motta
Registrovaný: 27.8.2008
VIAC OTAZOK - E34 525i '93
Streda, 26. Novembra 2008, 08:57
KUPIL SOM E34 525 I R.V. 1993 141KW VANOS,.......A IDE O TOTO: KURENIE V ZADU NAD TUNELOM STED- NEJDE ..INDE NEMAM PROBLEM....DALEJ...STIERACE CKLUJU LEN NA MAXIMALNEJ RYCHLOSTI :)-SI TO PREDSTASVTE TEN RAHOT VZDY KED PRSI :) ...DALEJ: TROCHA KLEPE VANOS ALE LEN OBCAS (MOZE BYT RIEDKY OPLEJ ???)...DALEJ : NA VOLNOBEHU ALE NIE VZDY STUPAJU A KLESAJU SAME OTACKY OD CCA 700 DO -900...ALE NIE PRAVIDELNE A STALE ..INAK MOTOR NADHERNY CHOD...A KAMARAT MA TOTO ISTE LEN NIE VANOS A MA PROBLEM ZE KED PRIDA TAK SAAUTO ZAJAKAVA A ROBI MU KRAVINY S OTACKAMI A KED BOL NA DIAGNOSTIGE TAK MU POVADALA ZE : LAMBDA ALEBO VAHA ?...LEN SA MU NECHCE ZE KUPIT OBOJE A RADSEJ BY LEN JEDNO POPRIPADE ZIADNE :)) ...DAKUJEM VELMI PEKNE ZA ODPOVEDE ...
BMW 325 ix Touring 0951998
Helldiver
Registrovaný: 10.6.2007
Auto: E90 330d M-paket
Streda, 26. Novembra 2008, 14:51
To s tym kurenim vzadu je normalne, pokial tam mas iba kolecko na otvaranie/zatvaranie prieduchu a nie na regulaciu teploty (co bola veeeelmi zriedkava priplatkova vybava, neviem ci dokonca nie iba pre E32), tak ti stadial pojde iba cerstvy (v zime studeny:)) vzduch, teply vzduch od kurenia ide spod sedaciek. Kolisanie otacok moze sposobovat plno veci, uz to tu bolo 1000x preberane, najcastejsie je to prisavanie falosneho vzduchu, zasekavajuci sa volonbezny ventil, lambda...
EX E34 535i 92' Schwarz
EX E46 328ci 2000' Silber
E90 330d 2007' M-paket
