RACERMAN
Registrovaný: 16.10.2011
Reset adptacnych hodnot prevodovky INPA vs TOOL32
Nedeľa, 7. Júla 2013, 23:25
Chcem sa opytat aky reset adaptacnych hodnot automatickej prevodovky robi INPA ?
Na jednom zahranicnom fore som nasiel reset pod TOOL32 nasledovne:
I found this thread when trying to do the adaptations for my GM transmission and got the same errors as TS when using INPA.
Decided to use Tool32 (loaded GS1912.prg) instead to do it. However steuerngeraete_ reset doesn't seem to do anything to reset the adaptations. The prg file has various command to read the adaptation values.
STATUS_12UPSHIFTADAPTS
STATUS_23UPSHIFTADAPTS
STATUS_34UPSHIFTADAPTS
STATUS_45UPSHIFTADAPTS
STATUS_56UPSHIFTADAPTS
STATUS_12UPSHIFTADAPTS_2
STATUS_23UPSHIFTADAPTS_2
STATUS_34UPSHIFTADAPTS_2
STATUS_45UPSHIFTADAPTS_2
STATUS_56UPSHIFTADAPTS_2
after running steuerngeraete_ reset, the values did not change at all.
however, i found another 2 commands which seemed to be for resetting adaptations.
STEUERN_ADAPTS_RESET_PLANT
STEUERN_ADAPTS_RESET_WITHOUT_TCC
running the 2nd command changed the adaptation values and seemed to set the values to factory default.
there is an additional command STEUERN_TCC_ADAPTS_RESET which seems to be for resetting adaptations for the TCC (Torque Converter Clutch) which i did not run.
after resetting the adaptations, the transmission seems to shift smoother and the gear 1-2 or 2-1 jerk is gone.
1./ Rozumiem tomu dobre ze jedno je prikaz je reset adaptacnych hodnot a druhy je aj reset menica momentu...spojka menica otaciek? TCC (Torque Converter Clutch) kedy sa pouziva ?
2./ Aky je v tom rozdiel ?
3./ Udajne je to pre GM prevodovku pisane...je jedno ci je GM ci ZF ?
4./ Reset adaptacnych hodnot pod INPOU je ktory z tych dvoch ?
zaujima ma to pre rozsirenie obzoru, ak niekto vie dakujem :wink:
YAMAHA YZF R6, ATV QUAD
