alexion
Registrovaný: 11.2.2009
Auto: E36 2.8i
Side Window Anti-Trap Function Failure
Utorok, 11. Septembra 2012, 19:28
dnes sa mi stala taka cudna vec, vlozil som klucik do zapalovania, stiahol zadne okno nastartoval v zapati sa ozvala hlaska Side Window Anti-Trap Function Failure a okno uz nejde hore. da sa s tym nieco svojpomocne urobit alebo len bmw servis? poistky som skontroloval, su v poriadku.
co to som sa snazil aj vyhladat na forach, ale len 5tkari mali podobny problem, stym ze okno neslo dole, mne zas nejde hore. snazil som sa otestovat vsetky figle co sa k tomu spominali a nic. :-&
chch
Registrovaný: 28.11.2010
Auto: E91 318i ED
Re: Side Window Anti-Trap Function Failure
Utorok, 11. Septembra 2012, 19:57
Nasiel som tieto rady, aj ked predpokladam ze si ich uz skusal tiez:
1) To reinitialize the window, push and hold the window button (from the drivers seat controls) until the window is all the way down, and hold for another 5 seconds. Then pull and hold the button until the window is all the way up, and hold for another 5 seconds. That should reset the affected window.
2) Use a stop watch.
Sit in the back of the car with the door closed.
Use only the switch of the door concerned, not a switch in the front switch pack.
Fully open window so wont drop any further
Press and hold window switch fully down (open) for 17 seconds
Pull and hold window switch up fully (close) - Window now closes, opens, closes again.
Release switch, done!
3)
1) Turn ignition to 'ON' position (some cars need to start engine)
2) At the 'problem' window, press the switch until the window go down(open) completely, release switch.
3) Now, press the switch (harder like how you want to activate one-touch)and this time hold it there for 17 seconds. This 17 seconds is the key.
4) Once you reach 17 seconds, release the switch and immediately pull (like what you would do to close window) the switch and hold there until...
5) The window will go up, down and up again OR you will hear a beep (all the while you must still hold on to the switch).
6) After 5) happens, then you release the switch and the failure should be fixed.
alexion
Auto: E36 2.8i
Utorok, 11. Septembra 2012, 20:28
dik. nie vsetko som uplne dodrzal, cez mobil som nasiel trochu ine postupy, zajtra vyskusam.
problem je ale to ze tu sa vsade riesi otvorenie okna, ja ho potrebujem zatvorit.
alexion
Auto: E36 2.8i
Streda, 12. Septembra 2012, 22:09
dnes som odpojil bateriu a po opatovnom pripojeni skusil pohnut s oknom. na moje prekvapenie slo hore. ale nejde plynule, takze nepokusam stastie, chybu hlasi stale. pozitivne je ze uz mozem parkovat auto na ulici so zavretym oknom.
