ifojtik
Registrovaný: 1.1.2009
neznama chyba carsoft
Pondelok, 28. Septembra 2009, 22:41
poradte ak viete. svieti kontrolka ASC... ABS funkcne..
carsoft vypisal chybu v jednotke ABS/ASC:
74
nic viac.. co to moze byt?
e31 840CI
Z3 Coupe 28i
e46 320Ci cabrio
e61 520d
e65 750
-ex F10 530Xd
-ex F02 740Li
-ex e92 330xd
-ex e65 735
-ex e63 630i
-ex e39 M5
-ex e63 645 SMG
-ex e46 318
-ex e65 745
-ex e65 730d FL
-ex e46 330i supercharger
-ex e46 330CI cabrio
-ex e65 735
-ex E39 540
-ex E39 535
-ex e39 535IA
-ex E46 323
-ex E36 318
a nejake ine
Rudkoo
Registrovaný: 2.2.2007
Re: neznama chyba carsoft
Utorok, 29. Septembra 2009, 07:29
napíš celú chybu ktorú ti to vypisuje...
tento zoznam sice neni BMW ale malo by to sedieť...
ABS Codes
00 (No Light At All) Blown Back-Up/Meter Lights (10A) Fuse, Bulb, Poor Body Ground, Open/Cut Wire Between Fuse and Bulb or bulb and ABS Controler, ABS Controler Not Grounded, Faulty ABS Controler.
00 (Light Stays On) Blown R/C Mirror (7.5 A) fuse, Open Circuit Between The Under-dash Fuse/Relay Box And ABS Control Unit, Open Circuit Between The Battery And The Under-hood ABS Fuse/Relay Box, Blown ABS B2 (15 A) Fuse, Open Circuit Inside the Under-hood ABS Fuse/Relay Box, Open Circuit Between the Under-hood Fuse/Relay Box And The ABS Control Unit, Faulty Alternator, Open Circuit Between The alternator And ABS Control Unit,Short To Body Ground In The WARN Circuit Between The ABS Indicator Light And ABSS Control Unit Or Faulty ABS Control Unit
10 ABS Pump Motor Over-Run
12 Pump Motor
13 High Pressure Leakage
14 Pressure Switch
15 High Pressure System
21 Parking Prake
31 Pulser: Right Front
32 Pulser: Left Front
34 Pulser: Right Rear
38 Pulser: Left Rear
312 Different Diameter Tire Installed
41 Wheel Sensor: Right Front
42 Wheel Sensor: Left Front
44 Wheel Sensor: Right Rear
48 Wheel Sensor: Left Rear
50 Rear Wheel Lock: Right / Left
54 Rear Wheel Lock: Right
58 Rear Wheel Lock: Left
60 Fail-Safe Relay: Right / Left
61 Fail-Safe Relay: Front
64 Fail-Safe Relay: Rear
71 Solenoid: Right Front
72 Solenoid: Left Front
74 Solenoid: Rear
81 ABS Functoin
82 CPU Comparison Failed (i.e. Bad ABS Control Unit)
84 IC Failed (i.e. Bad ABS Control Unit)
ifojtik
Utorok, 29. Septembra 2009, 11:33
nevypisalo nic ine.... len to cislo 74
e31 840CI
Z3 Coupe 28i
e46 320Ci cabrio
e61 520d
e65 750
-ex F10 530Xd
-ex F02 740Li
-ex e92 330xd
-ex e65 735
-ex e63 630i
-ex e39 M5
-ex e63 645 SMG
-ex e46 318
-ex e65 745
-ex e65 730d FL
-ex e65 735
-ex E39 540
-ex E39 535
-ex e39 535IA
-ex E46 323
-ex E36 318
a nejake ine
Utorok, 29. Septembra 2009, 15:26
ifojtik napísal:
Treba to pichnut na poriadnu diagnostiku, s carsoftom vela neporiesis a dokonca to niekedy pise aj bludy namiesto realnych chyb.
