snip_snap
Registrovaný: 10.5.2009
Auto: BMW X5 e70 3.0 sd
E46 316i 1895 cm3 77kW odblokovanie RJ? cipovanie?
Streda, 15. Júna 2011, 20:36
zdravim vas pani a damy, dnes som sa dozvedel ZEVRAJ tento motor 1,9 s vykonom 77 kW sa da nejak bud prechipovanim alebo odblokovanim riadiacej jednotky presteluvat na vacsi vykon...kedze objem motora je 1895 cm3 a ma to chabych 77 kw ako nejaka 1,6....hm co vy nato? teraz nemyslim klasicke chipovanie.
SurrendeR
Registrovaný: 25.5.2008
Auto: e36 328i Tour
Re: E46 316i 1895 cm3 77kW odblokovanie RJ? cipovanie?
Štvrtok, 16. Júna 2011, 04:47
info z WIKI:
316
The 316 was introduced in 1999 and has the smallest engine available in the E46, the 1.9 L BMW M43 producing 105 hp (78 kW) and 165 N·m (122 ft·lbf).[17] Like all 4 cylinder models, it was not released into the United States market.[9] In 2001, the 316 was given a smaller, yet more powerful, 1.8 L BMW N42 engine producing 116 hp (87 kW) and 175 N·m (129 ft·lbf).[18]
[edit]
318
The 318 was introduced in 1998 with the same engine as the 316, the 1.9 L BMW M43.[18] However, it was designated the M43B19TU (technical update) and had dual balancing shafts which increased horsepower to 118 hp (88 kW) and torque to 180 N·m (133 ft·lbf). Along with the 316, the 318 received an updated engine in 2002: the 2.0 L BMW N42. It produced 143 hp (107 kW) and 200 N·m (148 ft·lbf).[18] The 318 was not released into the United States market.[9]
snip_snap
Štvrtok, 16. Júna 2011, 14:49
neni som nejaky riadny anglictinar,ale tato poucka myslim o motoroch, ktore sa vyrabali, nema ziadny zmysel na moju otazku,ci? oprav ma ak sa mylim.
BMino
Registrovaný: 28.12.2006
Štvrtok, 16. Júna 2011, 15:58
snip_snap napísal:
nema :D
dnes som sa nad tym zamyslel, ak narazas na to, ci sa z toho neda spravit 318i, osobne si myslim, ze to bude mat inu mapu nahratu, takze ak to chces upravit, tak ci tak by to chcelo novy soft, co je chipovanie
ale snad sa ti ozve aj niekto, kto s tym aj robi :roll:
e91 330d
e90 320d - ex
Land Cruiser 90 3,0 td
2000 CA - ex
e36 M3 coupe SMG - ex
e30 320i coupe M-Technic - ex
SurrendeR
Auto: e36 328i Tour
Štvrtok, 16. Júna 2011, 22:28
cize to neni len tak SW, je tam iny HW :lol:
eko.fresh
Registrovaný: 2.3.2008
Auto: bmw
Štvrtok, 16. Júna 2011, 22:31
Toho HW je tam viac, uz sa to tu riesilo, niesi prvy koho to napadlo.
snip_snap
Sobota, 18. Júna 2011, 09:31
surender cize ked si tam dorobim tie dvojake vyvazovacie hriadele budem mat z toho 318i? :mrgreen:
sak ale cipovanim sa mi tam prida mozno tak 10 konov, ale keby sa to prerobi na tolko co ten motor zvladne tak by to bolo ovela viac,nie?
andy00
Registrovaný: 25.7.2009
Sobota, 18. Júna 2011, 14:42
podla etk ma aj 316 vyvazovacie hriadele,v tom rozdiel nebude. rozdiel je v tom ze 318 ma DISA(variabilna dlzka sania), vacka by mala byt rovnaka aj ked maju rozdielne cisla dielu, a rozdielnu RJ. Vychadzam z tohto fora http://www.e46fanatics.com/forum/showthread.php?t=480563 kde sa to jednemu podarilo upgradnut. Pise tam ze 316 ma aj konektor na DISA, ale ja som ho osobne u mna nenasiel.
snip_snap
Pondelok, 20. Júna 2011, 13:25
cize na fore sa nenajde asi ziadny fachman co by to vedel poriadne vysvetlit a porobit... hm, skoda, ale zvysenie vykonu by ma potesilo :)
eko.fresh
Auto: bmw
Utorok, 21. Júna 2011, 07:16
snip_snap napísal:
Pre tych 11kw sa to neoplati. A stale to bude iba zabastlena prerabka. Ak chces "ladit" motor tak ten najvykonejsi nie ten najslabsi.
Tie peniaze co by si do toho investoval radsej investuj niekde inde. Napr. nove ramna brzdy alebo tlmice... proste na udrzbu. Autu ulahodis viac ako keby si ho nezmyslene bastlil.
