Moderátor: jkk
stanleyy
Registrovaný: 29.8.2008
Auto: G30 530xD, F20 116i
Hifi audio
Piatok, 28. Augusta 2015, 05:55
Ahojte, nema niekto z vas Hifi audio v F20? V dverach nemame vyskove reproduktory, ale myslel som si, ze to tak na 1tke ma byt... Nejako sa mi to ale nezda - vsade v zahranicnych forach pisu, ze Hifi system ma tie vyskove reproduktory zabudovane... dufam, ze to nedomotali v tovarni...
To audio hra slusne, ale v F30 nam Hifi system hra este o triedu lepsie...
G30 530d xDrive, F20 116i, ex F31 328i xDrive, ex BMW 525d F10, ex BMW 320d e90
hellah
Registrovaný: 30.6.2015
Auto: F21 118i LCI
Re: Hifi audio
Nedeľa, 11. Októbra 2015, 21:01
Ja som si tiez myslel, ale nie su. to len v HK
Hifi
Multi-channel loudspeaker system with analogue amplifier for vehicle-specific equalising, 205W amplifier power, multi-
channel capability and seven speakers as follows:
- Five mid-range speakers (two in the front doors, two in the rear parcel shelf holder and one in the instrument panel)
- Two central bass speakers (underneath the front seats)
HK
harman/kardon speaker system with surround mode, digital amplifier with vehicle-specific equalising, 360W amplifier power,
multi-channel capability and 12 speakers as follows:
- Five mid-range speakers (two in the front doors, two in the rear parcel shelf holder and one in the instrument panel, top
centre)
- Five tweeters (two in the mirror triangles with harman/kardon branding, two in the rear parcel shelf and one in the instrument
panel, top centre)
- Two central base speakers (under the front seats)
only with Z0E / Z0F
/ 663
stanleyy
Re: Hifi audio
Pondelok, 12. Októbra 2015, 14:43
na F30 mam v hifi tweetery aj vo dverach, tak isto som mal aj v F10, preto som cakal, ze budu aj na F20 a neboli :)
je ale dostupna retrofit sada "Alpine", ktora ich obsahuje.. stoji asi 5 kil, vsetko je p&p. Akurat treba dokupit na dvere nove plastove kryty tweeterov.
hellah
Auto: F21 118i LCI
Re: Hifi audio
Pondelok, 12. Októbra 2015, 21:20
jj, ten alpine retrofit som pozeral, ale asi to nebudem riesit. akurát tak max do predných dverí pridám tweetery
kent60
Registrovaný: 15.12.2015
Auto: BMW 118d F20
Re: Hifi audio
Utorok, 15. Decembra 2015, 08:49
Taky jsem zatoužil po upgrade audia a řešil jsem umístění výškových reproduktorů do plastového trojúhelníku v předních dveří. Nakonec jsem koupil u dealera BMW "Kryt rám okno přední vlevo" TOP HIFI číslo dílu 51 33 7 270 759 (vpravo 51 33 7 270 760) dohromady za 5187,- CZK a světe div se, součástí dodávky je také těsnění do trojuhelníku ( 51 33 7 288 229, 51 33 7 288 230) a tweetery Harman Kardon (65 13 9 226 357). Stačí doplnit pouze výhybku.
Já si však předem zakoupil reproduktory GLADEN ONE 201 BMW a tak mám výškové reproduktory OEM BMW HK navíc.
matus699
Registrovaný: 5.7.2014
Auto: e46 e87 e90 f31
Re: Hifi audio
Piatok, 18. Decembra 2015, 13:08
neviete nahodou aka je montazna hlbka pri wooferoch pod sedanami?
priemer by mal byt 8 palcov/20cm ak sa nemylim len hlbku neviem...
RACERMAN
Registrovaný: 16.10.2011
Re: Hifi audio
Streda, 23. Decembra 2015, 13:44
matus699 napísal:
pozri toto a potrebujes este k tomu redukcie tiez co su tam z MDF
http://www.copper.sk/eshop/ozvuc-auto-t ... 00neo.html
YAMAHA YZF R6, ATV QUAD
PatoTT
Registrovaný: 8.12.2012
Auto: E87
Re: Hifi audio
Streda, 23. Decembra 2015, 14:57
hlbka nič moc, ja osobne tie pod sedačku mam odpojene a mam spravenu bednu v kufri
- Bmw e46 330d
- Bmw E39 520i EX
- Bmw E87 120d
- Opel Calibra 2,0 16v EX
- Alfa Romeo 166 2,4jtd EX
- Opel Calibra 2,0 8v EX
matus699
Re: Hifi audio
Streda, 30. Decembra 2015, 21:27
dat 2x150e za 2 repro a este ani neviem ako to bude hrat to asi nedam je to dost vela... pozeral som sady za cca 400e len repro na vymenu tiez mi to prislo dost nakolko neviem co mam cakat radio klasicke zesik tam nemam keby som menil plus obe veci dostanem sa na dost velku sumu...
