Moderátor: SmartBastard
Vlado Behun
Registrovaný: 8.4.2008
Auto: E46 M3
Priklad udrzby E46 M3 (AJ, no celkom prikladne)
Pondelok, 16. Apríla 2012, 19:05
http://m3forum.net/m3forum/showthread.php?t=190111
Part 1: What you should do to keep the car running as cheaply as possible in the long term. AKA maintenance requirements.
First, an explanation of the service interval counter on the e46 M3: Every time you turn on the car the cluster will say either "Inspection" or "Oil Service", followed by a number (a negative number if you've gone over). As you drive, and based on how hard you drive, the number will count down to zero. When it reaches zero you need to do the service requested (oil service or inspection) and reset the service interval. The car will alternate: oil service, inspection, oil service, inspection, every time you reset it. The car is not capable of displaying if you are do for inspection 1 or 2, so that is up to you to determine.
If you follow this thread, you should basically do the following:
new car with 0 miles
oil service at 7500 OBC service interval miles (not odometer miles!)
oil service at 15,000 OBC service interval miles (not odometer miles!), reset counter
inspection 1 at 15,000 miles
inspection 2 at 15,000 miles
and then start the entire loop again
Resetting the service interval procedure (the free way):
-Ignition key must be off
-Press and hold the trip odometer reset button in the instrument cluster (left button), and turn the ignition key to the first position.
-Keep the button pressed for approx. 5 seconds until one of the following words appear in the display: "Oil Service" or "Inspection", with "Reset".
-The service due is shown with "reset" if the coded minimum consumption limit has been reached and resetting is possible. If "reset" is not shown, the minimum limit has not been reached and resetting is not possible.
-Press and hold the reset button again until the word "Reset" begins to flash.
-While the display is flashing, press the left button briefly to reset the service interval. After the display has shown the new interval the following will appear: "End SIA".
-The system can only be reset again after 2.5 gal (10 liters) of fuel have been consumed.
Oil Service:
-twice as often as the OBC (on board computer, the count down that appears on the odometer when you turn the car on) calls for. AKA, replace the oil when the service interval says 7500 or 0. Do not skip changing the filter. In fact, it is much more important that you change the filter than the oil (not that I'm promoting that either, but if you feel the need to skimp... just change the filter.) Use Castrol 10W-60 ONLY!. Pictures as to why you want to do them more often than BMW recommends here. Reasons to stick to Castrol TWS 10W-60 here. Note that by doing it twice as often as the service interval counter asks for, you'd actually doing it around every 6000 miles (varied by how hard you drive the car).
-Oil change DIY here
Inspection 1
-oil change (see above)
-diff fluid:
OEM fluid Castrol SAF-XJ + FM booster
BMW part# PN 83-22-2-282-583
diff fluid swap diy here
-tranny fluid:
OEM Fluid (6mt & SMG) Castrol MTF-LT-2 (NOT LT-3) fluid
BMW part# 83 22 0 309 031
-Engine air filter
-cabin air filter
-valve adjustment
valve adjustment DIY here
-chevron techron fuel system cleaner (bottle that treats up to 20 gallons). Try to do this and have it out of the system before your oil change.
-If using turkey baster method, do power steering fluid every inspection. If doing full power steering fluid flushes, you can wait till inspection 2. Use ATF. Brand doesn't matter that much, I use Mobil 1 multi ATF.
Inspection 2
-diff fluid:
diff fluid sway diy here
-tranny fluid:
-Engine air filter
-cabin air filter
-valve adjustment
-coolant flush (50/50 distilled water and BMW coolant)
DIY here
BMW Antifreeze/Coolant - 1 gallon jug
OEM Part #: 82 14 1 467 704
-Power steering fluid flush. If you do turkey bastering every inspection (1 and 2), you can just baster here. If you are only doing inspection 2 power steering fluid service, do a full flush. Brand doesn't particularly matter here, any ATF will work. I use Mobil 1 multi ATF. Flush DIY here.
