zigus
Registrovaný: 29.9.2013
Auto: BMW X5 E70
318i e91 DSC, DBC, FTM failure
Nedeľa, 11. Mája 2014, 20:39
Ahojte, dnes sa mi rozsvietili za jazdy 3 warningy na bmw 318i touring, 2009.
Flat tyre monitor failure
Tyre pressure loss can not be identified. Have fault checked by BMW service as soon as possible.
Driving stability
Brake and drive control systems failure. Reduced braking and driving stability. Avoid hard braking. Have the problem checked by the...
DBC failure
No DBC assistance while emergency braking. Drive moderately. Have the problem checked by BMW service as soon as possible.
Mam runflaty, skontroloval som a nemam na ziadnej pneumatike defekt. ABSko a ESPcko je teraz vypnute ako to svieti.
Nestalo sa vam nieco podobne? Je to len cidlo, alebo abs pumpa?
Zajtra ho vezmem ku znamemu do servisu, nech sa na to pozrie.
Vdaka.
edit: Prikladam este fotku. Kontrolky svietia zltou farbou, nie cervenou.
zigus
Auto: BMW X5 E70
Re: 318i e91 DSC, DBC, FTM failure
Pondelok, 12. Mája 2014, 09:58
ok, takze na diagnostike mi dalo toto:
5DC2
Wheel speed sensor pulse wheel (rear right) plausibility
Asi to bude lozisko alebo snimac, zajtra to zoberem do servisu.
bendy252
Registrovaný: 18.2.2014
Auto: E91 320d
Utorok, 13. Mája 2014, 10:21
moze to byt cidlo aj abs pumpa alebo senzor tlaku,pozeral si si ci su vsetky gumy dobre nafukane a vynuloval a nastavil si ten system merania tlaku ??
u mna sa podobne zacalo spravat ked mi odisla abs pumpa (chyba 5E20)
Utorok, 13. Mája 2014, 11:06
tlak v pneu to nebude, vtedy zasvieti iba samotna FTM kontrolka a vypise to aj na idrive
zigus
Auto: BMW X5 E70
Utorok, 13. Mája 2014, 18:58
OK, tak nakoniec problem vyrieseny.
Vymenili sa snimace medzi dvomi zadnymi kolesami a potom to prestalo. Zrejme nejaka spina alebo kontakt na ozubenom kotuci ci nieco podobne. Teraz mi uz funguje vsetko a nic nesvieti :)
Snad to nebude len docasne riesenie.
Štvrtok, 15. Mája 2014, 16:07
zigus napísal:
vsetko na tomto svete je len docasne :wink:
AntiBiotik
Registrovaný: 28.5.2007
Auto: E91 320d
Pondelok, 16. Novembra 2015, 09:24
zigus napísal:
Cau Zigus
Mne sa vcera vecer stalo to iste: na mokrej dialnici, pri ryclosti asi 160km/h, pri podskoceni na spojke mosta mi zrazu vypol tempomat a zobrazili sa 3 oranzove kontrolky na pristrojovke a chyby na CIC - Driving stability, DBC failure, FTM system error.
Funguje ti vsetko spravne po prehodeni senzorov doteraz? alebo si este od vtedy nieco riesil?
BMW E91 320d 130@160kW/425Nm, Retrofits: FLA, Heated seats front | "OEM like" heated seats rear | TV | AV in | Raspberry-pi | Combox + USB | Snap-in | BMW apps (6FL,6NF,6NR) | Front PDC | Rear/Top view camera | Custom HiFi with DSP | High cluster white LED | Custom ambilight...
AntiBiotik
Auto: E91 320d
Streda, 18. Novembra 2015, 10:14
Tak vcera som to pozerel cez istu,
Chyba 005DC2 – DSC: Wheel-speed sensor: increment gear, rear right.
Tak som an skusku prehodil sensory otacok kolesa medzi sebov/pravy za lavy a vyresetoval chybu,
No po prejdeni par metrov, znova prisli kontrolky a po nacitani ta ista chyba.
Moje podozrenie je na “ABS Reluctor Ring” (toto ozubene kolesko z ktoreho sensor cita impulzy) vraj casom zhrdzavie alebo sa rozpadne.
Hovori vam to daco? Mate s vymenou niekto skusenoti?
AntiBiotik
Auto: E91 320d
Sobota, 21. Novembra 2015, 09:39
AntiBiotik napísal:
Takze problem je vyrieseny
Vybral som koleso aj senzor a vycistil dieru od senzora zubnou kefkou a cisticom brzd a zaroven som tocil kolesom, aby sa vycistili zuby prstenca.
A vyfukal to vzduchom.
Zatial to slape jak hodinky
zigus
Auto: BMW X5 E70
Sobota, 2. Januára 2016, 16:43
Ahoj,
mne to vtedy pomohlo, no za 3 mesiace som mal znovu ten problem, na pravom zadnom kolese som mal pokazeny snimac. Ked sa mi ho snazili rozobrat tak tam bol zapeceny klb. Museli ho rozsekat a tak to vybrali. Vymenilo sa to, len s tym bolo mega vela roboty.
Auto som predal v auguste tak snad sa uz ten problem neopakoval.
eniac
Registrovaný: 24.6.2011
Auto: E91 330xd M-Paket
Pondelok, 4. Januára 2016, 19:20
Ja som mal ten istý problém, po náraze na výmoľ mi vypísalo všetky tieto chyby. Po diagnostike a vyčistení sa senzor i tak nerozbehol a za 100e som ho musel dať vymeniť. "ďakujem" slovenským cestárom - sedmospáčom...
Súčasnosť: E91 330d x-drive 2006 M-Paket
Ex1: E46 330xd Touring 2003
Ex2: E46 320i 1999
januar
Registrovaný: 18.9.2007
Auto: e90 320i
Pondelok, 4. Januára 2016, 22:58
dobra E46 tam az take chybi neboli :D
upir156
Registrovaný: 25.11.2012
Pondelok, 4. Januára 2016, 23:08
januar napísal:
To nebude modelom. Y
Vindo
Registrovaný: 14.8.2016
Auto: E90
Nedeľa, 28. Mája 2017, 13:59
Ahojte, oživím túto tému.
Presne tieto 3 chyby mi začalo hlásiť dva dni po tom, ako mi bolo vymenené zadné ložisko. Môže to byť spôsobené aj týmto? Niekedy sa to prestane zobrazovať počas jazdy, inokedy ak otočím volantom do ostrej zákruty, tak ihneď sa objavia tieto chyby + blikanie smeroviek sa po vyrovnaní volantu nevypne.
Dodrbali mi snímač pri výmene, je to možné?
Ďakujem za odpoveď.
Nedeľa, 28. Mája 2017, 19:48
Alebo snimaci kruzok, nedavno som to panovi menil
