Moderátori: alfi666, fox1k
iste
Registrovaný: 23.2.2009
Priepustnost vstrekovacov bosch, rozdelenie podla farby
Nedeľa, 13. Decembra 2009, 12:44
15lbs = Gray top injectors
19lbs = Yellow (or sometimes referenced as Orange) top injectors
19lbs = Solid Orange "skinny" injectors
21lbs = Solid Light Purple "skinny" injectors
22lbs = Violet top injectors
22.5lbs = Blue & Black top w/ Silver body injectors
24lbs = Sky Blue top injectors
25lbs = Solid Black "skinny" injectors
25lbs = Solid Light Blue "skinny" injectors (Ford Navigator)
27lbs = Solid Light Gray "skinny" injectors
30lbs = Red top injectors
36lbs = Brown top injectors (low impedence, used in the 4 cyl Turbo vehicles)
36lbs = Dark Blue (Colbalt Blue) top injectors
36lbs = Solid White "skinny" w/ rectangular connector injectors
39lbs = Solid Blue "skinny" injectors (Blue Giant) (Ford rates this at 39lbs, flow rate is actually 42lbs)
42lbs = Lime Green top injectors
42lbs = Solid Green "skinny" injectors
48lbs = Beige top injectors (found on 85 CFI 5.0's)
50lbs = Gray top injectors
55lbs = Black w/ Gray top injectors
65lbs = Purple top injectors
160lbs (1600cc) = White top injectors w/ black body
iste
Re: priepustnost vstrekovacov bosch, rozdelenie podla farby
Nedeľa, 13. Decembra 2009, 12:47
tu je aj obrazok podla stupnov,aby sa dalo predstavit ako to tam frcka to palivo
Užívatelia prezerajúci toto fórum: Žiadny pripojení užívatelia a 36 neregistrovaných