-fuel filter DIY
-spark plugs
spark plug DIY here
-RSMs and RTABs (if you have the stockers)
video diy here
-guibo
-tranny mounts
tranny mount DIY here
Yearly (every spring works well for me):
-brake fluid flush
DIY here
-general inspection-- eg cracks in suspension mounts, subframe, check belts for cracks, bent control arms, brake pads and rotor thickness (obviously continue to monitor more regularly if low), etc
-wiper blades
75,000 miles
-Begin to think about replacing your radiator. The plastic parts of BMW radiators do NOT age will and when they fail (which they will) you must stop the car immediately or you will destroy the engine. Side note here, if the temp gauge is ever in the red, STOP THE CAR IMMEDIATELY. You may be able to time the radiator swap to go along with a coolant flush, which will save you a little money. I know my car should be due for inspection 2 around that point. There are several all metal radiators out there that mean you'll only have to do this swap once. I'll be putting a Zionville radiator in my car, which you can get from several places on the web (or from me ).
100,000 Miles
-fuel injectors cleaned (you can get all 6 cleaned to new spec here for the price of buying one new injector)
-I would do a belt swap at this point, even if they aren't visibly cracking
-Belt-idlers
-FCABs
-engine mounts
-cooling system: At this point you might want to consider replacing the entire cooling system. If you want to car to be bulletproof, this is the route to take. That said, they are fairly pricey components so you could wait for them to fail and get a few extra value miles out of them. At 100,000 miles, I replaced:
Radiator
Thermostat
water pump
fan clutch
coolant piping
-Other items to consider if you true want the car to be 100% reliable:
alternator
fuel pump
starter
coil packs
CPV (constant pressure valve)-- you can replace just the o-ring with the one linked below and never have to deal with this again
Clutch
The clutch is entirely driver (and mod) dependent. ArtM3 replaced his at 100,000k plus and it was only 1/3 used up, so don't assume it's going and replace preventatively-- wait till you feel it start to slip.
Update: replaced my highly abused clutch at ~100,000 miles (see below) and it still had at least 50% life left!
Suggested replacement items when doing the clutch (because they're easy when you're in there and a PITA when you're not): clutch, pressure plate, pilot bearing, throw out bearing, rear main seal, guibo, tranny mounts, center support bearing, and check the drive shaft joint for play. I would highly recommend doing every item listed there, as they will fail before your next clutch replacement and labor will be EXPENSIVE on them with the trans out of the car. Right now the labor is all buy free and the parts are cheap.
Note: Assuming you don't let the clutch slip before you replace it (scoring the flywheel), there is NO reason to replace or resurface the flywheel when replacing the clutch. The stock flywheel is good for at least 2-3 clutches. This is an expensive part that you don't need to replace IF and only if you replace the clutch as soon as it begins to let go. Clutches are cheap! flywheels are expensive! Don't let your clutch slip!
Battery
replace every 5 years or after a complete drain (unless it's an optima, which you can recharge after a complete drain)
Part 2: Things to keep the car like new or better:
(some repeat from above because they do both)
Shocks
Shocks can last anywhere from 30,000 to 80,000 miles, depending on how the roads are where you live. Pothole and the like determine shock life, track use is not particularly hard on them. Lowering springs will also drastically lower their life (the lower the springs the faster they age).
video DIY here
-RSMs (rear shock mounts)-- with shocks
50,000 miles: RTABs, guibo, tranny mounts
100,000 miles: engine mounts, front control arms (must be replaced to replace the ball joints), FCABs (front control arm bushings) steering flex coupler, driveshaft center support bearing, diff mounts, ball joints (4 total), pre cat 02s, rear control arm inner bushings (upper and lower), subframe bushings.
Part 3: Permanent fixes for e46 common failure items
Difficulty scale: 1 is a cabin air filter, 10 is a complete engine rebuild.
