Igorino
Registrovaný: 25.9.2015
speed camshaft sensor vymena
Piatok, 26. Januára 2018, 15:23
caute ak menite snimac kluky robite na pripravok ako je to tu https://www.newtis.info/tisv2/a/en/e46- ... it/46olMTw alebo bez?
lebo toto dnes vypisala inpa chyby idu zmazat do nastartovania DAKUJEM
47 Speed (rpm) sensor Crankshaft
Error frequency : 40
Engine speed Injection pump 164.50 [1/min] Kuehlmitteltemperatur 0.00 [Grad C] Betriebstundenzaehler 6505.50 h Engine speed Injection pump 235.00 [1/min] Kuehlmitteltemperatur 16.00 [Grad C] Betriebstundenzaehler 6503.30 h
Speed change unplausible Error currently not available
Errorcode: 2F 10 28 07 28 4B 9F 0A 38 4B B5 ------------------------------------------------------------
67 Control unit Injection pump
Error frequency : 36
Engine speed 2326.50 [1/min] Fuel temperature Injection pump 1.00 [Grad C] Betriebstundenzaehler 6505.50 h Engine speed 517.00 [1/min] Fuel temperature Injection pump 3.00 [Grad C] Betriebstundenzaehler 6503.50 h
comparison the speed (rpm) Crankshaft to Speed (rpm) Injection pump Error currently not available
Errorcode: 43 02 24 63 29 4B 9F 16 2B 4B B3
Flasho
Registrovaný: 14.2.2012
Auto: e60 545iA e46 330iA
Re: speed camshaft sensor vymena
Sobota, 27. Januára 2018, 21:31
Netreba, ide aj bez.
Tel.č. +421918113450
Igorino
Nedeľa, 28. Januára 2018, 13:52
dik
