Štvrtok, 22. Novembra 2007, 14:53
obsah - 3453ccm / radovy 6 válec (210kW)
max. výkon - 286koní/6500 ot/min (americka verzia 256koni)
max. krútiaci moment - 340nM pri 4500 ot/min
prevodovka - 5st. manual
rozmer pneumatík - predok 220/55/16 - - - zadok 225/50/16 7,5x16
rozmery karosérie - 4620/1700/1400mm
rázvor - 2625mm
váha - 1465 kg
počet dverí/počet miest na sedenie - 4/4
zrýchlenie 0-100 km/h - 6,1 s
maximálna rýchlosť - 251 km/h
priemerna spotreba - 15,3l/100km
Prvé zaregistrované auto vyrobené - 1984
Posledné zaregistrované auto vyrobené - 1987
Na zaver par zaujimavych info
Zakladna cena 80,750 DM |Heated washer jets |
|Standartna vybava | Posilovac riadenia |
|Spatne zrkadla, lave a prave, | 25% svornosti - diferencial |
|electrically adjustable and heated
|ABS | Sportove sedacky |
|Check control - fault diag- | Socket for rechargeable torch |
|nosis panel which verifies | |
|oil level, water temp., | |
|washer fluid level, light | |
|bulbs etc. | |
|Rev counter | Central Locking |
|Heated drivers door lock | Options |
|Brown tinted glass | Buffelo leather seats |
| | 6460,- DM |
|Thermostatically controlled | Metallic paint |
|cabin heating | 980,- DM |
|Heated rear window | Manual sun-roof |
| | 1165,- DM |
|Alloy wheels | |
| | Elektricka roletka |
|Adjustable reach leather | 1525,- DM |
|steering wheel | |
| | Heat resistant glass (green) |
|Hmlovky | 190,- DM
Prevodove pomery
I 3.51
II 2.08
III 1.35
IV 1.00
V 0.81
R.3.71
staly pomer 3.73:1. 38.3 km/h pri 1000/min na 5 prevodom stupni
Objem palivovej nadrze - 70l
pomer vahy predok/zadok 52/48 %
Zrychlenie a max. rychlost:
Maximalna rychlost (6550/min na 5 prevodom stupni) 251 km/h
Zrychlenie
0-60 3.0s
0-80 4.4s
0-100 6.1s
0-120 8.4s
0-140 11.0s
0-160 14.5s
0-180 19.0s
0-200 25.8s
400m s pevnym startom14.1s
1km s pevnym startom 25.9s
Flexibilita
40-100 km/h (IV st) 12.3s
60-120 km/h (V st) 16.5s
Rychlostna odchylka
Tachometer Skutocnost
50 km/h 44 km/h
100 km/h 94 km/h
130 km/h 123 km/h
160 km/h 151 km/h
180 km/h 169 km/h
220 km/h 201 km/h
Hluk v interieri
pri 50 km/h 65 db(A)
pri 100 km/h 70 db(A)
pri 130 km/h 73 db(A)
pri 140 km/h 74 db(A)
pri 160 km/h 77 db(A)
pri 180 km/h 82 db(A)
pri 200 km/h 82 db(A)
Spotreba
DIN in Liter/100 km
pri 90 km/h na 5 prevodom stupni 7.8
pri 120 km/h na 5 prevodom stupni 9.7
mesto 16.5
Test spotreby Litrov/100 km
Minimalna 12.0
Maximalna 19.2
cesta 1 triedy @ 80 km/h 14.4
Dialnica @ 150 km/h 17.9
priemer 15.3
Riadenie a odpor pedalov
Riadenie pri stojacom aute 42 N
Riadenie pri iducom aute 33 N
Spojkovy pedal 170 N
Plynovy pedal 20 N
Brzdovy peda pedal pri 80% z maximalnej brzdnej sily 120N
POZOR : hodnoty uvedene vyssie su pre EUROPSKU verziu.
hodnoty AMERICKEJ verzie sa trosku lisia...
zdroj info: internet
prelozil: Peppo
- s38.jpg (26.26 KiB) 3174 zobrazení
- E28S.jpg (60.67 KiB) 3175 zobrazení
- budiky1.jpg (20.29 KiB) 3174 zobrazení
- bmw-m5-e28-rear.jpg (30.1 KiB) 3173 zobrazení
- bmw-m5-e28-front.jpg (28.83 KiB) 3173 zobrazení
- bmw_m5_e28_2.jpg (17.64 KiB) 3174 zobrazení
- 20409141_thumb.jpg (188.31 KiB) 3173 zobrazení
- 623d27aj0.jpg (26.83 KiB) 3173 zobrazení
- 191-9146_IMG.jpg (46.59 KiB) 3173 zobrazení
- 65e227ts1.jpg (41.34 KiB) 3173 zobrazení
- 63fe27hc0.jpg (25.4 KiB) 3173 zobrazení
- 046db2c9f6cd956009d71024206fbebb.jpg (91.88 KiB) 3173 zobrazení