CPV
Problem: O-ring degrades with time
Solution: high temp dupont o-ring: http://m3forum.net/m3forum/showthread.php?t=369406
Price: $5 for parts
Labor: 1-2 hours
DIY difficultly: 2
RTABs
Problem: wears out every ~40,000 miles causing handling, tire wear, and alignment issues
Solution: Polyurethane RTABs. Stock OEM rubber stiffness from AKG or stiffer (improve handling) from PowerFlex
Price: ~$100 for parts
Labor: 2-4 hours
DIY difficulty: 3
Subframe
Problem: subframe tears out of car after repeated sudden acceleration
Solution: Turner subframe kit. Can be welded in or epoxied in. http://www.turnermotorsport.com/p-91...ement-kit.aspx
Price: $126 for parts
Labor: 8-10 hours
DIY difficulty: 6
Subframe Bushings
Problem: stock bushings tend to be tired by ~100,000 miles. That said, if your subframe is getting reenforced, I'd do these while you're in there!
Solution: AKG polyurethane subframe bushings. Can be had in stock stiffness or stiffer. For a car that still gets driven on the street, I'd go with stock stiffness. I'd avoid PowerFlex for this-- they have some fitment issues.
Price: $300 for parts
Labor: 8-10 hours if you do them alone, 1 hour if you do it while you're in there for subframe work
DIY difficulty: 6
VANOS bolt failure, which can lead to engine failure
Problem: intake cam sprocket bolts back out over time and eventually sheer.
Solution: Z4 M S54s use an updated bolt design that is make of harder steel. Combine with loctite.
Price: $5 for parts
Labor: 5-8 hours
DIY difficulty: 7
VANOS exhaust cam sprocket tab failure
Problem: tabs that connect the cams to the sprockets break off over time
Solution: Dr. VANOS replacement. Cryogenically frozen for extra hardness and larger tabs to take the slack out of the system (reduce stress).
Price: $800 for part
Labor: 6-9 hours
DIY difficulty: 8
Radiator
Problem: The radiator is made of plastic and aluminum, which expand and contract at different rates. Over time, this results in cracking
Solution: all aluminum radiator. Mishimoto sells a cheaper unit that may have some fitment issues (especially if supercharged), Bimmerworld sells a good midrange unit or Zionville sells a top of the line unit.
Price: $400-1000 for parts
Labor: 3-4 hours
DIY difficulty: 4
Coolant Piping
Problem: Over time and heat cycles the coolant pipes get brittle and crack
Solution: silicone pipes. Don't get brittle over time. http://www.rogueengineering.com/mm5/...Category_Code=
Price: $ for parts
Labor: 4-5 hours
DIY difficulty: 4
Differential Mount Bolts
Problem: the stock bolts sometimes snap over time
Solution: BMW updated the part at some point in the M3 production cycle. The new bolts are stronger, and I haven't yet seen anybody snap any. Thread here: http://m3forum.net/m3forum/showthread.php?t=345096
Price: ~$10 for parts
Labor: 2-3 hours
DIY difficulty: 3
VANOS sealing plate
Problem: VANOS sealing plate comes with o-rings rated for 212º. Sometimes it gets hotter than 212º in there.
Solution: Beisan systems VANOS sealing plate. Come with o-rings rated for 400º. http://www.beisansystems.com/procedu..._procedure.htm
Price: ~$40 for part (final price TBD, being release november 2011)
Labor: 1-2 hours
DIY difficulty: 5
VANOS solenoid failure
Problem: cracked solder joints in the solenoid coil pack resulting from cold solder joint, heat cycling, and mechanical movement
Solution: Beisan systems rebuilt VANOS solenoid pack-- OEM with extra strength added. http://www.beisansystems.com/procedu..._procedure.htm
Price: $300 (after core return)
Labor: 1-2 hours
DIY difficulty: 5
Rear Axles
Problem: the stock rear axle sometimes fail, especially on cars that are drag raced and/or launched hard, often
Solution: beefed up axels
http://www.driveshaftshop.com/import...ar-c-v-upgrade
Price: $1000 plus stock axles
labor: 1-2 hours
DIY difficulty: 3
Rear Shock Mounts
BMW's rear shock mounts tend to fail some time after 50,000 miles, and when they do they can do a LOT of damage on their way out.
