Moderátor: SmartBastard
Ranger666
Registrovaný: 8.5.2012
Z4 launch control e89
Pondelok, 7. Júla 2014, 13:53
Zdravim Vas, mam otazku.
Má e89 ročník 2009-2010 35i naprogramovany launch control?
Ak ano, netušite ako ho vyskušať ? ;)
Ďakujem vopred
ice.blade
Registrovaný: 14.7.2008
Re: Z4 launch control e89
Pondelok, 7. Júla 2014, 15:41
make sure the car is warmed up - put your left foot on the barake - select "Sport +" mode - select manual mode with the gear lever and then push the gear lever forwards to select 1st gear (this step can easily be overlooked). Floor the accelerator and you should see a chequered flag appear on the instrument panel. Take your foot off the brake and away you go! This is also on page 56 of the driver's manual
Ranger666
Pondelok, 7. Júla 2014, 18:45
Dakujem, to som už čítal :)
Podla tohto navodu mi to nejde alebo som daco zle spravil :)