asi budem musiet ostat na tom istom co tam mam...
mozno niekedy ked budem lepsie zarabat :D
PatoTT
Auto: E87
Re: Hifi audio
Sobota, 2. Januára 2016, 12:05
mohol by som jebis cele sady čo predavaju aj repraky po 150€.... šak predne a zadne repraky 10cm maš dvoje za 40-50€ ,zosik kupiš tiež od 30-50€ a už to len všetko prekablovat,je to na tebe či ponechaš subač pod sedadlom alebo dorobiš do kufra ale myslim si že upgradovat ten subač pod sedadlom za lepši sub je blbost,lebo moc pytaju za tie repro a ani vykon nemaju poradni,tam iba ide o tu hlbku
- Bmw e46 330d
- Bmw E39 520i EX
- Bmw E87 120d
matus699
Re: Hifi audio
Piatok, 15. Januára 2016, 00:41
teraz dúmam nad týmto :D
http://www.ahifi.cz/reproduktory-gladen ... s-produktu
GLADEN ONE 201 BMW za 6.990 Kč čiže cca 260€
nemá to tu niekto náhodou aký je rozdiel oproti sérii na rádii business?
PatoTT
Auto: E87
Re: Hifi audio
Piatok, 15. Januára 2016, 14:53
business radio je same o sebe o ničem,treba vymenit ked chceš mat kvalitu,aj nemusiš menit,ale aspon zosilovač dokup
tie repraky možu byt dobre ale furt to je bez zosilovača tak moc odteho nečakaj, osobne by som tolko zato nedal, za 260€ spraviš omnoho viacej ako len vymenit predne reproduktory
- Bmw e46 330d
- Bmw E39 520i EX
- Bmw E87 120d
matus699
Re: Hifi audio
Piatok, 15. Januára 2016, 15:55
Do kufra bednu nechcem je tam uz teraz malo miesta a nie to este tam buchnut bednu. Ale chcel by som pocut rozdiel v serii a z repro gladen pripadne este zesik by sa dal riesit.
Susty
Registrovaný: 20.6.2008
Re: Hifi audio
Pondelok, 29. Februára 2016, 18:58
V zaklade hra hifi ozaj plechovo, zle podanie basov. Ak ale pocuvate hudbu cez bluetooth, tak si skuste nastavit eqalizer cez zariadenie z ktoreho pustate hudbu. Ja som bol velmi milo prekvapeny podanim zvuku po takejto uprave.
Ekvalizer som si nastavil podla seba a so zvukom som ozaj velmi spokojny, snad to niekomu pomoze.
whoiswho
Registrovaný: 27.6.2017
Auto: BMW 120i (F20)
Re: Hifi audio
Streda, 28. Júna 2017, 07:47
Ja som do F20ky nechav v BMW namontovat tu priplatkovy HIFI vybavu za 290 EUR (myslim ze to tak stalo). Hned ako som sadol do auta po prebrani som vedel ze je zle. Hlavny problem je ze tam niesu vyskove repro v stlpikoch. Takze ten zvuk je uplne neurcity. Basy ok, su tam dva basaky pod prednymi sedadlami. Ale vsetko ostatne zle :(.
Apline set sa do F20 neda u BMW dokupit. Skusal som v SK/AT/DE, vsade ma poslali kade lahsie. Takze som nakoniec riesil tuningovy obchod a dal tam u-Dimension EL Comp 8B za 249 EUR. Je to OEM set priamo do tohto auta. Set, montaz, zakladne vytlmenie, nove listy s otvormi na vyskace od BMW a bez zosilovaca to vyslo nejakych 600 EUR. Teraz to hraje podstatne lepsie. Ale aj tak budem musiet este zosik dokupit. Nakolko na tom co tam je sa nedaju nastavit zvlast basy. Ide iba jeden kabel z neho do stredovych reprakov a potom z nich do basakov. Takze dalsich 350 aj s pracou.
