afro
Registrovaný: 22.12.2008
Auto: BMW 118i F20, X1 E84
Ako nakonfigurovat otvarac elektrickej brany
Nedeľa, 3. Júla 2011, 08:32
Mam bmw e91 a mam zabudovany univerzalny otvarac elektrickych bran v spatnom zrkadle auta v kabine. Take tie tlacitka pod vnutornym spatym zrkadlom 1,2,3. Ma s tym niekto skusenosti ako sa to da nakonfigurovat ? Doviezol som auto s nemecka, nemam SK manual na to.
-= BMW 1 118i - 4/2017 - A/T =-
-= BMW X1 118d - 2/2015 - A/T =-
-= BMW 325d - 5/2007 - 17"/225/45 - A/T =-
-= BMW 320d - 11/2004 - 18"/225/45 - A/T =-
skydive forever
chch
Registrovaný: 28.11.2010
Auto: E91 318i ED
Re: Ako nakonfigurovat otvarac elektrickej brany
Pondelok, 4. Júla 2011, 17:35
afro napísal:
Homelink System Installation - Instalacia systemu Homelink
1. Park either inside the garage or have your car parked on driveway facing the garage as close as possible. - Zaparkuj s autom v garazi, alebo hned oproti garazovej brane, co najblizsie.
2. Press and hold the first and third button of the homelink buttons for approximately 20 seconds, until the red light starts blinking rapidly. - Stlac a drz stlacene gombiky 1 a 3 zhruba na 20 sekund, pokial nezacne cervena led blikat rychlo.
3. Press the button (1,2, or 3) you desire to have installed and hold it. The red light will be blinking slowly. - Stlac gombik 1 alebo 2 alebo 3 (ktory chces naucit) a drz ho stlaceny. Cervena led zacne blikat pomaly.
4. With the garage opener remote near the rear view mirror (1~4 inches near), press and hold the remote button while you are still holding the desired button on your homelink system. The red light will eventually blink rapidly. If so, release both buttons. - Stale drz stlaceny ziadany gombik na homelinku, pribliz tvoj standardny dialkovy ovladac garaze uplne blizko k spatnemu zrkadlu (par cm), a stlac gombik standardneho dialkoveho ovladaca, a drz ho stlaceny. Cervena led zacne blikat znova rychlo.
5. Next, go to the garage opener’s main console (it’s most likely the garage opener’s motor with the light turned on when opened/closed) - Presun sa dovnutra garaze, a najdi hlavne pripojne/programovacie pole mechanizmu otvarania. S najvacsou pravdepodobnostou to bude niekde na motore.
6. Search for a button that reads “learn”, “read”, or a noticeable button on your console. There aren’t a lot of buttons on that console, so you’ll most likely find it. - Pokus sa najst gombik, ktorym sa ucia dialkove ovladace na tvojej garazovej brane. Nastuduj manual, spytaj sa tych co ti to instalovali, atd.
7. Press the button, and a light adjacent to the button will flash/blink. You have a 30 second window to finalize the installation. - Stlac gombik uciaceho rezimu na motore, vacsinou je tento cas limitovany, takze bud rychly.
8. Go back in the car, press and hold that button you desired to have installed and the light will blink rapidly for like 2 seconds and stop blinking (light will be on). Release the button and press/hold again. Repeat this two more times (A total of THREE times) and voila! The garage door will open/close! - Vrat sa do auta, stlac a drz stlaceny gombik na homelinku, ktory si chcel mat naprogramovany. Cervena led zablika rychlo asi na 2 sekundy, a potom prestane. Toto musis zopakovat TRI KRAT. Potom by sa mala garazova brana otvarat.
Troubleshooting - Riesenie problemov:
If you are stuck on number 4, try putting the garage opener remote near the 3 homelink buttons (1~4 inches). Try different angles of the remote if still does not work. - Ak si sa zasekol v bode 4, skus dat tvoj dialkovy ovladac co najblizsie k spatnemu zrkadlu, skusaj rozne uhly, pokial to nebude fungovat.
If you are stuck on number 6, where you can’t find ANY button on your console, you might have to open up the console and it will be there. I have a Genie brand garage opener and couldn’t find a button, so I gently spread open slightly between the light bulb cover and the console. Then the button was visible! So I got a flat-head screw driver, pressed the button and the light right next to it started flashing. - Ak si sa zasekol v bode 6, musis prestudovat manual ku brane, alebo sa spytat dodavatela.
*I would recommend two people in installing this, so one person can be ready to press the “learn” button on the garage opener console and one working inside the car* - Odporucam aby si si nasiel niekoho, a robili to dvaja.
afro
Pondelok, 4. Júla 2011, 21:26
Dakujem za preklad, nakoniec som to nasiel aj ja, po anglicky viem :)
No problem je ci sa ti to podarilo aj niekomu realne rozbehat?
Ja mam branu od firmy CAME - pohon Krono.
skydive forever
chch
Auto: E91 318i ED
Utorok, 5. Júla 2011, 06:48
afro napísal:
Vzhladom na to, ze si pisal ze nemas SK manual som predpokladal, ze hladas slovensky navod. Takze som to prekladal zbytocne.
afro napísal:
No problem je ci sa ti to podarilo aj niekomu realne rozbehat? Ja mam branu od firmy CAME - pohon Krono.
Ja homelink nemam, ale podla mna by to nemal byt problem, potrebujes navod k pohonu.
afro
Utorok, 5. Júla 2011, 19:57
Urcite si to neprekladal zbytocne, pomoze inym co nevedia po en. Mam len nemecke knizky a tie som ani neotvoril, tento postup som nasiel ked potom ako som dopisal tento prispevok na stranke homelinku, kedze som taktiez az potom zistitl ze tam je homelink device.
Na stranke toho pohonu som nenasiel ako sa dopatrat k tomu tlacitku, takze musim tu firmu kontaktovat co to riesi...
aj tak dakujem!
skydive forever
JozefSvob
Registrovaný: 19.11.2010
Auto: E92
Utorok, 5. Júla 2011, 21:00
Necital som to cele,ale podla manualu mi to islo absolutne bez problemov...- Hörmann Brana/Motor
JozefSvob
Auto: E92
Utorok, 5. Júla 2011, 21:02
Potlac prve dva gombiky na spataku,pockaj kym nezacne cervena ledka blikat...ked zacne blikat priloz ovladac na branu,a stlac ho,ako keby si chcel otvorit branu (nestlacit , DRZAT !!! ) kym nezacne ledka blykat ovela kratsich intervaloch. cele...
afro
Streda, 6. Júla 2011, 08:14
JozefSvob napísal:
Parada, funguje! :thumbup:
skydive forever
TomasHC
Registrovaný: 7.3.2012
Auto: 320d E90 N47
Nedeľa, 25. Marca 2012, 15:19
Toto by som prijal, ale nemám to zabudované :( Mám ale 3 voľné ovládače (2ks k posuvnej bráne, 2ks ku garážovej) SOMFY, rád by som to zabudoval pod ovládací panel klímy a zapojil na dve voľné tlačítka (tam kde býva ovládanie PDC, zácloniek..). Dajú sa také univerzálne tlačítka bežne kúpiť, prípadne čo to stojí...? Dopojiť už nebude problém, veď som nejaký elektrikár :)
TomasHC
Auto: 320d E90 N47
Utorok, 27. Marca 2012, 18:16
TomasHC napísal:
Home-made úprava hotová, všetko funguje ako víno - pridal som to medzi návody - technicke-okienko/e90-otvaranie-garazovej-brany-t60498.html
Užívatelia prezerajúci toto fórum: Bing [Bot] a 5 neregistrovaných
