze pro export.
E60 530iA Ex
E39 530dA Ex
BJS
Registrovaný: 14.6.2007
Auto: 530d xdrive
Sobota, 8. Mája 2010, 19:14
[-X Je to len a len autodiagnostika motora, nie bagov, prevodovky a hocičoho iného. Keď som sa hrabal v motore, neviem už či som pretesňoval čerpadlo, alebo niečo iné, mal som poodpájané čidla atď... Po urobení autodiagnostiky mi tiež vyblikalo 19. Ale asi po dvoch dňoch už nič. A ja bagy nemám.
Boh miluje ateistov, pretože ho nezaťažujú blbosťami.
Ex 525tds E34 calypsorott - EX po šmerci
Ex 330xdaT E46 oxfordgreen II -EX nie je ďaleko
Ex 530daT E39 titanstriebro
535dx GT F07-Gita (ancikrist)
530d xdrive F11-Lojzička
Furby
Registrovaný: 1.3.2009
Auto: E60 530d & K50
Nedeľa, 9. Mája 2010, 08:36
ja mám podobný problém na E34 /1992:
blikne 1x a potom 29x
pri SRS2 taký kód (29) ani nie je, čo to je?? #-o
E60 530d
Patricius
Nedeľa, 9. Mája 2010, 09:54
DDE2
29 speed signal
žeby?
[E61 525dA] ex
[E39 530dA] ex
Furby
Utorok, 11. Mája 2010, 11:09
a to je čo??
nikto nevie čo to môže byť? 1-29? #-o
E60 530d
Patricius
Utorok, 11. Mája 2010, 16:26
Tak sme včeera preštelovali čepradlo a dnes zablikal už len 8x :-k
8 air mass position
[E61 525dA] ex
[E39 530dA] ex
fioro
Registrovaný: 11.10.2007
Auto: 156 1,9JTD
Re: vyblikanie na e34...19x ??? už len 8x
Utorok, 11. Mája 2010, 19:36
a e34 ma vahu? [-X
...... Obrázok......
BMW e34 525tds EX
Ford Transit 2,5 td EX
Opel Campo 2,5td 4x4 EX
Alfa 156 1,9 JTD
Patricius
Utorok, 11. Mája 2010, 19:47
fioro napísal:
a e34 ma vahu? [-X
nie nemá... ale má totok http://www.bmwklub.sk/bmw5/e34-525tds-cidlo-v-sani-t31502.html :smile:
[E61 525dA] ex
[E39 530dA] ex
fioro
Auto: 156 1,9JTD
Utorok, 11. Mája 2010, 19:57
cize asi tak tie kody....
BMW e34 525tds EX
Alfa 156 1,9 JTD
Patricius
Utorok, 11. Mája 2010, 20:22
jo to je tiež v tabuľke, ale už som s tých kódov chorý...teraz bliká len 8x...a to je zasa niečo iné...
Otázku je asi treba položiť inak:
Je možné že vyblikanie neukazuje korektne?
A teraz prečo...chronologicky:
1. vyblikanie závad bolo 19x čiže SRS(ABG čičo)
následne prestavené čerpadlo>>dosiahol sa lepší záťah odspodu a nedymí už skoro vôbec(sem tam obláčik)
2. vyblikanie závad bolo 8x čiže air mass position
Výsledok?:
Po prestavení čerpadla sa odstránil problém s ABG :-k a objavila sa iná chybová hláška [-o<
[E61 525dA] ex
[E39 530dA] ex
BJS
Auto: 530d xdrive
Streda, 12. Mája 2010, 19:43
Už som ti písal, že je to len a len diagnostika motora, ničoho iného. Skús premerať čidlo teploty v saní. Pri studenom a teplom vzduchu by mal byť odpor rozličný.
to fioro: už som videl aj e34 s váhou a som čumel ako puk.
