Simonis
Registrovaný: 27.10.2018
Retrofit AC basic to AC high- staci vymenit panel!
Nedeľa, 8. Decembra 2019, 10:32
Zdravim, uz sa to tu riesilo a uzavrelo sa to tym, ze to mozne je ale je potrebna kompletna prerabka auta. Ide o vymenu panela jednozonovej klimatizacie za panel dvojzonovej klimatizacie (krajsie cudliky) pricom funkcnost klimy ostava ako jednozonova akurat pribudnu nejake nove funkcnosti. Podarilo sa to chlapikovi z tohto fora cital som aj o dalsich uspesnych prerabkach, vraj staci vymenit cisto len panel a bude to fungovat, ide sice asi skor o pred LCI model ale podla mna to bude fungovat aj u LCI modeloch. Po nakodovani pribudnu nejake nove funkcie aj priamo v iDrive nastaveni. Otazka je, skusal to uz niekto? Vymenit len panel a nakodovat?
Ak je povolene, prikladam aj link:
https://forum.bmw5.co.uk/topic/59683-success-ac-basic-to-ac-high/
[color=#8d9aa6][color=inherit]Posted September 14, 2011[/color]
[size=100]Came home early today so got to work on this retrofit.
I can confirm it to a be a complete success!
Front screen quick clear works
Driver side vent control works for all vents but they can be manipulated individually (top, middle, bottom).
Independent ventilation mode timer works
Max cooling mode works
Manual vent control mode works (for all vents but can be set top middle and bottom individually)
Extra heat or extra cooling works for both auto and manual modes
Solar sensor not fitted yet due to waiting for the 4-pol connector (will do this friday)
Auc sensor needed for auto recycle (I may add this at a later date)
Rear fresh air grill high version can be added really easy and I may do this as well at a later date
Condensation sensor can also be added fairly easily.
I will do a DIY for this.
[/size][/color]
[size=100]
[color=#3d6594][img=640x427]https://forum.bmw5.co.uk/uploads/monthly_09_2011/post-36958-0-43547100-1316024234_thumb.jpg[/img]
[/size][/color]
