michaltt
Registrovaný: 12.5.2011
e39 kola na e46 mpacket
Streda, 20. Júla 2011, 21:53
Zdravim
v piatok by som si chcel ist po disky z e39 a rad by som ich supol na e46 Mpacket II. Viem ze to ma ine rozmery, nema s tym niekto skusenosti ci to nebude suchat ? S tym ze budu trcat ratam ale tak...zidu sa nejaky rady predtym nez tam vobec vyrazim. co som cital tak z e39 sa da, ale naopak moc nie.
vdaka
Lowered wagon - pribeh
michaltt
Re: e39 kola na e46 mpacket
Streda, 20. Júla 2011, 22:01
len ci to nebude mat nejaky vplyv na auto....
"Widening track isn't really as simple as just using different wheels with more - offset, (less positive offset). The whole steering geometry needs changing to keep the same dynamics. If you just add more - offset, (less positive offset) you are changing the scrub radius. That increases the possibility of brake pull, more steering pull and wander on rough roads, more rolling toe out (needs toe tweaking to save your tyres), and obviously alters the handling characteristics.
Hub rings are essential, for perfect concentricity of the rims. "
michaltt
Sobota, 23. Júla 2011, 10:02
takze kto by mal v buducnosti zaujem nieco take skusit, tu su fotky. Bolo by to v pohode keby sa vytiahli blatniky ale tak to radsej volim ine kola, ktore budu pasovat. I ked...tie BBSky su raritka a po nejakych upravach by vyzerali peckovo.
michaltt
Sobota, 23. Júla 2011, 10:55
neviem ci sa ti oplatia, su dost okusane po okrajoch, 3 su krive, 1 je prasknuty. Este kopec roboty s nimi :smile:
8J et20 a 9j et24
tu ich typek dava na e36
http://www.stanceworks.com/forums/showthread.php?t=934
mys_iak
Registrovaný: 14.3.2009
Auto: Bmw F31 316d
Sobota, 23. Júla 2011, 16:14
ja by som ich dal sustruhom zbehnut ;) ak je s coho ;)
Bmw F31 316dAT
ex: e61 530iA+LPG
e36 320Ci+LPG
e39 530dAT
e46 320dT
e91 320d
svanto66
Registrovaný: 31.5.2009
Auto: E91 318d LCI
Utorok, 20. Marca 2012, 09:58
michaltt napísal:
caute chalani..tiez mam moznost kupit kola z E39 17" 225/45 a zaujimalo by ma ci to bude mat nejaky vplyv na auto :-k
E93 M3 LCI
E91 318d LCI
E46 320d EX
michaltt
Utorok, 20. Marca 2012, 16:29
na foto vidis, bude to trcat von, inak vplyv ziaden
svanto66
Auto: E91 318d LCI
Streda, 21. Marca 2012, 00:42
michaltt napísal:
na foto su tiez 17" 225/45 kola? ake ET maju?
E93 M3 LCI
E91 318d LCI
E46 320d EX
michaltt
Streda, 21. Marca 2012, 08:25
ano su to 17, et je tam okolo 20-24
janyPD
Registrovaný: 28.1.2012
Streda, 21. Marca 2012, 18:28
No kamarát mal tiež na e 46-ke kolá 5-ky M5 e34. Zadné disky 17-ky 9J ET22. Strašne to šúchalo. Muselo sa to vymeniť za origo m-kovice na e-46.
svanto66
Auto: E91 318d LCI
Streda, 21. Marca 2012, 20:18
hmm ja mam este sportovy podvozok od vyroby tak neviem ci by to robilo dobrotu :roll:
E93 M3 LCI
E91 318d LCI
E46 320d EX
janyPD
Streda, 21. Marca 2012, 20:43
svanto66 napísal:
Ak budeš chcieť disky z e39 máš štyri možnosti: upraviť blatník, stočiť disky na sústruhu, dať užšie gumy alebo vložiť dorazy do zadných tlmičov.
svanto66
Auto: E91 318d LCI
Streda, 21. Marca 2012, 20:52
janyPD napísal:
tak to sa radsej pekne vykaslem na tie disky a kupim E46tkove alebo este lepsie E9xtkove :thumbup:
E93 M3 LCI
E91 318d LCI
E46 320d EX
