Matt23
Registrovaný: 28.4.2013
Auto: E46 330 D
Prerabka 5st manual na 6st manual
Utorok, 6. Októbra 2015, 15:34
Je mozne prerobit u e46 330d 135kw sedan 5st manual na 6st manual z e46 330d 150kw a to len prehodenim samotnej prevodovky + system riadiacej paky, alebo je nutne vymenit aj zotrvak, spojku, hriadel a diferak ?
5st manual 330d-M57
http://bmwfans.info/parts-catalog/E46-S ... #7501342_1
6st manual 330d-M57N
http://bmwfans.info/parts-catalog/E46-S ... #7531346_1
jurkyLE
Registrovaný: 17.7.2009
Auto: Volvo XC90 + BMW X5
Re: Prerabka 5st manual na 6st manual
Utorok, 6. Októbra 2015, 19:21
kuk: https://www.google.sk/?gws_rd=ssl#q=E46 ... ap+6+speed
druhy link, vraj mu to funguje:
I asked a while back about what I needed to convert my 330d estate from a 5 speed to a 6 speed, this is how done so advice for anyone thinking about it, it's NOT worth it lol!
To make it work you need:
6 speed gear selector
6 speed clutch
6 speed gearbox
6 speed propshaft
Wire
Gearbox mount
Essentially it's a straight forward job, just swap the box ect you will need to change the clutch as its got twice the amount of splines on the first motion shaft, the dual mass is the same, you will also need to cut the reverse light sensor wire and extend it as the 6 speed one is further back, the gearbox mount for under the floor is also different from the 5 speed one so this needs to be changed aswel, also cruise control doesn't work in 6th.
Hope this helps anybody going to attempt conversion
Ex Mercedes CL500
Daily Fabia RS
Mercedes SLK 320
Matt23
Auto: E46 330 D
Sobota, 6. Februára 2016, 03:03
Super dik. Netusi inak niekto aky pomer ma manual prevodovka a diferencial u 330d 135kw M57 a u 330d 150kw M57n ?