Solution: Aftermarket RSM with reinforcement plate. Rouge makes a nice set.
Price: $100 for parts
Labor: 1-2 hours
DIY difficulty: 3
Shocks
Problem: Stock shocks wear out some time between 40,000 and 80,000 miles (depending on the quality of your roads)
Solution: Koni Yellows. These aren't truly a permanent fix like the others above, but they last 2-3 times as long AND they're rebuildable when they need it, so you don't have to replace them. They also have a lifetime (for the first owner) warranty against failure, unlike the stock units. So they're pseudo lifetime parts
Price: $600-1000 for parts (depending on compress to adjust or top adjustable)
Labor: 4-5 hours
DIY difficulty: 4
If you run aftermarket camber plates:
Front shock tower reinforcement plate
Problem: Some camber plates do not distribute the load of the shock evenly across the shock tower, which over time can lead to the shock tower cracking.
Solution: OEM BMW shock tower reinforcement plates. These come from BMW Africa, where they put them on cars that have to frequently drive on unpaved roads. http://www.turnermotorsport.com/p-32...ates-pair.aspx
Price: $23
Labor: 1 hour
DIY difficulty: 2
If you run aftermarket rear ride height adjustors:
Rear control arm reinforcement plate
Problem: the ride height adjustor focuses the weight of the car on a smaller area than the stock spring does
Solution: Rear spring perch reinforcement plate http://www.rogueengineering.com/mm5/...Category_Code=
Price: $55
Labor: 1 hour
DIY difficulty: 2
Ex - Renault 5 TL, Renault 5 GT Turbo, Fiat Uno Turbo, Peugeot 106 1,6 GTi, Ford Focus ST, Impreza Sti (now)
Ex - BMW E30 325 Coupe
Ex - BMW E36 316 Compact
Ex - BMW M3 E36 3,2
Ex - BMW M5 E39
Ex - BMW M3 E46
Current: Non BMW (+ E46 Compact 2,0d)
Roman804
Registrovaný: 21.3.2010
Auto: M3 E92, F11 LCI
Re: Priklad udrzby E46 M3 (AJ, no celkom prikladne)
Nedeľa, 9. Septembra 2012, 06:51
zaujímavé,podľa toho by sa menila spústa vecí ktoré ešte môžu slúžiť,suma takejto údržby by bola astronomická,ale auto by bolo neustále skoro ako nové
pribehy-nasich-aut/topic-t31012.html
ex-lada2106,ford escort cabrio1983,ford scorpio1986,škoda100 1974,škoda1000MB1969,vw polo1997,nissanAlmera2001,honda CRV2005,mercedesA1998, kawasakiZR500 1984,yamahaFazer600 2004,yamahaGrizzly2005
Mr.S
Registrovaný: 5.1.2008
Nedeľa, 9. Septembra 2012, 08:50
... preto M3 z USA 8)
ex E46 316ti M-paket
ex E46 325ci M-paket
ex E46 M3 Competition
ex E46 M3 Coupe
ex E46 M3 Convertible
ex E92 330xd A-Paket
ex E91 335d M-paket
ex E90 M3
ex E92 M3 Competition
ex E92 M3 DCT AM
+ dalsich 500 koni
kačo
Registrovaný: 2.9.2006
Auto: OOOO A6 3.0TDi
Streda, 12. Septembra 2012, 09:08
Mr.S napísal:
:thumbup:
E36 325 TDS (ex)
E46 MT-330CI (ex)
E46 M3 (ex)
E70 X5 35d (ex)
dodoIPD
Registrovaný: 21.4.2008
Utorok, 18. Septembra 2012, 07:55
Oni nato maju ...
